Question about Dishwashers
Gianni dishwasher won't drain or restart lights are on
  • 2 more comments
  • ctrades Mar 21, 2011
    Hi Rick
    Will try this as I am a plumber I have plunged it already with no result.
    The END light stays on when the machine is reset so it won't start a new cycle
    Thanks Ctrades
    Gianni Dishwasher has water still in the bottom of machine it is not blocked & it won't reset to start again on a new ccycle lights are stiil on end & rince aid
  • ctrades Mar 28, 2011
    The best solution was to dump the made in china dishwasher & upgrade to a Bosh brand.
    Thanks
    To the dump its the control
  • 17,130 Answers
Possible fault in the program controller unit. It must be confirmed with a test on the drain valve/pump. If there is no power to the drain pump/valve at the time of cycle , then the program is not outputting and the fault is in the main controller unit.
However if there is power to the drain but without the drain valve/pump working to open out then the drain unit must be taken out, externally cleaned , backflushed and tested. If not the valve is faulty and needs a change.
Posted on Mar 21, 2011
  • 1,998 Answers
There are a couple things you can check due to the unit not draining first shut off the water supply going to your unit and check the drain hose and disconnect it from the sink or garbage disposal where it ties into the pipe assure that there is no crud blocking the exit port of the hose that goes to the drain. the following parts you would need to de-install your unit and pull it out from under the counter you would next check to assure that the drain pump is not clogged and it is working properly as well it is possible to pull the drain pump out and using a powered jumper wire do a bench test to assure that the impellar is spinning properly some models also have a drain solenoid like on the ge versions this gives power to the pump as well if yours does have a solenoid try to free the solenoid from what ever is jamming it message me back your model number as well and i may be able to locate some further information on your unit I do fix alot of american type of dishwashers as well as european and others types like fagor as well. If you have any further questions message me back those as well and please remember to rank how this opinion has helped it allows for me to help others in similar situations Thanks Rick
p.s also how many lights are on and if they are on are they flashing and if so how long in between each flash this usually distinguishes what the error code is on your unit by the flashing lights which would also point you directly to the actual problem rather then testing the whole unit Thanks again Rick
  • 4 more comments
  • Rick Ead
    Rick Ead Mar 21, 2011
    ok if you still have water left in the bottom and the drain hose is cleaned and you have assured that the drain pump works as well the next thing that you would check due to you still haveing water in the bottom would be the float switch and on some units they also have a flow meter as well the float switch is pretty much like it says looks kinna like a hockey puck and rises and sinks depending on how much water you have inside your machine when it gets to a certain level it turns on the drain or when it gets to that cycle it also turns on the drain so the unit drains the water out going to go look at a couple more things on possibilities Thanks Rick
  • Rick Ead
    also what is the model number and please do not rank our chat yet it has not concluded in full and i try to achieve the maximum in all my chats Thanks Rick
  • Rick Ead
    there is also a thermo cut off fuse located in between the door panels sometimes taking this off and reinsterting it solves the matter as well if you do choose to take it off perform a continuity test on the thermal cut off fuse to assure that it is working properly I am unable to look up your unit without the model number so message me back when you have the model number and i might be able to actually find the problem and not just go of past experience of some things that can cause these issues Thanks Rick
    p.s I am assuming that you have bench tested the drain pump and the pump is working properly outside the machine correct ?
  • Rick Ead
    still awaiting the model number bud if i dont receive it from you tonight I will check again tomorrow Thanks Rick
  • Rick Ead
    Rick Ead Mar 24, 2011
    hello still awaiting your reply I try to achieve 100 percent customer satisfaction on all my chats Thanks again rick
  • Rick Ead
    Rick Ead Mar 28, 2011
    you think you have came out of the woods but bosch models have problems as well good luck with your new unit Thanks again and god bless
    Rick
2 Suggested Answers
ezdoesit2
  • 40 Answers
SOURCE: Gianni Dishwasher won't drain or restart
I had the same problem less than a year ago. This should help you troubleshoot the problem: http://www.associatedcontent.com/article/818791/got_a_dishwasher_that_wont_drain_heres.html?cat=6
Thanks and good luck!
Belling dishwasher won't empty. I have cleaned the water filter and the machine worked fine this evening it won't empty?
Search Results
    Belling won t drain Dishwashers Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > won t drain > Dishwashers
    Belling dishwashers won t drain related questions and answers. Ask your Belling questions. Get free help from dishwasher experts.
    How to fix a dishwasher that won't drain - Dishwashers ...
    www.which.co.uk/.../dishwashers/.../how-to-fix-a-dishwasher-tha...
    Which?A dishwasher that doesn't drain can cause concern in your kitchen, but you may not ... Check out our video to see how to repair a dishwasher that won't drain.
    i have belling dishwaher which is not emptying e1 showing as
    www.justanswer.co.uk > Appliance
    OK, so it fills and starts the cycle and then won't drain and this error will flash ... is ... the washing machine which is at the side of the dishwasher has been giving ...
    How to Fix a Dishwasher That Will Not Drain - YouTube
    ? 2:13
    https://www.youtube.com/watch?v=nr6tIO5iNSc
Feb 08, 2016 | Belling 24 in. IDW603 Built-in Dishwasher
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
My Miele dishwasher has the red drain light on and won't drain
most common, debris stuck in the drain pump. remove the triple filter, remove the non return valve. clear the debris from the drain pump impeller. try to drain again. also make sure you dont have an obstruction in the drain line. if you replaced your garbage disposal recently, make sure they knocked out the drain plug when they connected the dishwasher. also make sure your dishwasher drain line connects directly to the disposal, and does not run to a air gap in your countertop. miele dishwashers will not function properly when connected to an air gap.
Mar 23, 2012 | Miele Dishwashers
Bosh washer won't stop? model SGS45C02
major recall of bosch dishwashers. recommend you check the list. https://www.consumerreports.org/dishwashers/maker-bosch-expands-dishwasher-recall/
Jan 01, 2018 | Bosch SGS45C02 Dishwasher
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Dishwasher intake/drain light is on, removed and cleaned intake valve, no obstructions. Tripped the breaker to the power supply to no avail....any suggestions?
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Aug 27, 2011 | Miele Touchtronic G894 SC Built-In...
Does not start cycle just hums gianni dishwasher
sounds like it is not getting water or a solenoid is stuck or broken.
Aug 22, 2011 | Zanussi 24 in. LS6E Free-standing...
Gianni Dishwasher won't switch into cycle and just hums.
I have found out that it seems to be the drainage pump, have real problem finding a new one.
Jun 03, 2009 | Zanussi 24 in. LS6E Free-standing...
Dishwashers Logo
475 people viewed this question
Top Dishwashers Experts
