Question about Sony Cyber-shot DSC-W50 Digital Camera
The lens won't retrack - Sony Cyber-shot DSC-W50 Digital Camera
    Novelist:
  • 107 Answers
Unfortunately this is one of the most common problems in your standard 'point and shoot' camera. If you are unable to fix it yourself, the cost to repair something like this is generally about the same cost as a new one. You can try and take it to a friend or a local repair shop, but before you do try reading the information from this link. Hopefully that helps
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Mar 21, 2011
Lens will not retrack when turning camera off
The best course of action here is to just replace the camera, the repair cost is likely close to the cost of a newer model.
Jun 20, 2016 | Panasonic Cameras
Kodak easyshare v803 power's on but when lens goes out the power goes off retracking the lens and does not stay on
the coomon caused are lens blocked.
1.- clean the external surface of lens with can air compressed and a soft cloth
2. turn OFF your camera
softly PUSH the lens
3.- Softly PULL the lens while you turn ON the camera
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Cameras
Getting an error code E 45
Error 45 in your camera clearly indicates it is related to a lens issue. Something has caused the lens to jam or stop working. When it does you get the E45 error you have to update the firmware and the error should go away.
Thank you !!
May 23, 2010 | Kodak EasyShare CX7430 Digital Camera
E 18 errror
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Dec 28, 2009 | Canon PowerShot S2 IS Digital Camera
The zoom lens don't retrack Display don't
Charlene, It seems that there some dust that has entered between the lens housing and the camera body. To remove it you must use the vacuum cleaner to pull out the dust from this place. And keep switching on and off the camera so that it tries to move the lens inwards/outwards. If this does not work then the movement mechanism of the lens may have got stuck and would require more serious efforts for which you may or may not have to tools and knowledge.
Nov 02, 2009 | Vivitar ViviCam 8400 Digital Camera
Ex-z9 lens is bent and wont retrack. PUSHING THE POWER BUTTON GETS A LENS ERROR MESSAGE. aNY WAY TO GET LENS UNSTUCK
There is no DYI fix for your damaged lens, and attempting to repair it yourself will likely cause serious damage to the camera. Professional repair is needed to fix this problem.
Oct 25, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
THE TEL PHOTO LENS WON'T RETRACKED
That happened to me. Camera is a few years old so the warantee was long gone, so I actually took it apart and cleaned inside it with electronic cleaner.
If you still have a warantee you could call customer service and speak to a technician.
If you know how to put things back together easily, you can try it. You could probably use Air in a Can to spray around the lense.
I sure hope this helps!
Oct 23, 2009 | Cameras
Lens will not fully close.Len get stuck when retracking.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 30, 2009 | Canon Cameras
I have an A520 Powershot..I dropped it and jammed the lens..now the lens won't retrack back in.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Apr 24, 2008 | Cameras
Sony Cyber-shot DSC-W50 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
