Question about Marshall Amplification Marshall Mg Series 10 Cd
I have the old 3520 200w SS head. It is blowing the fuse as soon as I power up. No one around here (south of Dallas, TX) know anything about this amp. I am using the Marshall 1553 cab w/ one 15" and 2 10" speakers. Any suggestions?
  • Marshall Amp... Master
  • 5,603 Answers
Here is a link to your schematic:
http://elektrotanya.com/marshall_bass_200w_3520.pdf/download.html
Scroll way down and click on "Get Manual" link. They will only let you download two a day unless you are registered.
Suggestion is to troubleshoot and repair the unit.
You will likely find one of the following:
Shorted transistors in output TR5 through TR10
Shorted rectifier diode(s)
Shorted fillter capacitor
Shorted power transformer (not very likely)
Posted on Mar 21, 2011
Why would my iron heart Lainey 212 combo amp combo be blowing fuses?
Because some component in the amp is failing/failed and drawing too much current. The amp needs a repair shop. Poking around without knowing what you're doing can expose you to leather voltage. Don't do it.
Oct 13, 2016 | Laney IRT60H Ironheart Guitar Amplifier...
Amp keeps blowing fuses
Blowing fuses, was caused by many thing.
Short of rectifier,resistor,elco,tube heater,tube pin, and also trafo itself (primary or secondary winding). It must check step by step.
CAUTION :
THIS IS HIGH VOLTAGE AREA.
RISK OF ELECTRIC SHOCK THAT CAN KILL.
DON'T DO THIS IF YOU ARE NOT TECHNICIAN OR NOT FAMILIAR WITH VACUM TUBE CIRCUIT. THE CIRCUIT MAY STILL CONTAINS ELECTRIC SHOCK EVEN IF IF THE AMP IS NOT POWER PLUGGED.
The simple steps (see picture) are:
  1. Disconnect all connection from secondary of power trafo (PLV,PDCH,PACH and PHV).
    Power ON the amp. If fuse is not blowing,trafo is good.
  2. Power OFF the amp. Unplug the cord.
    Connect PLV1-PLV2-PLV3 (this are Bias voltage,+/-15VDC and Backlight PCB voltage) to power trafo.Power ON the amp. If fuse is not blowing,PLV circuit is good.If fuse blowing,there are parts is damage (dioda,elco,7815/7915,resistor) in this PLV circuit.
  3. If step 2 is good,go to next step.
    With PLV circuit stay connected,connect PDCH 1-2 and PACH 1-2 to power trafo. Power ON the amp.
    If fuse is not blowing,PDCH and PACH circuit is good and all tubes heater/filaments are lights after a few seconds.
    If fuse blowing,there are parts is damage (dioda,elco,tube heater pins) in this PDCH/PACH circuit.
  4. If step 3 is good,go to next step.
    With PLV,PDCH,PACH circuit stay connected,connect PHV 1-2 to power trafo.
    Power ON the amp. CAUTION: HIGH VOLTAGE AREA is ON.
    If fuse is not blowing,PHV circuit is good.
    If fuse blowing,there are parts is damage (dioda,elco,tube pins) in this PHV circuit.
Notes:
  • Steps had to be done sequentially from 1 to 4, not upside down.
  • If tube/heater pin is short,it can't be repair. The tube must be replacing.
  • PDCH circuit is voltage for V1-2-3-4 heater/filaments.
  • PACH circuit is voltage for V5-6-7 heater/filaments.
  • Always replace fuse with same type.
Oct 02, 2015 | Peavey 6505 Plus 120W Guitar Amp Head
Crate power head replace fuse how to /
did it blow a fuse or is it just dead?
Aug 02, 2014 | Crate Music
Why my Marshall amplifier immediately blows fuses?
It could be a failed power supply capacitor, it could be a shorted speaker, it could be a shorted cable. It might also be a conductive piece of trash in just the wrong spot on the circuit. They would be the big ones of about 5000 microfarad give or take a few hundred microfarads.
Though a little less likely, there could be a short of failed component in the output stage.of the amp.
Sep 25, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
My Fender LX1506 powered mixer keep blowing the fuse as soon as i turn it on what is the problem?
There is a direct short somewhere. Is the fuse the right size amps? volts? You dont want to put an dc fuse in an ac power amp. Double check your fuses.
Apr 11, 2012 | Fender Music
Still Blowing fuses
there could be something wrong with moisture. I had a drink spilled down the back of mine and I had to clean the board cause it kept blowing fuses.
Aug 18, 2017 | JBL EON 515
Hello...I am an owner of the Fender Passport PD-500 Sound System
Replace the fuse only once. If it blows right away, then servicing is required as continued replacement will likely damage more inside.
Most of thes have a fuse holder that is a part of the input power socket. There is a little rectangular panel adjacent where the cord connects with a tab that you gently pry out and carries a small fuse. Replace the fuse and re-install the carrier.
These units are very hard to work on due to packaging.
May 30, 2010 | Fender Passport Deluxe 500watt Sound...
Blown fuse
Continued replacement of fuses without fixing the reason for them blowing MAY be doing additional damage to components in the unit.
It needs to go to a repair shop. It is likely there is damage in the power supply section or that of the power amplifier section.
Feb 28, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a KRK Rokit Powered 5 studio monitor and the fuse blew out, so i replace the fuse with the spare they provide and ''bam'' blows again as soon as i turn on the monitor. i have had these for about 4...
Look for a failure in the power supply section. You will need electronic experience or someone who has that.
If the fuse is glass and blows silvery inside thia means a direct short inside. SUSPECT the input rectifier or filter capacitor(s).
Do testing with a 100 watt light bulb in series with the hot side of the power cord to avoid blowing fuses.
Oct 10, 2009 | Music
Blows main fuse. Found burnt place on circuit board where connection 1 is. It's the board that's mounted to the heat sink with fan at the back. Disconnected connector 3 that goes to con 1. Now fuse does...
Chances are a power transistor has shorted. Sometimes input rectifier diodes short or electrolytic caps.
Here is a hint to troubleshoot this: Connect a 150 watt lamp in series with the hot side of the power line to the amp. This will limit the current (and voltage) and prevent the fuse from blowing. You can do a lot of troubleshooting at the much reduced voltage.
If board is burnt to carbon, this "cancer" needs to be cut out and removed as the blackened board is slightly conducive instead of an insulator. Often a circuit trace has fried the board. One must install jumpers around ones that have smoked.
Sep 24, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall Amplification Marshall Mg Series 10 Cd Logo
135 people viewed this question
Top Marshall Amplification Music Experts
Michial Gueffroy
matt martin
matt martin
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
