Question about Meade LS6 06100310 Telescope
Im getting a sensor failure message after the scope tries a level procedure, I tried leveling the scope by eye. but it does the same thing.
  • 3,186 Answers
Contact Meade for repairs- they will probably want you to send the scope back.
http://www.meade.com/support/index.html
Posted on Mar 21, 2011
How to use a spotting scope for shooting?
A Spotting Scope is an essential element for hunters and shooters. This small device is technically a special type of telescope used for hunting, magnifying and watching an image or object more clearly. The methods use a shooting spotting scope does not involve much difficulty.
Here is the method:
Comfortable position
For a perfect shooting experience, you need a comfortable position. If your comfortable position is unable to help you fix the targeted area, you are likely to miss the hit or glance.
Attachment of the spotting scope with the tripod
Having an accurate view of the targeted area is important. Due to this reason, shooters need to position the spotting scope with a tripod so that they can see the targeted area very clearly and accurately.
Adjustment of the magnification level
The lens and magnification level should be adjusted so that you can get the appropriate view of the targeted area.
View of the targeted area
After fixing the targeted area, you have to adjust the magnification level with the lens to view the targeted area. At the time of using scopes, you will find some problems that magnification will present. If you fix the magnification and focus firstly, you may not find the target. You have to first view the target, and you have to adjust magnification level as required. Here, you should bear in mind you will have to go with the slow magnification process because the fast magnification process cannot give the accurate target.
Adjustment of the focus
You have to know how to reset the focus because you will need to do it again and again. It may sometimes harm your eyes with the magnification level being set to high.
Focusing on target is important for shooting and the spotting scope is also important for this purpose. For acquiring a specific target, it is important to use magnification level with the spotting scope.
You should follow all the methods of using explained above. There is no alternative way to learning how to use a spotting scope for shooting except these methods.
Apr 05, 2018 | Optics
Oil pressure high, oil level low
Oil pressure and oil level are two different creatures.
your oil gauge determines oil pressure while the oil can (red light on dash) indicates oil levels.
There are usually two different sensors but can gauge the same types of things. E.G. - If your oil is so low that your pressure gauge is affected this can cause engine failure. Thus--a good rule of thumb is to check your oil once a week as the oil pressure gauge and red oil can may not always work as intended.
I hope this helps!
Aug 13, 2012 | Cars & Trucks
Whrere is the coolant sensor located
On a V8 there are two sensors, the are located on either side of the neck where the thermostat is located. Standing in front of the vehicle the one on the left is for the temp. guage, the one on the right is for the computer.
If it is the six cylinder and you're getting the "COOLANT SENSOR BAD" message on the VIC that refers to the level sensor in the header tank. Is common in this models, I have one '93 ZJ and my signal Sensor Coolant Level also is ON for long time; first, try to clean the plug and reset the ECU. If the signal show again, maybe you need replace this sensor.
For more details about location and diagnotics, check this documents:
ZJ-Secc-8D-Ignition-Systems
- Page 5 Location (Coolant Temperature Sensor)
- Page 11 Diagnostics/Service Procedures
- Page 24 Removal Components
ZJ-Secc-7-Cooling-System
- Page 23 Coolant Reserve Tank (Coolant Sensor Level)
Hope this helps.
Jul 11, 2011 | 1996 Jeep Grand Cherokee
Hi hoover 600 mb water wont shut off when it gets to the right level even when i push in the button and un plug it can you help Thanks
This is a failure of the inlet valve if the water flows all the time but if the water flows uncontrolled only when the machine is put on start then it is the failure of the WATER LEVEL SENSOR which is normally a pressure switch.
When the level of water reaches the set level then the pressure of the water will switch on the switch to contact and so give message to the controller to SHUT down the inlet valve.
Jul 07, 2011 | Washing Machines
I get an intermittent "Coolant Sensor Bad" The FSM is clear, Bad mean the line to the coolant bottle switch is open.
The coolant sensor and the coolant level sensor are two different sensors. Your message center is showing (coolant sensor bad),not level sensor bad.
The level sensor only monitors the amount of coolant in the container
The coolant sensor senses the degrees of the coolant, which turns on the electric cooling fans. Change the coolant sensor, and the problem should go away.
Nov 16, 2009 | 1998 Jeep Grand Cherokee
Problem with alignment of Meade LX90 8" telescope
Start from scratch-
RESET the hand controller.
Calibrate motors using the same power source you will use outside.
Re-train the drives
Calibrate sensors on Polaris
Use either the 110 volt power cord, or buy a 12 volt power pack and the proper Meade 12 volt cable. (www.scopestuff.com carries the right 12 volt cable)
If your scope is NOT the LNT or GPS model you must level the tripod before you align. Go to home depot and buy the $3 small plastic two way bubble level, or the bulls-eye style bubble level.
Further trouble, I suggest going to the LX90 Yahoo group forum, and asking questions there.
Good Luck
Aug 30, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
Dont understand what to do!
The Under Water Level Of Mario is very interesting you have to put all your interest into the games first... if incase you dont pass through the next level then first see the where you have made the mistakes because this will surely help you pass thorugh the next level..Keep keep eye on to it .Hope in this way your problem will be solved and 'All the best for next Level'..
please rate my solution.
Thanks.
Mzas.
Jan 02, 2009 | Nintendo New Super Mario Bros. for DS
Nikon az1 auto level
There are 2 allen screws on the fish eye bubble that can be adjusted to correct that problem.
First level the instrument;
Then turn 180 degrees
Adjust the vial until the bubble is half way from where it is back towards the inner circle.
Relevel the level using the foot screws
Then turn 180 degrees again (back to where you started)
It should be mostly fixed, however if it is not just repeat the steps above; it gets exponentially better everytime until you can no longer detect the error.
Aug 02, 2008 | Nikon Optics
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Optics
Meade LS6 06100310 Telescope Logo
108 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Are you a Meade Optic Expert? Answer questions, earn points and help others
