Question about 2wire 2700HG-B Router (2700HGB)
Limited or no conectivity
My wireless is saying limited or no conectivity. how do i fix
    Problem Solver:
  • 13 Answers
First of all try to reset you router and your pc. If it still doesn't work tell me a little more about your configuration (how many pcs, which is your router).
hope to be helpful
Riccardo
Posted on Aug 03, 2008
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
When trying to connect to the internet via cord, my laptop will say limited or no connectivity. I have restarted it and started all the applications that were disabled. i also have the wireless chip for...
On the right below task bar find network conection >>> open network conection
On Local Area Conection ( cord ) right click >> properties rolls down to Internet protocol (XP) or IPv4(WIN7) click properties >>> on general tab choose Obtain an IP address automatically >>> click OK >> OK
akee_akee@live.com
Aug 16, 2011 | Dell Latitude C610 Notebook
Belkin wireless g router working perfect last night today will only work if patched direct to router why has it stopped working wireless saying limited or no conectivity
Hi Ok lets resolve your problem
the problem you have with your connection is wireless issues:
  1. go to setup page Belkin 192.168.2.1 in browser Explorer
  2. change your security mode to 64bit WEP
  3. if your security mode is allready 64bit WEP change again your SSID and passwird
Ok that is the solution for this problem.
Any questions etme know.
please rate me techbelkin.
Oct 29, 2010 | Belkin (F5D7230-4) Router (587009)
Hi, my name is Abimael and i have any problem whit my netbook inspiron mini 10 DELL. I canot conect to internet as i always do it. Display a message that it say Limited or not connectivity AND...
Click on start and select all programs.. Click on dell wireless utility.. You will have option to disable the dell wireless utility - please disable it.. Then restart the computer and try connecting.. It will work.... Still not working then unistall the drivers from the devi9ce manager and install the drivers from the dell website... (www.support.dell.com).. The issue will be definitely fixed...
Sep 02, 2010 | Dell Inspiron Mini 10 Notebook
My wireless connection , says "Limited or no conectivity" I have excellent signal strength. This occured when i plugged in a second lap top with cable. Now only port 2 works and wireless is restricted. I...
Usually this is caused because the security settings on the laptop or PC do not match what is setup on the wireless router. Login to the wireless router and look at what is setup for security, WPA, WPA_PSK, etc, also the passphrase, it is case sensitive. The setup on your laptop must match.
Jun 22, 2010 | D-Link DIR-655 Wireless Router
My conection says limited connection with wriles what can i do
Its looking like that singal strength is low. Try to locate Router near around or move to location near router so that it can assure that problem is with Single strength only.
Please put comments so i can further help you
Mar 23, 2010 | D-Link DIR-615 Wireless Router
I have an IBM ThinkPad R40e and there is a question mark in the ethernet conection i have already install the driver but still I can´t conect to the broadband ethernet. Is this a bug or daughter...
It may that your wireless card can't handle the encryption on the wireless network you are trying to connect to. Thinkpad R40's are limited to WEP encryption (see Lenovo's/IBM's site http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-41929). If your network is using WPA, for example, you won't be able to connect. Usually it will say something about not being able to find a certificate if this is the problem.
Oct 15, 2009 | IBM ThinkPad R40e 2684 Notebook
Cannot connect to my Netgear WRG614 v6 router. My Dell laptop shows an excellent connection but it says limited or no conectivity???
if it says limited or no connectivity, it means that there are a couple of settings that needs to be configured for your wireless connection. click on start > run> connections> wireless connection >when you see your wireless network, try to disconnect from the network and try to connect again using the right wep key (if you have it enabled). or you can try checking the wireless properties. start > run> type in ncpa.cpl and hit enter. right click on wireless connection and click on properties. highlight tcp/ip and click on properties. make sure that the settings are set to obtain automatic. hope this one helps.
Jun 04, 2009 | NetGear WGR614 Router
ENUWI-G2 wireless adapter.
check if the wireless key u entered is correct
unplug and reconnect the wireless adapter
checked if u are able to go online with the cable connection
if still problem persists uninistall and reinstall the wireless adapter
still no go only option is to replace the wireless adapter
May 23, 2009 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Hooking up without a modem
how to you get online through the wireless connection? Did you put a username and password or a static ip address?
Aug 03, 2008 | Belkin (F5D7230-4) Router (587009)
2wire 2700HG-B Router (2700HGB) Logo
81 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
