Question about GE A730 Digital Camera
My digital camera is having a proble every time i will take a shot it always put "write Protect" what will i do?
  • 262 Answers
I'm going to give you a canned answer, but it's a simple question and your GE A730 camera is no different in the way it reacts to the 'lock' tab.
Why does my camera say "Card Locked" or "Write Protected"?
The basics. In the same way that the recordings on audio cassettes and VHS tapes could be protected by breaking off the little tab on the back corner, the material on a memory card can be protected against being overwritten. Instead of a tab to break off, write protection is done by a tiny slider on the edge of the card (opposite the cut corner). Before the camera will take pictures, it's necessary that this slider on the card operates a microswitch in the camera, which it will only do if it's NOT in the 'lock' position. The slider actually does nothing inside the card, which is why I don't call it a 'switch' even though it seems like one. Its only purpose is to be detected by the microswitch in the camera's slot, and it's the camera that takes care of the write protection, not the card.
Diagnosis.
Obviously the first thing to do is to check that the slider is NOT in the lock position. If the camera is giving you this error in the unlock position, it means that the slider has failed to operate the microswitch, or that the microswitch itself is faulty, or possibly that there's some file system error with the card. To diganose the problem, it would be really helpful if you could try two or more different memory cards in the camera and see if just one, or all of them exhibit the problem.
If only one memory card exhibits the problem: In this case, it's clearly something to do with the memory card. Is the slider worn, bent or missing? A missing slider will write protect the card in the same way that sliding it to the 'lock' position will. There's another possibility. I've recently discovered that
some cameras which use xD-Picture cards also give this error even though those cards don't even have lock sliders! Furthermore, some users have reported fixing this error by reformatting the card. Therefore, I feel it's also possible that your error may be fixed by reformatting. Before you do this, make sure that you've copied all you want off the card and then use the camera's 'format' function to reformat the card. I advise using the camera for the format function because this guarantees the correct file system. If you use your computer to format it, you may easily get the wrong one. However if you need to do it this way, see which file system is currently in use on the drive before you start. Go to "My Computer" and right click on the drive which is the memory card, and choose "Properties". Examples of filesystems are "FAT" (probably FAT16), "FAT32" and NTFS; to make sure your reformat is successful, ensure you use the same filesystem as before.
If some memory cards work, and others don't, or the same cards sometimes work but only sometimes:
The slider is really tiny, so it's possible that the number of people reporting this error is caused by lack of precision in manufacturing sizes. It must be hard to make a microswitch that can feel such a small thing. Does a better brand of card work? Can you bear to simply stick to the better brands, or the ones that work most reliably? As a remedy of last resort, you could try wrapping a small strip of sticky tape over the slider to increase its thickness, but I think this is a risky solution. There's a risk that the tape will come off in the slot and cause even more problems, or that the tape will be so thick that the card will jam in the slot and you'll have trouble getting it out.
If all of your memory cards behave in the same way: In this case, it's clearly something to do with the camera. It could be that the microswitch is broken, or there's some software error. Although it's less likely, let's cover the software error first; please find the 'system reset' function in your settings menu and use it to clear everything. Any good? If not, try the sticky tape solution in the last paragraph in the hope that it's a size/fit problem with operating the microswitch, but if that fails we're out of options really, beyond a repair of that microswitch.
Posted on Mar 21, 2011
After used one shoot, the camera always reset to macro mode.
IF this camera has the Power-Zoom function [as many newer model cameras do] ... then this function is automatic [if there is any "long-time" between shots] as this is designed to PROTECT the delicate lens mechanism against damage if it should be accidentally dropped and/or knocked against an object.
Most modern cameras have similar safety features built-in to protect your considerable $$ investment [including my camera] ...
IF this is still a problem then go to OLYMPUS Website in your country/region and ask their techs for advice ...
Nov 23, 2013 | Olympus D-630 Zoom Digital Camera
"write project" while taking shots
I assume it's actually saying "write protect" and not "write project".
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 18, 2012 | GE X5 Digital Camera
The lens on my camera opens and closes 3 times each time I turn it on. THis is followed by an error message "Turn the power off and on again. THAT NEVER WORKS
Hi well sorry to tell you but the controller board has failed, it's pretty common with these ones, it may happen after a knock or a bump? but not always, usually is a bad join on the flexible board(s), but in any event the only option is repair, there is NO DIY, to repair you will have to send it either back to the manufacturer or agent or take it to an authorised camera repair shop and ask for a "quote" and go from there.
Oct 12, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
When i turn on my Cyber-shot camara it always says " For use with compatible battery only." What do i do ?
sorry to say this friend....u have inserted an incompatible battery in your camera
that is why the message "for use with compatible battery only" keep showing up whenever u switch on your camera
so u got to replace your currently installed battery to the compatible battery of your model
so i have searched the web for your model's compatible battery list...just check with it in the below link
http://www.sales-battery.com/digital-camera-batteries/sony-cybershot-dsc-t100_r.htm
even check with your sony cyber-shot model's manual for compatible battery info
in case if you have lost your manual friend...below is the link for your model's manual download
http://www.pdf-manual.com/user-guide-instruction-owner-manual-sony-cyber-shot-dsc-t100-13434.html
"feel free to ask further help friend....am here to guide u based on cameras:-)"
Aug 27, 2011 | Sony Cyber-shot DSC-T100 Digital Camera
When we are about to take the picture "write protect" comes written.and the picture isnt shot! so what to do?
1. If you are using a SD(HC) memorycard in the camera, be sure that you have set
the Write Protect switch on the memorycard to the not LOCKED position.
2. You may further look at the manual page 40, page 53 and page 59.
Jul 12, 2011 | Olympus SP800UZ Digital Camera
My Sony Steady Shot DSC-H5 says "recording" when I am taking regular pictures. Uses up the memory stick quite quickly, although it lets me take about 30 pictures...!!! Doesn't actually record,...
There are some multi burst programs etc which show RECORDING, but actually store pictures. You can always do a reset you know (initialize from the camera SETUP menu) - that should help.
Jan 24, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Camera fell from a chair and hit the floor. The power was off at the time of the fall. Now the lens is sticking out and seems "crooked." When I press the power button, the camera will not...
It's busted.
Take it to a dealer for repair.
You may be able to claim this on your Home Contents Insurance.
If it costs too much to repair, hold a little ceremony and send it to a recycling centre for proper burial.
Never drop cameras, expose to sand water (unless waterproof). These will surely break a camera. Always be conscious of your camera to edge of tables or other potentially damaging situations. ALWAYS use straps and safe storage.
I'm sorry it's broke. : (
Regards Robyn
Jan 09, 2011 | Sony Cyber-Shot DSC-W5 Digital Camera
Good day.. After uploading photos to my PC using USB connection of my GE X5 camera " Write protect error " always appears when taking shots.. Please help.. Thank you very much. -TeR-
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 23, 2010 | GE X5 Digital Camera
Snap Shot Pixtreme 3.1 M camera corrupts SD cards
If you just put the card straight into the card reader, not forgetting to set write-protect, you should eliminate this problem.
Aug 04, 2017 | Snap Sights SS 1.3 Digital Camera
GE A730 Digital Camera Logo
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
