Question about Dryers
Clothes comming out grey and has a soot like stuff on door and inside drum that we cleaned off with carpet cleaner. Cleaned out lint from under link catcher and it was very black.. How do I clean all of the dryer to stop this?
  • 3,018 Answers
Sounds to me like that lint is just about to catch fire good. To clean the dryer itself unplug it and from the backside remove the back off of it. Should be 4 maybe 6 5/16" bolts you can remove with a nut driver. Some have the option for a flathead screwdriver. Now clean the duck ways inside the dryer. Now we need to make sure that this was not an even bigger issue. So once you get the dryer back together, and before you hook the vent hose up to it, plug it in and make sure you get plenty of air flow out that vent on the back. If you do the the dryer is cleared. Also check the ventilation tract in the home itself. This gets plugged from time to time and could have led to the dryer also being so plugged. You can either have a duct cleaning service come check and/or clean it out or if you can find where the vent exit on the outside of your home is. Take a high powered air compressor and put an air gun adapter on it and charge the compressor. Wear proper eye protection and, from the outside, blow that air passage clear. It will make a mess but this is what the duct cleaning service will do when they come out so if you can do this you will save some good money. That black is a sign of that lint catching some real intense heat. I would recommend you take care of this before you dry anymore. I would hate to see a place burn down from the dryer catching fire and it has happened.
Posted on Mar 21, 2011
In the last week black marks have appeared all over the inside of the drum on my Maytag centennial dryer, Do you know why this would happen and what to do about it/
Since you did not post the model information, it is hard to say without a better description. If the marks appear to be ash or soot, the drier intake has not been cleaned, it needs to be cleaned about every 6 months. The drier is taking in air with lint because it is not clean, the lint is burning and then getting on the drum.
Apr 11, 2018 | Maytag Dryers
Maytag dryer clothes gray soot around the drum and door
Sounds like drum belt is out of alignment and rubbing. Check the rotation/alignment with pulleys and drum. If belt is worn replace it. Hope this helps.
Feb 17, 2014 | Dryers
Lg wd 1049c
There are cleaners you can get at the grocery store in the laundry soap section.
Jan 23, 2014 | Washing Machines
Crumbly black flecks in dryer, on clothes
first off get a new lint filter part number WE18X53 and it's around 20 to 30 dollars depending on where you buy it,now when you say you cleaned the dryer do you mean you cleaned just where the clothes go into or did you unplug it and take it apart and clean it out?if you look at the inside back wall you'll see holes,on g.e. dryers lint builds up behind the drum and the heat shield,you can try vacumming the lint out of the holes but the best way is to pull the drum,clean the back of the drum out where i was just telling you about,vacing out the cabinet where the motor is and then blow off the motor and cabinet with the shop vac the other side of it blows air and clean out the duct where the lint filter is and clean out the door,then blow out the vent line,if the line is long you can remove it from the dryer and blow it out with a leaf blower,it sounds like the dryer never has had a clean out,i know you most likely will have to call some one in to do this but for now with a shop vac set it up to blow,remove the lint filter and blow all the lint out of the duct,blow it for a few seconds the vac up the lint and do it again until it's clean,then vac the back of the drum,if you put a light in the drum you can see the lint through the holes,you can try blowing through the holes to lossen the lint and then vac it out and see if that helps but the dryer has to be taken apart and cleaned so you don't have a fire,this should be done at least once a year if it's gas and once every 1 1/2 to 2 years if electric,this way your clothes will dry on time and mostly so you don't have a fire. also when it's pulled apart you can check all the parts to make sure nothing has to be changed out like the rear bearing and rollers and pulley,also check the heater to make sure it's not sagging after a while on electric dryers the heater coils can sag down and short out,when you have it apart you can tighten them up and bend them up into shape again,hope this helps and good luck with your machine.
Sep 08, 2012 | GE Dryers
Clothes dryer produces black soot when drying and leaves clothes darkened
lint build up is on heat element canister. take dryer apart on clean with a good vacumm cleaner. unplug first.
Mar 02, 2010 | Dryers
Black color left in dryer, cant clean
As a mechanic, and based on knowing the drum is mostly stainless steel, my first inclination is to grab a can of carb cleaner from the auto shop and a few paper towels, and clean it up.. but I'm cautious with that stuff as it's very flammable... and I'm a guy.
My other thought would be to call or visit your local fabric store. Talk to someone who knows about fabric dyes and ask them what cleaner you could use. It'll likely be less.. barbaric than my fist thought.
IF you try my first thought, spray it on the rag and wipe the drum. don't spray that stuff into the drum.. it flows fast and will take hours to fully evaporate. and let the drum air out over night before using, just to be sure. Have exhaust fans or other ventilation going. Just to be safe too.
Jan 21, 2009 | Maytag HYE3658AY Electric Dryer
Dryer turns white clothes gray.
Replace Burner.
I have the same problem, getting ready to try and tackle this. I've been told it is the burner that is the problem, a crack or cracks in the burner are letting the soot into the drum instead of venting to the outside.
Dec 29, 2008 | Dryers
Auto dry not working
If there is a dryness sensor, it will be just inside the door, on the bottom right. You can clean the sensor by rubbing the metal bars with a scrubbing pad. This will remove any wax buildup from fabric softeners.
Possible reasons your clothes may still come out wet:
1. The dryer isn't tumbling the clothes.
2. The dryer isn't heating.
3. The airflow is restricted.
From your description, the third seems most likely. If your machine is the one pictured above, inside the dryer door is a plastic grate over the lint screen. Remove the lint screen. Remove the two screws on this grate (Phillips.) Use a vacuum cleaner with a crevice tool to get out as much lint as possible. Be careful to not shove any lint or debris further down into the blower wheel.
Lint can also clog up in the vent pipe. This pipe should be cleaned or replaced anually. Also, check the exhaust vent on the side of the house.
Mar 07, 2008 | Frigidaire GLGR341AS Gas Dryer
Spots of Grey lint left on clothes after washing
Have you cleaned the filter on the front bottom of the machine?
May 11, 2017 | Bosch Washing Machines
Black soot in dryer
There are several possible causes: a)  exhaust vent is restricted forcing the lint to enter the dryer shell and overheat and/or be picked up by the blower -- you seem to have inspected this b)  check the hot gas inlet to the drum.. on some dryers, lint buildup can occur in tight spots and it will overheat and char c)  ducting is not intact or leaks allowing lint to leak into the dryer shell -- this will occur over time, and all dryers should be taken apart and cleaned out on a regular basis... also, all ducting should be inspected and sealed as needed d)  verify that the inlet vents to the dryer shell are not blocked and allow adequate air flow to the burner assembly -- natural gas normally won't smoke due to incomplete combustion, but..  likewise, verify the room has adequate ventilation particularly if the utility room or closet is very small,  e)  check the drum drive belt, as it gets old, it will release dust and minute pieces which will be picked up by the blower -- replace if needed... f)  verify that the seals on the drum are still good -- replace as needed g)  as 'washer-tech' advised, do a thorough cleaning and inspection... put it back together with all ducting tight and free flowing
Jun 28, 2007 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
