Question about Oreck (AIRCOM1BOI) Air Purifier
I have 2 and they smell bad. You have a bad reputation and I am going to return them to Canadian Tire if the odor problem is not resolved in the next 48 hours.
    Brigadier General:
  • 4,736 Answers
Stan, unfortunately what you're saying is not to Oreck, the manufacturer. This site is designed to help you determine what the problem is and hopefully, how to solve or repair the problem. But, not be threatened by what you want to do with your Oreck Air Purifier. Save that for Oreck.
With that said, I would have to ask you, when was the last time you cleaned or changed the filters on the air purifiers? I suspect that may be problem.
Posted on Mar 21, 2011
Environizer doesn't work
Is it dead? does the motor run? Fan blow? No freshened smell from unit, only stale odor? You haven't given any usable info here but I'll address a dead unit condition for you: power cord stretched/damaged, on/off switch bad, fuse/cicuit breaker(if any are used).
Jun 15, 2014 | Air Purifiers
No fresh air smell from EcoQuest Fresh Air 2.0. What is the fix for this? Everything else seems to work
The FA2 uses several technologies for purification. The "normal" mode produces purifiers using the honeycomb RCI cell and UV light. This has little or no odor.
Open the back of the machine, or shine a flashlight through the front to make sure the white 4" plate is inserted, closest to the back screen. If it isn't, you'll need to either put one in, or order one from Vollara (new EcoQuest company name) @ 1-800-989-2299. You can use #16618 as the dealer referral number if you are no longer in touch with the registered distributor who sold you the machine.
When you turn the machine to "purifier," you should then detect the "fresh air" smell. You'll see square footage numbers, which you should set according to the immediate area, NOT total for the building! Also, the machine directs the air flow to the sides in a "V" shape, rather than straight ahead. So if you're standing close to the machine, smack-dab in the front/center, you may not be able to smell any of the purifier!
When the machine is on "Away" mode, the purifier and fan are ramped up to maximum strength, and you can choose 2, 4, 6, or 8 hours for this super-sanitization. At then end of that time, the machine will return to whatever setting you had it on for daily operation. No people or pets should be in the immediate area, because the purifier is strong and likely to be uncomfortable. (Set the timer for 2 or 4 hours less than the time you expect to be "away," to allow the purifier levels in the home to return to a pleasant level.)
Hope this helped.
Jan 20, 2011 | Ecoquest Fresh Air Air Purifier
I just purchased a used XL15s. The unit when in manual mode emits an oder, but the air feels oxygenated. When you breath close to the machine the air seems to irritate or kinda burn my eyes. When in auto...
This is what the machine is designed to do! The machine emits a low amount of ozone, which is the purifier/sanitizer created by sunlight. Close to the machine, it's concentrated. When it spreads throughout the room, it kills odors and bacteria, and creates the fresh smell of clean air. The air truly is "oxygenated," because ozone is simply O3, instead of O2, and breaks down quickly.
If the numbered dial is set too high (try it at 300 to 500) it will smell "bleachy." Your "rule of thumb" is that when you've been away, and enter the home, you should experience the same fresh, clean smell that you get when you step outdoors on a bright spring or winter day.
When you're doing something that creates odors, like frying fish or cooking sauerkraut, turn the dial up to take care of that odor quickly, then turn it down for normal operation.
Leave it on the manual setting for continual purification. Often, the auto setting has been disabled, which might be the case in your older machine. (These machines can be 12-15 years old!) For an owners manual, go to www.vollara.com (new name of Ecoquest/Alpine). They may be able to help you.
Jan 17, 2011 | Alpine Air XL-15 Air Purifier
I have just remodeled a old condo with new toilets and I am getting a strong gas smell. How can I get rid of it. I am in Thailand and the building is 22 years old.
jajoy,
Did you connect the sanitary pipe stack to the sewer line that takes away the flushed effluent? Check to see that the pipe is connected, not leaking sewer gas, not plugged up with an animal carcass, and that the pipe extends through your roof three feet past the roof line (keeps smell out of house).
Nov 29, 2010 | Air Purifiers
No clean air smell/crackling & static
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Oct 01, 2008 | Ionic Pro TURBO Air Purifier
XL-15 Classic Living Air emmitting Foul Odor!!
Ionizers do cause a bad odor to happen. I work in the copier business and do work around machines that can cause an ozone to happen when there are ran. Copiers like ionizers can cause an ozone to happen because the air particles are being electrically charged. The smell isn't good to be breathing in as well.
Here is an EPA report about ionizers
The Consumer Products Safety Commission is going to be making a decision about the health effects on ionizers by the end of the year. Their decision can effect selling ionizers all together.
This industry should have been regulated years ago and after what happened to Sharper Image this year due to their arrogance it isn't doing the industry any favors. They went out of business because of Consumer Reports findings and tried to sue them for it.
If you really want the air in your house cleaned, the best way to do it is using a hepa filter.
Jul 26, 2008 | Ecoquest Living Air Classic Air Purifier
Living Air XL-15 Classic - Foul odor!
Hi cant standit,
Can you control this odor by adjusting the ozone (O3) control? High levels of O3 smell obnoxious or irritating to some people; you want a fairly low concentration (~40 ppb - that's parts-per-Billion, not much).
It sounds like you've done everything else right. Have you consulted with the dealer you bought from? How about EcoQuest? If it's not the O3 level being too high, then perhaps there's something goofy with the unit. If it's under warranty, pursue that option. You should have contact infor with the unit; respond if you need it and I can post it.
Let me know.
Jun 06, 2008 | Ecoquest Living Air Classic Air Purifier
Last night for the first time the machine is emitting a gaseous smelling odor. At first we thought it was coming from the house, electrical or outside. Not finding anything which would generate this...
The odor is trace amounts of ozone. I hate the smell myself, some people love it. Most common cause is a short in the cells. Can you hear any arcing noises?
Did you clean it recently. The ozone can be reduced by making a change in the power head. What is the model number and date code........Should be like, F300Aor E1625, The date code is a four digit numbe like.....0904. Both can be found on the back of the aircleaner door.
May 22, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
Need to buy replacement filters
Here is the link; http://www.hamiltonbeach.com/cgi-bin/main/co_disp/displ/pgname/trueair_home/strfnbr/20 Hope this helps :)
Dec 01, 2006 | True Air Plug-Mount Odor Eliminator with...
Oreck (AIRCOM1BOI) Air Purifier Logo
66 people viewed this question
Top Oreck Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
