Question about Compaq Televison & Video
How to repair computer that is not connecting with monitor and keyboard?
    Master:
  • 525 Answers
Take out the ram sticks and put them back in. See if it helps.
Posted on Mar 21, 2011
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Jun 13, 2014 | Acer 22" X223w LCD Monitor
I connected my LG 22LD350 to my hard drive, and both the sound and picture work, after I selected "RGB-PC" on the monitor. But I don't see a connection anywhere on the TV for my keyboard and...
Hi bpollen,
you will use the computer for {GUI} Graphics User Interface!
The TV is a "secondary visual device, or monitor"
The TV "cannot give instructions or commands."
"You not be able to "tranfer information from the TV.
You will use the "Computer for [Input and Output] transmissions.
The "Keyboard and Mouse" stay 'connected to the computer!"
You will "control all functions for the TV; by using the computer."
"I hope this information solved some issues?"
!"Take a moment to rate the help."
Thank you! paul7of9
Mar 18, 2011 | Computers & Internet
Green p0wer light flashing on screen but no display
Monitor is not on
Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep
If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
Connections not connected properly
vga.jpgMake sure that you are connecting the monitor to the back of the computer in the 15-pin connector as shown to the right or older computer 9-pin connection.
If the computer is properly plugged in, make sure it's getting getting power.
If you are not receiving power from a known working wall outlet and if the power cord is removable, replace it with the one connected to the computer and attempt to power on the monitor again. If the monitor still does not get power or it is not removable, it is recommended that the monitor be replaced or serviced at a local TV / Computer repair shop.
If the monitor is receiving power, check the status light.
If the light is orange or flashing ensure that the monitor is not in a suspend mode by moving the mouse or pressing a key on the keyboard. If the computer does not get a display by moving the mouse or touching the keyboard, turn off the computer and monitor and reconnect the data cable from the back of the computer, and if removable, the back of the monitor. Turn the computer back on; if you still encounter the same issue, continue reading through the other possibilities.
Monitor settings are not correct
Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibilities.
No Post
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting a No Post.
Steps on troubleshooting an irregular POST or no beeps can be found on document CH000607.
Hardware Issue
If you have followed the above recommendations and are still encountering the same issue, it is likely that the computer may have either a bad video card or monitor. The best method of determining this is to do one or both of the following:
  • Disconnect your monitor and attempt to connect it to another computer. This can be a friend or family's computer and/or it can be taken to a service center.
  • Borrow a computer monitor and connect it to your computer. This will not harm the other computer monitor in any way.
If your monitor works on another computer it is safe to assume that the video card or potentially the motherboard within the computer is bad. Steps in troubleshooting a video card can be found on document CH001028.
If another monitor works on your computer it is safe to assume that your
Nov 27, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
No display
This issue can be caused by any of the below possibilities.
  1. Monitor is not on
  2. Computer is asleep
  3. Connections not connected properly.
  4. Monitor settings are not correct.
  5. No Post.
  6. Hardware issue.
Solution: The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on
Computer is asleep
No Post
Hardware Issue
Nov 26, 2010 | ASUS P4S333 Motherboard
My monitor is plugged in and everything but it won't display
  5. No Post.
  6. Hardware issue.
Solution:The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on
Computer is asleep
No Post
Hardware Issue
If another monitor works on your computer it is safe to assume that your monitor is bad.
PLEASE ACCEPT IF YOU SATISFAID
Nov 14, 2010 | Samsung 932BW Monitor
Microsoft Keyboard (1045) doesn't work with new Samsung Monitor
Hi
Keyboard and mouse have no connection with Monitor
Since keyboard and all are linked with mother board
so firstly i suggest you yo check the wireless connections are ok
Now reinstall the software packages that came with the keyboard(And drivers)
i hope this will help you
Mar 23, 2009 | Microsoft Wireless Notebook Optical Mouse...
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
Flatscreen monitor
Monitor is not on Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
Connections not connected properly Make sure that you are connecting the monitor to the back of the computer in the 15 pin (illustrated below) or older computer 9 pin connection.
video.gif If the computer is properly plugged in, make sure it's getting getting power.
Monitor settings are not correct Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibility.
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting .
Hope this works for ya/ Please dont for get to Vote.Thank You
Jul 18, 2008 | Dell Dimension 4600 PC Desktop
Hyundai monitor connects two computers .how do i switch between them?
Use a KVM (keyboard,video, mouse) switch to connect your 2 computers to this monitor. Then you can also have only one keyboard and one mouse. Connecting to the VGA header with one computer and the digital with another is probably not a good idea and the only way that can work is if your monitor has a built in video switch that can be controlled with software. If that is the case they would boast about it in the user manual and tell you how to activate the switch. VGA KVM switches are relatively in-expensive. Some high end KVM switches will exceed the cost of your monitor.
Jan 18, 2008 | Hyundai L90D+ 19" LCD Monitor
Televison & Video Logo
18 people viewed this question
Top Compaq Televison & Video Experts
Marvin
Marvin
Are you a Compaq Televison and Video Expert? Answer questions, earn points and help others
