Question about Dryers
I have an estate gas dryer and am unable to light the pilot; please help!
  • 122 Answers
An estate dryer would not normally have a standing pilot. It has an electric glow type of ignition. If you're not getting any heat it is most likely the thermal fuse located in the back of the dryer by the outlet. Hope this helps
Posted on Mar 21, 2011
Can not get pilot to light on estate by whirlpool gas dryer
The pilot will only turn on for a couple of seconds while the gas comes out to create the flame for the heat to do its job. The pilot is a ceramic fuse that will not stay on at all times. It will click as a sign that is activating (you should see a red glowing light) and ready for the gas/ propane to come out ( the flame will stay on approx. two to five minutes), then it will turn off . Repeating itself many times throughout the cycle. It this is not happening you might need to replace the fuse. Good luck
Nov 04, 2013 | Dryers
I have no heat with my whirlpool estates TGDS84OJQ1, read that it could be fuse or pilot. I need help to find where the thermol fuse and or pilot light is on my dryer. I am a diy guy and I dont want to...
sdfs77Hello and sorry to hear about your problem.
It sounds like your dryer glow rod, is defective. This is the electronic pilot lite for the unit.
I suggest you can in a service person. If you live in the Denver Co area, I can help you.
I have tried to help you. Please help me by Vote/Rate this response. Thanks and good luck.
Dec 22, 2010 | Estate TGDS840JQ Gas Dryer
How do you light the pilot light
http://www.applianceaid.com/gas_dryer.html#noheat
Nov 07, 2010 | Estate TGDX640JQ Gas Dryer
It has no heat when we turn it on we took it apart and we have no flame
you may need to light the pilot light at the valve going in to the dryer.If you have the owners manual it should tell you how to light it. Be careful it is not a hard thing to do but take caution and follow the steps correctly. If this has helped you don't forget to hit yes in the box and good luck friend!
Oct 09, 2010 | Estate TGDS840JQ Gas Dryer
HOW DO I LIGHT THE PILOT LIGHT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 15, 2010 | Estate TGDS740JQ Gas Dryer
Im trying to lite the pilet
This dryer has no pilot light. When you turn dryer on the igniter turns on and lights gas. If yours is not igniting, you could have a bad igniter or a bad heater cavity switch located behind back panel attached to dryer vent area, has two wires connected to it.
Jun 10, 2010 | Estate TGDX640JQ Gas Dryer
How do i light the pilot of my dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
May 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Hooking up my dryer
There is no pilot light on your dryer it sounds like you have a gas leak somewhere. Get a cup put alot of dish soap in it and a little bit of water and apply it to your fittings in the back. If you have a gas leak it will bubble up. If this is a used dryer you may have a damaged gas valve or another internal leak.
Jan 22, 2010 | Estate TGDS840JQ Gas Dryer
No puilot on.
U must rmove the whole front of the dryer to get to the pilot. Good luck.
Oct 17, 2008 | Estate TGDX640JQ Gas Dryer
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Dryers Logo
95 people viewed this question
Top Dryers Experts
Marvin
Marvin
