Question about Canon PIXMA iP90v Printer
My printer has come up with a service error 5c00. What can i do to fix it?
  • 2,296 Answers
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30.
Posted on Mar 21, 2011
CANON MG8100 series error 5C00
Per http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5c00
5C00 - Orange and green blinking 4 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
May 27, 2014 | Canon PIXMA iP3500 Printer
When i turn the printer on it tells me error code 5c00
Hi andrew_webb0,
The error code 5C00 means the purge unit is broken. To fix this, you have to bring the printer to a Canon service center and need to replace it with new one.
Hope this helps.
Feb 23, 2011 | Canon PIXMA MP510 All-In-One InkJet...
5c00
Error code 5C00 means purge unit is broken. To fix this problem you have to bring the printer to the service center and need to replace it with new one. I hope this brief explanation help you. Thanks
Find more printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Error code 5C00
Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
May 15, 2009 | Canon I900D InkJet Photo Printer
Canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Apr 01, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Canon ip3000 shows service error 5c00
5C00 is Purge unit error.Check for object around the purge unit.
Feb 23, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 5C00? what's that?
Service error 5C00 is a purge unit error. The purge unit like a spitoon to the printhead where is stops. There is a sensor in the purge unit; when it is blocked (usually by ink build up), that error is given. The error indicates that the purge unit may be full or at least gunked up. It may be possible to clean the purge unit and sensor to make the error go away. I base this on information learned with experience on another Canon product (Model i560). Hope this helps...
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Error code problem
Unplug printer. Press and hold power button for about 15 seconds. 5C00 is a hardware service code. Meaning there is an EEPROM error on the printer systemboard. Which may need to be replacing by a certified techinican.
Jun 23, 2007 | Canon SELPHY DS810 InkJet Photo Printer
Canon PIXMA  iP90v Printer Logo
383 people viewed this question
old marine
old marine
