Question about Dometic RM2852 Refrigerator
It runs the battery down - Dometic RM2852 Refrigerator
  • 8,404 Answers
Does your frig have 110, Gas and 12 volt setting? ... or is it auto select?
This is the way they should work ... if there is 110 Volts, it should run on 110 volts. The device is still controlled by 12 volts but the heat source is electric. If there is no 110 volts, it should switch to gas as a heat source. Same deal with the control, runs on 12 volts. If there is no electric and no gas, it should select 12 volts for a heat source ... same deal with the control. Problem with 12 volt source for heat is it GOBBLES up the power in your battery.
How is your battery? Do a volt test on the battery and the charger. Charger should run about 14 volts. Battery should provide at least 11 volts. If it is such that you can measure the acid, a good reading is 1200. Your charger can provide only about 15 amps charging power. Your battery should be able to provide up to 110 amp/hours.
If you do have electric and gas, it may not be your frig that is killing the battery ...
Thanks for your quesiton @ FixYa.com
Posted on Mar 21, 2011
What happens when the runs down the battery
if the battery runs down you have to charge then test the battery. then check the charging system to find out what caused the battery to run down.
Aug 04, 2015 | Kia Cerato Cars & Trucks
1996 nissan primera battery keep running down
When the car is not running, something is consuming more electrical power than normal to run the battery down. Another problem could be that the battery is more than 5 or 6 years old and it is at the end of its useful life.
Mar 27, 2014 | 2004 Pontiac Montana
I have a problem with my laptop battery, my laptop will not work without charger connected to it, if not connected to charger it will shup down in 5 minutes
Definitely sounds like a bad battery. Don't know how old the battery is but they do run down and fail to hold a charge over time. This is especially true when the laptop never runs the battery down and is constantly running with the charger connected. Batteries need to "cycle" to maintain their ability to hold and accept a new charge. A new battery should solve your problem.
Oct 10, 2011 | Acer Computers & Internet
Going down the road runs great then starts loosing charge sit awhile and push off runs great. put new altenater on it i can reve motor up if running lights and starts running good
Either have a bad battery, sometimes they go bad and the symptom is a "self" discharge that will run it down in a few days..
or.
You have something inside the car that's running it down.
The way to check is to unhook the battery for the time that its down and see if the battery is dead when you return. If the battery goes flat unhooked, you have a bad battery. If the battey holds its charge while unhooked you have a drain from the car.
Your car I think was bad about one of the cooling fan relays sticking "on". Just something to be aware of.
Jun 06, 2011 | 1984 Porsche 944
THE BATTERY OF MY CELL RUNS OUT PRETTY QUIK
Hi, When a phones battery runs down, it is usually caused by too much time of charging battery and phone board that has a heating problem.
First, use another battery to test and see if the battery will not run down.
Secondly. if the battery still run out then the faulty is from the board.
For bard repairs, contact and expert technicians.
Take care.
Jun 15, 2010 | LG CHOCOLATE VX8500 Cellular Phone
Battery runs down. replaced alternator, starter
Replace battery also then use a multimeter at the fuse box to check for power drains to find the loss of power. A tune up may be in order if it runs poorly.
May 10, 2010 | 1992 Subaru Legacy
Battery runs down within a hour after giving an outgoing call.
this is a hardware problem form chip called "thavo" should be replaced
Apr 18, 2010 | Nokia 6630 Cellular Phone
Problems
Hi, i think the battery has completely run down, i suggest you get another battery and ensure you don't allow the new battery to completely run down before yo charge.
As`soon as it shows low battery, you try charge or shut down to save and give your battery long life span.
I wish best of luck
Jan 06, 2010 | ASUS Eee PC 900 Notebook
Car will not run with headlights on but will run
check the alternator an battery again, is seem leke the car is running on battery power, thats why is shuts down when the heavy drain lights comes on
Jul 18, 2009 | 1998 Chevrolet Prizm
Nokia n81 running a new battery down in 6-8 hours on standby mode
Even if the battery is new, if it is not charged properly it can run down pretty fast. To reset the battery I recommend running the battery all the way down - charging the battery all the way back up to full - and then repeat. Also, make sure you do not charge the battery after it is full. Most phones or charge units have signals to tell you when the battery is fully charged. Do not charge the battery overnight.
These are the best ways to protect the life of a battery.
Jul 30, 2008 | Cell Phones
Dometic RM2852 Refrigerator Logo
157 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
