Question about Alpine Car Audio & Video
Need to know how to wire Alpine 12" 1242D 4ohm Want to use 1 speaker in ported box with Phoenix gold 2200pro amp
  • 1,586 Answers
As long as the total wattage of the amp does not exceed the total wattage of the speaker, you can bridge the amp. To do this, put the positive wire of the speaker on the positive terminal of channel 1 on the amp, and the speaker negative wire on the negative terminal of channel 2. This allows you to run the amp's full power into one speaker.
Posted on Aug 03, 2008
I have a 12" d4 type r 1000 rms and a alpine 1000 amp speaker sounds great but smells like something is burning, my amp never over heats or shuts down but the smell is still coming from the sub?
Cut your gain back on the amp. It sounds like they are set too high. Check your install instructions on how to set your gain. If you have a 4 or 5 volt output head unit your will not be at half way. Im running a JL Audio 500 /1 on a skar wwv10 dvc in a ported box. My gain is set about half way & its plenty loud.I have a Alpine 9887 headunit 5 volt output on my RCAsI can take a volt meter & set my speaker output at 45amps & my gain in perfect.
Apr 28, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
What is the best box for 2 ALPINE SWR-1242D 12"SUBWOOFERS TYPE-R NEW SUB WOOFERS
Ported and tuned to around 37-40 hertz. After all displacement the box should be in the 2.2 cubic foot for sub and you will be very impressed. Build it yourself for optimum sound and output.
May 23, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
NOT SURE WHAT OHMS SUB I NEED!
if you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know bertman285@hotmail,com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
Oct 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
What size enclosure (sealed)for Alpine 12"1242D(METAL Music)
  • 12" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 25-500 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 85 dB
  • top-mount depth: 7-5/8"
  • sealed box volume: 0.57-1.0 cu. ft.
  • ported box volume: 0.75-2.0 cu. ft.
  • For rock, i actually have 2 seperate 12's in slot port boxes i built facing forward. Facing forward reduces a little resonance and spl, but keeps alot of that annoying rattle off your tag lol
    Hope this helps :)
    Dec 10, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    Help on 1 amp and 1 alpine srw-124d
    You have dual 4-ohm coils. 2 coils per speaker.using one speaker, if you take and run the postive from one coil and connect it to the negative of the other coil, then take a wire from your bridge channel on your amp and connect the positive to the the remaining positive on the one coil and connect the negative to the remaining negative on the other coil you will create a 8ohm load on the amp in bridged mode.
    now this is the important part. The bigger the load on the amp the greater the wattage output to the speakers. This sucks the wattage out of the amp. Careful not to overload you amp. The setup above is safe for any amp. The following is for 2ohm stable amps only. The lower the ohm value 2, 4, 8 and so on, the greater the load on the amp.
    connect the positive of one coil to the positive of the other. connect the negative of one coil to the other negative of the other coil. then take a wire from your bridge channel on your amp and connect the positive to the the positive on one coil and connect the negative to the negative on the same coil and you will create a 2ohm load on the amp in bridged mode.
    Series = add the two ohm value
    parallel= halve the ohm value
    you can play with series and parallel together using more than one speaker setup.
    Jun 07, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    Need help with the wiring on amp to subs
    http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4 DON'T FORGET MY FIXYA RATING!
    Mar 09, 2008 | Phoenix Gold R15.0:1 1500W Octane-R Mono...
    Wiring my subs to my amp
    bridge it and rear channel if you need to know how to bridge let me know
    Feb 07, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
    Wires
    Hi Gott Mudd,
    I can relate to feeling it in the bones. You got the stuff to do it.  You should try the Alpine MP3 head units with bass boost, those are bad to the bone.
    Wiring:
    Amp to Speaker I like to use the code VC for Voice coil, and AO for Amplifier output.  Also + for positive.  If I say VC1-, I am referring to the first connector starting left to right on the Alpine Sub. Now I have not seen a Kicker KX1200.1 amplifier.  All I see are MRA, MRP, or PDX prefix on the part numbers. So take what I am saying as a guess. You may want to revisit looking at the model of the amp to be sure your giving the right information.
    We are going for  2 Ohms. Paralleling the two subs, not the voice coils. The voice coils will be series.  Bridge the amp if necessary to get mono channel. only using AO+ and AO- for output.
    AO+ to Sub1VC1+
    AO+ to Sub2VC1+
    Sub1VC1- to Sub1VC2+
    Sub2VC1- to Sub2VC2+
    AO- to Sub1VC2-
    AO- to Sub2VC2-
    Set your Crossover to LPF
    Adjust the bass gain down to lowest until you test.
    Set the Frequencies to midrange between 40 and 100hz
    Your box can be ported or not. It depends on the space your have.  If you do not have much room, go Enclosed and build a box that the inside space is less than 1 cubic foot.  Make sure you give barely  enough clearance for the speaker to fit.  If you have room, Go with a box and vent it with a 3 inch Vent tube 10 inches long.
    Oct 15, 2007 | Alpine Type-R SWR-1242D Car Subwoofer
    Car Audio & Video Logo
    49 people viewed this question
    Top Alpine Car Audio & Video Experts
    xxxxxx xxx
    hoyzee1
    Tygh Duval
    Tygh Duval
    Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
