Question about Wacom Graphire4 4x5
My Driver Won't Install
I've tried installing the driver for my wacom graphire4 multiple times, but every time it tells me the install failed due to 'preflight errors'. I run Macintosh OS X with an intel processor.
  • Anonymous Dec 28, 2008
    I have the same problem but the pen gets installed then it says that the mouse monitor failed, and it wont work. I use vista home prenium.
5 Suggested Answers
  • 3 Answers
SOURCE: Driver don´t work (MacOSX Leopard
Here are the steps that you need to take to fix your issue:
1. Uninstall the current Wacom driver via the Macintosh HD on your desktop--->go into the Applications folder and then the Pen Tablet folder and click on "remove tablet". Once you have done the removal you will want to run a "repair disk permissions on your Macintosh HD.
2. The repair disk permissions can be done via the utilities folder on your Mac HD. Go to "disk utility" and then run it. In that program select the Mac HD and choose "repair disk permissions".
3. After that is completed you will get a message that says permissions repair complete!
At this time you will want to reboot your computer.
4. After rebooting you will want to go and install the latest driver from Wacom's website, www.wacom.com The most current driver is 5.08-2 for the Graphire 3 tablet.
That should do it!
Paul
Posted on Nov 12, 2008
SOURCE: Wacom Tablet
http://www.wacom.com/productsupport/select.cfm
Posted on Nov 16, 2008
  • 5 Answers
SOURCE: graphire4 pen registers without touching pad
It's meant to. So you can move around the page without selcting anything.
Posted on Apr 07, 2010
SOURCE: Wacom CTE-440 Graphire4 tablet is drawing when I don't want it to
Ok so I called costumer service because mine was doing the same thing. Apparently the pressure sensor in the pen is stuck down. What you do is remove the pen tip with tweezers, blow in the open end of pen, then tap the pen (open end down) in a table to get any debris out of there. Then just put the tip back in and give it a try. That did the trick for me. Hope this helps.
Posted on Aug 24, 2010
  • 5 Answers
SOURCE: Wacom Bamboo Fun Error
i was just having the same issue. My tablet was working fine in Windows XP but couldn't install it in Windows 7. was getting the same error. Found the solution here ...hope it helps :)
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Posted on Dec 03, 2011
My Graphics Tablet Pen Keeps Clicking When I Hover It Over The Tablet Without Touching It, How Can I Fix It?
This sovled my issue using a Mac...
1. Download the latest driver from Wacom http://www.wacom.com/en/CustomerCare/Drivers.aspx
If you already have the pen tablet uninstaller utility, run it. In my case there was a Bamboo Fun folder with a Bamboo Utility inside the applications folder. If you cannot locate it, you need to run the installation of the new driver. Then go to said folder, open the utility, select All User and Remover preferences. THEN select "Remove pen tablet". You will essentially remove the driver you just installed.
Then RESTART your computer, and proceed to re-install the same driver. Issue should be solved.
If not, contact Wacom customer support. 800-922-6613
That fixed it for me. Hope it makes sense.
Jun 28, 2011 | Wacom Graphire4 4x5
When i try to install my wacom on my windows 7 inspiron, it says 'platform not supported'. how do i fix this?
You can also visit the following page and choose the tablet model and windows version you have and download drivers
http://www.wacom.com/downloads/drivers.php
for devices that are not supported by windows 7, microsoft has given an ingenious solution, its called windows XP mode
Please click on the link below to know more and download XP mode
http://www.microsoft.com/windows/virtual-pc/download.aspx
Once installed, then you can connect the wacom graphire and install XP drivers for the same and use it.
Feb 03, 2011 | Wacom Graphire4 4x5
Wacom Stylus not working on my DTZ1200. It shows that the pen is being red by the tablet but doesnt show the target from the pen point or be able to select from any selection in photoshop. Its and old...
you may have installed the driver for windows xp or a later version then windows 7, you will have to make sure you install the correct driver for you OS
Aug 16, 2010 | Wacom Stylus Pen for Graphire4
Wacom Graphire 4.40 Install question
Make sure you have no old Wacom drivers installed in your applications folder. If you do, then you will need to uninstall each driver via the "remove tablet" utility.
Oct 13, 2008 | Wacom Graphire4 Digital Pen
Graphire4 Vista
Vista doesn't support many things.. you need to see if you can find a driver for it or revert back to XP, or get a new graphics tablet
Jun 12, 2008 | Wacom Graphire3 Tablet 6x8 (C267252627)
That should do it!
Paul
May 02, 2008 | Wacom Graphire4 Digital Pen
Not work
It may have installed the driver but it wont work until you install the wacom tablet software (config program).
You will find this on your disk or.. http://www.wacom-europe.com/index2.asp?lang=en&pid=29 (UK site)
Wacom calls it a driver too but this is what you need to get it to work.. The windows must only detect that it is a human interface device or something.
Sep 08, 2007 | Wacom Graphire4 4x5
Wacom Graphire Installation
This means that the driver you have is NOT suitable for Vista. You will have to obtain one for ya Tablet. Try the link below. www.wacom-europe.com/uk/downloads/driver/driver.asp And a work arround in case it all get "mucky" lol www.geekzone.co.nz/content.asp?contentid=6790 G L.
Aug 11, 2007 | Wacom Graphire4 4x5
Tablet Issues
Could you tell me if you have tried removing the device from the Device Manager & rebooting? Are you using Vista or XP ?
May 19, 2007 | Wacom Graphire4 4x5
Wacom Graphire4 4x5 Logo
78 people viewed this question
Top Wacom Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
