Question about Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire Front Loading Washer and it displayed the error code E41 does that mean that the door switch is open or that it wont drain or spin properly. Model # LTF7000EGO
I just had the same issue!! It is either the control board or the door switch...I replaced my door latch/switch unit and it works great!! I ordered from www.repairclinic.com it took two days to ship it to me and I was back in business. I have never worked on an appliance before in my life, but it was super easy to do!!
Posted on Mar 25, 2011
What is code E41 on a Frigidaire Affinity ATF800FS. THE DOOR IS LOCK BUT THE DOOR LOCK INDICATOR WONT LIGHT UP & THE WASHER WONT SPIN
I appreciate your post, Trent!
Based off the information you have provided your Frigidaire washer is displaying an error code of E41 and the door is locked and will not open. An E41 error code means that your main control board thinks the door is open. I would recommend performing a reset on your washer and you can do that by disconnecting power from your washer for at least ten minutes. If that does not help correct your issue it could be a possible problem with your door lock assembly, control panel, or wiring harness. You may need to seek assistance from a professional technician to avoid unnecessary part purchases. I hope this is helpful to you. -Matt
Aug 03, 2015 | Frigidaire Washing Machines
I have an error code E41 on my Frigidaire ATF7000eso front load washer. How do I test to find the bad part
Good Morning friend, that's a great question!
I see that your Frigidaire washer, ATF7000ES0, is displaying an error code of "E41" and you would like assistance in troubleshooting that code. An "E41" typically stands for your main control board thinks the door switch is open. This could be a possible problem with your door switch assembly or main control board. I would recommend performing a reset just in case there is a miscommunication within the board and you can do that by disconnecting power from your washer for roughly ten minutes. If you restore power and continue to see an "E41" I would look over the door switch to make sure it is not damaged. If any electrical components need to be replaced I would suggest having a professional technician out to properly disassemble your washer. This will help you to avoid any future issues. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
I have a Frigidaire front load washer #ATF6000SF1 and need to reset the PAU and E41 error code. I cannot get the unit into diagnostic mode to accomplish this. How can I reset this code?
I appreciate your post, Josh Orenstein!
From my understanding your Frigidaire washer is displaying "PAU" and "E41". "PAU" normally displays when there is an interruption to the cycle and "E41" means the main control board thinks the door switch is open. Either code can display due to a faulty door latch assembly, door strike, or main control board. You can attempt to perform a factory reset by holding down the Start/Pause button and Select button until a signal sounds. Also review the door latch and strike to see if there is any visible damage that could cause a short within the components. If there is no visible damage you may want to consult with a technician for proper diagnosis and repair of your washer. Hope this information is helpful to some degree. -Matt
Dec 07, 2014 | Frigidaire Washing Machines
Error message e41
Hello Friend, thank you for your inquiry!
If you are receiving an error code E41 on your Frigidaire front load washer, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power to your appliance for about 30 seconds. You can do this by unplugging your washer or flipping your circuit breaker into the off position. If the error persists, it could either be the door switch assembly or your washer's main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Hope this helps! - Z
Jul 07, 2014 | Frigidaire GLTF2070DS Front Load Washer
E41 is displayed
Hello mev1985 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Oct 05, 2012 | Frigidaire Affinity ATF6000F Front Load...
Error code e41
Hello phrainer3 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Oct 01, 2012 | Frigidaire Affinity ATF7000E Front Load...
Code e41
You have a communication error. 1. Is the loading door closed?No, close the door. Yes, go to step(2).2. Disconnect the plug from J2 on the Main Control Board and check forcontinuity between the pins in the plug. Open, check the door strike. If good,replace the door switch assembly. Closed, replace the Main Control Board.
Jul 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
Hi Mr. Barry Coates, I have frigidaire ATF 6700FS front load washer. I am having problem with error code E41 and all time it shows me PAU. I tried all the solution on this site but nothing works. Could...
E41 - Control board thinks the door switch is open.
PAU means PAUSE in the cycle; if you are try all methods, I assume that the control panel needs to be replaced.
Check in this link your Control Board Replacement
Hope helps.
Oct 12, 2011 | Frigidaire ATF6700FS Front Load Washer
I have an Frigidaire Affinity Washer Model ATF6700FS1 got error code E41. Thinks the door is open. I tried unplugging the connectors to the door switch but nothing worked. What to do now?
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
May 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
163 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
