Question about Panasonic SC-HT670 System
I turned on my home theater sc-ht670, and the display shows "hello", "init ", "please" and finally "wait" and nothing happens and be left with the word "wait" and will not let me play no video and sound, I had passed this situation and solved it with the manual in the box, but now neither the manual solves this problem, what I can do?
    Problem Solver:
  • 6 Answers
Basic steps to check if the problem lies with the home theatre system or not.
1. First thought might be to conclude that your poor audio quality is caused by your speakers, before you immediately race out to purchase a new home theater surround sound speaker package, check the basic things first.
2. The problem might not be in the speakers, but in the amplifier or the connections from the amplifier. Checking and ensuring that the speakers are correctly connected on both ends is the first step.
3. After the connections pass examination, the next step is to check if the problem lies with the amplifier or audio speaker. Some of the lower end home theater systems come with low powered amps. Most often they do not supply sufficient power to speakers to produce the quality audio you desire. This may show up particularly if the room is large when the sound doesn't fill up the room.
4. To determine if it is indeed the amplifiers then hook up your speakers to a stereo; this generally will have a more powerful amp. If the speaker quality improves then the problem probably lies in your home theater amplifier.
If you cannot distinguish any difference, then your speakers could possibly be at fault.
5. Poor cable installation and audio speaker cable are another possible cause for consideration. Cheap workmanship can lower audio quality and home theater packages often come equipped with inexpensive poor quality cables.
6. If you experience problems with your theater system, it is always best to assume the problem lies in the connections between components first and then suspect the components themselves.
7. To ensure a great sound experience ensures that everything is properly connected, your amp is of sufficient power, and the cables are of high quality. If a person makes use of these basic easy precautions a significant amount of frustration can be eliminated. If your home theater sound isn't where you need it to be, use those hints as a blueprint as you analyze your system. If it really is time to look for new components, consider those directives as you make your next purchase.
Note : Check to see if the color is bad across all input sources. If so, make sure you have your Televisions' color settings set to your preferences. If everything looks good except, say, your DVD player, and it is connected to your TV via Component Video Connections (which is composed of three cables - Red, Green, and Blue), make sure they are matched up correctly with the Component (Red, Green, and Blue) connections on your TV. This is a common mistake as it is sometimes hard to distinguish the Green and Blue connectors if the lighting in the connection area is dim.
Posted on Mar 22, 2011
My system says INIT please wait and the cd/ dvd trays are out of line i tinkle a little with electronics and feel that if i knew a little more about this problem I can fix it myself,especially due to high...
  • First you to pull out the DVD tray assembly and check to make sure there is not anything that has broke inside there. Make sure nothing is blocking the trays from moving.
  • Now pull the side cover off. There is a spare gear on the top of the DVD tray assembly. You will take that and place it in the two holes at the bottom of the player. This will allow you to manually adjust the trays. If you don't have this gear you can align the tray manually but it has to be real perfect.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 26, 2011 | Panasonic SC-HT670 System
My dvd player is dead on my sa ht670 panasonic dvd player home theater. Is there any way to still use the other functions like aux? i do no need the dvd player just want to use the theater for sound. I...
Maybe if you ask it to OPEN the tray as soon as you turn it on and leave it that way it might move on to other functions. A hands-on tech would have to lay hands and eyes on it otherwise.
Jul 04, 2011 | Panasonic SC-HT670 System
SA-HT730 need help with the above problem it just shows INIT and nothing else happens
Are you trying to reset the password for Ratings or re-initialize the unit to all factory defaults?
http://www.retrevo.com/support/Panasonic-SC-HT730-Home-Theater-Systems-manual/id/356ci961/t/2/
Page 27 shows one instance of INIT.
Re-initialize Setting
This returns all values in the Setup menus to the default settings.
≥Yes: The password screen is shown if "Ratings" (??? page 26) is set. Please enter the same password. After "INIT" on the display disappears, turn the unit off and on again.
≥No
Page 36 shows how to reset everything.
You have forgotten your ratings password. Reset all the settings to Factory Preset.
While stopped and "DVD/CD" is the source, press and hold ['Square Icon' button for STOP] on the main unit and [S10] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Jan 13, 2011 | Panasonic SC-HT730 System
I am having problems with my SA-HT670 it is reading error code INIT and then WAIT. The 5 disc changer will no open and close properly
The CD loading mechanism is not resetting properly. When powered on, the entire mechanism goes through a startup alignment sequence. This is to be sure that the unit is in a known position and state. The init indication is for the "electonics" reset portion, the wait message should be present while you hear the mechanism move. The most common cause of this is a slipping belt or a jammed CD. Be cautious about trying to repair this yourself. It is easy to damage the gearing inside or to get it out of aligment. There is a good possibility that this can be repaired with either no parts or with a $3-$5 belt.
Dan
Nov 02, 2010 | Panasonic SC-HT670 System
How do I align the trays on my Panasonic SC-HT670?
no esta en sincronismo nesecito el diagrama de los engranajes para sincronisarlos
Jul 02, 2009 | Panasonic SC-HT670 System
Says wait, won't play dvd's at all
Yes you are right, this will happen only when tray mechanism is not working at that time lense will try to read but it will be still under wait condition,
to resolve your issue you need to replace entire tray with lense set to work properly.
Mar 29, 2009 | Panasonic SC-HT670 System
Unit says Init Please Wait
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Oct 31, 2007 | Panasonic SC-HT670 System
Panasonic SC-HT670
Sep 24, 2007 | Panasonic SC-HT670 System
Init please wait
I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
Sep 01, 2007 | Panasonic SC-HT670 System
Panasonic SC-HT670 System Logo
158 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
