John Deere 544H starts up and runs great for all of 30 min and then just dies. You can restart it but it will only run for a matter of seconds, Sounds like it is missing occasionally also. There is 1/2 tank of fuel, and new fuel filters. The fuel is new. I think the injection pump/ fuel solenoid on the pump is failing. Is there any good way to confirm other than just replacing???
morse008
  • 1111 Answers
SOURCE: 1995 GMC Sierra 5.7 liter stalls and is hard
even though parts are new they also come with defects so it sounds as if when you turn the key you hear it working and other times not at all hmmm connections are tight ? could be faulty fuel pump or relay .
Posted on Aug 24, 2009
  • 17 Answers
SOURCE: 1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Posted on Nov 17, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
goldenglove1
  • 144 Answers
SOURCE: 22 In Craftsman Self propelled.Starts
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Posted on Aug 05, 2010
SOURCE: J Deere LX277 has stopped.
I don't have a John Deere. Had a Wheel Horse once; same problem. There is a transmission switch in back beside the right rear wheel; slides in and out. MAYBE this helps!
Posted on Mar 21, 2011
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
John deere 997
does it slowly die it overheating need valve job done on it also check for water in gas tank to im betting valve job 100.00 per cylinder
Sep 03, 2014 | Garden
John deere 420
Ignition switch could be at fault
Jul 09, 2017 | Garden
Electrical problem on a john deere 420 lawn tractor
remove the upper engine cover and inspect for a build up of grass and or a mouse nest that would over heat the coil and the engine
Jun 19, 2012 | John Deere 420,1020,2010,2020,2510,2520...
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Oct 02, 2009 | Garden
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
