Will not spin, noise from drive. will agitate, but fails to turn drum when going to spin cycle
    President:
  • 1,654 Answers
Since I have no idea what machine you have, top loader or front loader I can give you some places to look at.If it is top loader, either the motor coupling is going out, this is a small rubber piece between the motor and transmission. When these go out it starts a whirring sound or growling. Picture 2 rubber gears rubbing against each other but the teeth aren't engaging. Front loaders could be the transmission going out, and some have belt drives which can be going bad. Another reason machines won't spin is that the pump is clogged or drain hose is clogged, or the lid switch or door switch is broken or out of alignment.
Posted on Mar 21, 2011
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
My 10+ yrs old Frigidaire gallery # GLTF1240AS front-loader drum won't agitate/spin
Check and see if the drive belt broke? On mechanical agitators using gears, a solenoid may fail and drive motor won't function.
Dec 23, 2013 | Frigidaire Washing Machines
Loud banging noise during washing cycle. Sounds like agitator is slipping,then banging. No noise during spinning cycles.
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
My washer makes a loud grinding noise when spin cycle is running. If I hold the agitator stationary while spin cycle is running drum will continue to spin and noise stops. I have already replaced the dog...
If dogs and coupling are replaced, then you will need to look at the transmisson, check the piece that holds drum on itself, this bearing can go bad. There is also a seal under the nut that holds on the air bell housing.
There is also a plastic hub that connects the agitator to the motor that can go worn.
Feb 20, 2010 | Kenmore 23822 Top Load Washer
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool washer spin cycle noise
Likely you need either an agitator repair kit or need to replace the direct drive clutch assembly. The drive coupler is a fail-safe device and generally fails for a reason. In order to repair the agitator, you will need to acquire an agitator hub nut wrench.
Feb 18, 2008 | Washing Machines
Noisy washing machine
the agitator transmission may be the noise source because it turns with the drum during spin. may need a new transmission just to stop noise.
Nov 19, 2007 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
