Question about Dacor 52'' Builtin Outdoor Grill Cover OVCB52
I have a dacor bbq in an island. Today we had very heavy rain. With that said, the lighter was on and making the typical clicking noises. I made sure that the gas was not on. Finally, I turned on the gas. Everything lit properly. The lighter and clicking stopped. However, the moment I turned off the gas the lighter and its clicking noises resumed. Any ideas? Thanks in advance.
    Brigadier General:
  • 4,736 Answers
The really odd thing about this, is one shouldn't affect the other. So, I suspect that some moisture got into the ignitor button or module during the heavy rain and is causing the ignitor to button/switch to make contact when it shouldn't. Dismantle the ignitor button, remove the battery and check for moisture. Even if you don't see any, use a Q Tip lightly sprayed with WD40 to clean the interior. The WD40 will dissipate any moisture and help to lubricate the contacts.Then check all the wiring from the module to the burner ignitors to make sure they are not grounding out on something that the wires shouldn't be touching.
Hope this helps to solve your problem.
Posted on Mar 21, 2011
'97 Maxima Windshield wiper problems
Check to make sure your fuse is set all the way down first. Could be a bad ground too. Check the wiring at the wiper motor and maybe clean the ground and terminals with either alcohol or electric cleaner and make sure the are dry before you plug it back in. It sounds like a power to the wiper motor issue. If that doesn't fix it your wiper motor may have an internal short.
Feb 12, 2018 | 1997 Nissan Maxima
I have a steady island with butcher block on top and it seems very heavy, can I pot wheels on it and turn it into a huge cart?
Sound s like a pretty hard task. I'm a greatbeliever in wheels and I think that you can wheel anything these days (theyhave to match the weight of the piece). Today there are whole kitchens withwheels. However, these kitchens are usually made out of light aluminum orlighter type of wood and not butcher blocks. In any event, I would have anexpert come over, like a carpenter or even someone from the store you boughtthis island and ask them if this is doable.
May 30, 2012 | Furniture
Are there kitchen islands that also have cart wheels?
Yes, there are few, but bear in mind that an island is a heavy piece of furniture to move and if it has kitchet appliances on top of it is even heavier so it is recommended to hardly move it. You may also consider getting an island without wheels and have a handy man or a carpenter put on the wheels for you, but you have to make sure that they match the size of the island and its weight.
Try this link: http://www.allkitchencarts.com/Crosley-KF30004ECH-CRY1351.html
Oven will not ignite
Make sure line is bled of air, make sure air in kitchen is free of gas, make sure ignitor is
sparking, if not light manually with BBQ lighter
Dec 18, 2010 | Siemens HG2415UC Stainless Steel Gas...
CTS-V: Drive shaft "whip" or bad vibration in heavy rain.
Sorry I don't have a solution, just adding that you're not alone...
I just bought my '05 CTS-V on 8/31/09 and today (9/4/09) was the first time I've driven it in the rain. When I hit hard rain it sounded as if the tranny or rearend was going to fall off. I thought I had thrown an axle being or jacked up the tranny/rearend gears or something. The sound quieted down as I left the heavy stuff and then totally disappeared when I got to a dry area. One person said it was probably water hitting the undercarriage or wheel-well, but this was more than that. This sound was louder tan that and is not normal splashing water. If this noise was common, there'd be a heck of a lot more CTS owner complaining about it. I've never heard such a noise in any car I've ever been in when driving in the rain. I'd love to know what it was. I'm not even sure how to show or explain the problem to the dealership in order to get it fixed
Aug 18, 2009 | 2003 Cadillac CTS
The weight of the arm and rain head is too heavy for fixing
can you at all shorten the length of the arm to make the head lighter or can you do the adjustment near the tiles up tighter apart from this attach unsightly bracket from the head back to the wall at worst mate start pulling tiles off ouch ! wish i could more help glenn..
Nov 20, 2008 | Grohe 27.217.EN0 Rainshower 6" Ceiling...
Need a Manual for Turbo STS Elite 4 burner BBQ - HELP!
if you havent already done it call bbq galore 214 696 0030
Sep 08, 2008 | Barbeques Galore Turbo Elite 4-Burner with...
Oven Striker
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Oct 12, 2006 | Dacor Preference SGM466SS Gas Cooktop
Dacor 52'' Builtin Outdoor Grill Cover OVCB52 Logo
228 people viewed this question
Top Dacor Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Dacor Grilling Expert? Answer questions, earn points and help others
