Question about Car Audio & Video
I have a 1999 Ford Expedition. My left front speaker has no sound. I tested the speaker separate from the truck and it works. Also my subwoofer has no sound. I have not tested the speaker yet. The subwoofer amp does have power to it. The sub amp is located by subwoofer in rear of vehicle. According to a wiring diagram i have there is a stock amplifier between the radio and all speakers, which also feeds the "sound" to the sub amp. But some thing i read on the web said its amp was built into the radio. So where is the amp! The wires coming out of the radio don't match the wires at the speaker, so it makes me think there is something between them. Where is the amp?!
  • 631 Answers
SOURCE: No power output
Set the meter to AC volts and measure the AC voltage on the RCA cables where they plug into the amplifier. The black meter leat will go on the shield ground of the RCA cable. The red lead on the center conductor. You may have to turn the volume up to get a reading on the meter. At high volume, you should read at least one volt but the actual voltage will vary due to the audio signal. If you get no voltage on the RCAs, measure the AC voltage on the input to the LOC. Let me know what you find.
Posted on Oct 05, 2007
alicantecoli
  • 22326 Answers
SOURCE: Front Speakers And Stock Sub Stop Working HelP!!!
do you need all this noise whilst driving the car,could you hear an emergency vehicle ??check the fuses first and connections ,try speakers direct to radio
Posted on Nov 13, 2008
  • 290 Answers
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Posted on Mar 26, 2009
rteemon
  • 578 Answers
SOURCE: wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Posted on Jun 25, 2009
  • 16 Answers
SOURCE: 2002 Ford Explorer Sport - Blown Subwoofer
yes you can replace it but is gonna be costly,because your gonna need a box plus the new woofer,any after market will not fit plus will require more power ,so your gonna need a bigger amp,plus wiring etc,,,,,re consider using a factory sub again or replace the sub plus the amp..check the replacements and amps at crutchfield..good luck
Posted on Jul 10, 2009
Fuse schematics
Here you go, hope this helps.. Use a test light to test for power or 12 volts at the bulb holder.
1999 ford expedition fuse layout Google Search
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2496c4f07ad24453
Mar 19, 2014 | 1999 Ford Expedition
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
1998 Ford Expedition with premium sound system. I removed the factory radio and installed an aftermarket radio had no sound coming from it, so I disconnected and installed the factory radio back in the...
Go to the engine fuse module and check 20A fuse 5 which feeds power to the separate amplifier and subwoofer amplifier. Also check 10A fuse 3 which feeds power to the radio, the CD changer, and the rear integrated control panel.
Oct 16, 2012 | 1998 Ford Expedition
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my...
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
I need the audio wiring diagram for a 2002 for expedition (eddie baur edition). It has a mach audio system.
2002 Ford Expedition Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: White/Violet
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Blue/Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Violet/White
Right Rear Speaker Negative Wire (-): Light Blue
pls rate
Dec 13, 2009 | 2002 Ford Expedition
I need the audio wiring diagram for 1997 ford expedition Eddie Baur with premium sound system
1997 Ford Expedition Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Purple
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Audio Front Speakers Size: 6′ x 8′
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6′ x 8′
Car Audio Rear Speakers Location: Rear Doors
Right Rear Speaker Positive Wire (+): Purple/White
pls rate
Nov 02, 2009 | 1997 Ford Expedition
I need to replace the left front upper ball-joint on a 1999 Ford Expedition, 2WD 4.6liter engine. How much work is it?
If it's an origional joint that you're changing, and it's still riveted in, it can ****. If it's been changed once or twice it'll be bolted in, and then it's just a matter of removing the bolts. You'll need a ball joint separator for one thing, and a floor jack.
Jun 03, 2009 | 1998 Ford Expedition
I need the color wiring for a ford expedition radio
Mar 26, 2009 | 1997 Ford Expedition
Rear speakers don't work
Speaker test confirms whether the speakers actually work but not the sound level you have them set at. Chack volume level of each speaker. This may be a separate button all itself.
Jan 06, 2009 | Audio Players & Recorders
1999 ford explorer car stereo install
Heres the whole list. 1999 Ford Explorer Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Doors Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink (from the12volt.com) Best of Luck.
Sep 28, 2007 | Car Audio & Video
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
