Question about Dryers
Broken belt who has parts and how do i access motor
  • Dryers Master
  • 43,501 Answers
Hi,Exploded views are often on the repair parts sites...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommendhttp://ping.fm/zJDAM
heatman101
Posted on Sep 17, 2011
Lg 6.5 fuzzy logic no spin but still drains
could be belt broken or slipping internally. if you hear the electric motor still running, you may have broken belt. not sure what type washer you have. most of them have scews fastened the body or access panel behind. if the belt drive is broken best get the part number for your washer model and see if you can get one order thru the appliance's store or online. made sure you get the correct information or you will have too short or too large belt.
Mar 02, 2015 | LG Washing Machines
Changer states checking disk, error
Possible broken drive belt, that's what caused the same error on my unit. Very easy to replace, just take off the top cover and the motor and belt are readily accessible.
Feb 03, 2014 | Technics SL-MC700 110-Disc CD Changer
Rotor does not turn on 91 geo prizm when engine is turned over
is the camshaft turning take of the rotor and se is the shaft of the distributor turning
Dec 27, 2010 | 1991 Geo Prizm
My washer tub nor the agitator spin or rotate you can hear a whining n grinding noise
whining and grinding most likely mean belt or coupler is binding or broken away unplug unit and open access panel or [remove water first]lay on side and access motor from bottom if belt driven check belt if frayed or broken replace-if has coupler [looks like a star shaped hard rubber /plastic piece between motor and trans] if broken pieces on floor or shredded replace- part's can be bought online-appliance stores coupler not expensive and both parts easy replacement good luck
Nov 08, 2010 | Washing Machines
Changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Jul 25, 2010 | Roper RTW4100SQ Top Load Washer
The drum of my washer does not spin freely. When I manually spin the drum, I found myself having to push it along to turn on one side. Also I found pieces of white plastic on my laundry? Please advise...
This drum is driven by motor which is coupled with a belt that connects the drum and the motor,the is a possibility of a broken belt,or the motor is stack, may be the motor is not receiving power for the motor to be driven to drive the drum.
To access this you need to open the screws at the back of the washer,the plastic pieces is a sign of some broken parts in the washer,if you find that it's the belt that slept off the puller place it back and test but unplug the washer from power before doing all this.
May 18, 2010 | Whirlpool GHW9100L Front Load Washer
The power bar stopped working. The vaccume is
If its 2 months old I wouldnt stress looking at anything. Box it up and take it back. Something that flimsy doesnt make sense to keep does it?
Apr 29, 2010 | Hoover S3765-040 WindTunnel Bagless...
Dryer heats but drum will not turn
the drum belt is more than likely broken. To access this area you will need to remove the back panel of the drier and there the motor and the belt assembly is. Take the model and serial number to an appliance part house for the correct replacement.
Hope this helped
Dave
Mar 01, 2010 | Dryers
Why won't the Kenmore top loading washing machine agitate?
There are two types of Kenmore top loading washing machines. The direct drive models and the belt drive models. Direct drive models do not have a back access panel and the water inlet valve is located on the left side viewed from the rear while belt drive models do have back access panel and the water inlet valve is located on the right side viewed from the rear.
The most common problem causing a top loading machine not to agitate, particularly when the motor seems running, is a broken motor coupler for direct drive models and a broken or worn out drive belt for belt drive models.
The best way to exactly determine the cause is to access the drive motor. Open the back access panel for belt drive models and check the drive belt. Check the drive motor if it is running, humming or stuck.
Please indicate the model number of the washing machine if it is a direct drive model for the procedure in accessing drive motor.
Jan 15, 2010 | Washing Machines
Roper dryer not working
If the drum will not rotate, look for a broken belt or even possibly a faulty motor. If it is a belt, it should be relatively cheap to repair and possibly easy for you to aquire the specs on the breakdown of the dryer to access the belt for installation. If the belt isn't broken, then the motor is possibly shot and I am unsure of how much ROPER parts are. Be model number and serial number SPECIFIC when ordering parts, and don't go with the "SUGGESTED MATCH" just to save money if you can avoid it, they aren't always compatible.
Mar 14, 2008 | Roper RES7646KQ Electric Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
