Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston usb cannot recognize by the computer what will i do to fix it? please help.
  • 62 Answers
I had a situation where my usb stick was corrupted and all I could do is format it. Then I seen times were a Windows format wouldn't work. I called the company and they said that it was no good anymore. To go purchase another.
Posted on Mar 21, 2011
My PC can't recognize my kingston 2GB it says unknown device it works,but i can't format or do anything .. please help ?!?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Sep 05, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Datatraveler Windows 7.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
eventhough the device is not present, causing the said error.
Aug 15, 2012 | Kingston Computers & Internet
My kingston 2 gb flash disk is not recognized, how can i fix it?
Please follow the below steps to fix your problem
Connect your flash drive to your computer using an available USB port. If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double-clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive. A question mark icon should be shown to the left of the label. Right-click the device name and select "Uninstall."
5
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes." This will scan your PC for any new devices. Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
6
Click "Start" > "My Computer" and look for your flash drive. If this process was successful, your flash drive should now show up under My Computer as a storage disk.
Hope the above information will be helpful to you.
Thanks.
Oct 22, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Window did not recognized my kingston usb (DT slim)
Usually all flash drive are plug and play devices if your computer is not recognizing it you should try plugging it into another USB port and even try plug in another computer to see if it would work.If your flash drive does not work this mean it is dead and the flash drives are not design to get the information off when it is dead.
Aug 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The computer does not accept the Kingston usb!
Kingston is a decent brand device. Does the port recognize the device and is just unable to install drivers? Does the USB port work for other devices? Have you tried other ports? Go to device manager (start, control panel, system, hardware, device manager). Are there any rec X's? Any yellow asterisks? Fix whatever you find. These are just some hints that I hope will help you find your problem. I assume your device is a jump drive. You might try another also... perhaps yours is faulty.
Nov 14, 2009 | Computers & Internet
Usb flash drive not recognized when plugged into hub
data is lost,
test with H2testW'
fix with PD V1.08 B3
good luck !
Jan 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb not recognized?????????
The USB port in which your flash disk has been inserted muight be damaged. Try inserting it in another port.
Oct 22, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My 4gb kingston pendrive is not recognize by any computer
Hello
For Solving your problem do the following
1. Check that the USB is connected properly to the mother board
2. USB 2.0 Drivers are loaded
3. See that the Pendrive is properly connected
Let me know that your problem is solved and rate me as Fixya!
Sep 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Non recognized Kingston pendrive 4 Gb
i bought a kingston 2 GB pen drive. computer does not recognize. device manager says drivers are not installed. but it works in safe mode. kindly help
Sep 08, 2008 | Electronics - Others
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
60 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
