Hi, I have this mother board MSI P67A and Intel Core I5-2500K 3.3Ghz processor. I have it mounted in a Thermaltake V3 Mid Tower with a Ultra LSP550 550w power supply and also 2 Patriot Signature 4GB DDR3 PC1060 1333Mhz CL9/HS memory sticks, a Seagate 1TB hard drive and DVD player. The problem I have is that I have put this computer together and it won't power up, That is to say it powers up for a couple of milliseconds and goes off. It continues to try to power up only for a few milliseconds every so many seconds but never powers up. Ihave to disconnect power to stop it from attempted to power up. Can you help me? All of these componets are brand new but doesn't work. Is my mother board bad? If so, can I get an exchange from TigerDirect or MSI? (I have also tried another power supply that was 600w, still did the same thing.) Help. Mark
    Master:
  • 525 Answers
Try taking out your ram and putting it back in. Also take out the cmos battery and put it back in. Make sure all the power connectors are securely fastened. Make sure the board is not in contact with the computer case. If it is then you have fried your board. If you still cant get it working then send it to msi. Most motherboards have a minimum 3 year warranty.
Posted on Mar 21, 2011
  • marksmail Apr 01, 2011
    That is a good idea, I will try to remove and replace the clock battery and then try the memory remove and reseat them. These are two things I have not tried. The mother board seems to be mounted okay and doesn't seem to be shorting against the chassis.
    It this doesn't work then I will contract TigerDirect and ultimately MSI.
    Thank you so much for your help and great ideas.
  • 2,632 Answers
Welcome to Fixya. With the specs of the computer it seems that the power of 550W is enough and after changing the Power supply to 600W you same result. Most likely the problem is the motherboard if the board is brand new you can ask to a replacement to Tiger Direct and you can ask them since it still has a warranty.
If you have questions please let me know. Thanks for using Fixya
Testimonial: "Thank you for your help. I will be contacting TigerDirect and see about a replacement. "
Hi guys, i need some advice on setuping my new system. here is the spec of my new system: casing- collermaster HAF 912 motherboard- MSI P67A-GD55 processor- INTEL I5 3.1 GHZ ram- 4gb x 4 total...
YES THIS GRAPHIC CARD WILL BE ACCEPTED BY MSI P67A-GD55 BOARD..
BELOW SHOWN IMAGE IS A VIEW OF NVIDIA GEFORCE GTS 450
THIS CARD ONLY SUPPORTS TWO DISPLAYS AT A TIME
May 24, 2011 | MSI N450GTS-M2D1GD5/OC GeForce GTS 450...
NO Post, No Display & No Beep. I have an MSI 045GCM5-F V2 Mother Board & Intel Core 2 Duo Processor. Plz help.
That is a symptom of burned SMPS or RAM. Try to replace SMPS only cost worth about 20$
Jul 29, 2010 | MSI 945GCM5 Motherboard
32 bit or 64 bit?
Here are the motherboard's processor specs >>>>
Intel Quad-core CPU Ready
LGA775 socket for Intel Core 2
Extreme / Core 2 Duo / Pentium D / Pentium 4 / Celeron D
Processors
Compatible with Intel 05B/05A/06 processors
Intel
Hyper-Threading Technology ready
64-Bit Processing Technology
Yes the motherboard can be used with a 32 bit or a 64 bit processor.
Regards..
Nov 13, 2009 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
Will an Intel E7400 processor work with an MSI P965 Neo F V2?
Your processor "Intel E7400" is listed as a socket 775 Intell core 2 duo processor. Your motherboard "MSI P965 Neo F V2" is listed as an Intell board using a socket 775 processor socket. The front side buss (or fsb) speed capabilities of the mother board, and the buss speed of the processor are compatible They should play nice with each other.
Good Luck!
Jul 27, 2009 | Intel Computers & Internet
I am from INDIA... i want to buy i IBM
Hi Friend,
Check below the model numbers of the intel dual core mother boards avaliable and the
address where u can buy it in Chennai,
1.Intel Atom 330 Dual Core (2x 1.6Ghz)
a.Intel D945GCLF2 mini-ITX
Features are:
  • Dual Core Atom CPU
  • TV-Out (S-Video)
  • 4x Rear USB 2.0
  • VGA, Serial and Parallel
  • 1x DDR2 533/667 RAM
  • 1 x Gbit LAN
  • Realtek High Definition Audio
  • Power: 24 Pin ATX, P4-connector
  • RoHS compliant
b.ECS P945GC
Feature are:
  • custom design board using mini-DTX form factor up to 170×170mm.
  • Intel 945GC and ICH7 chipset Intel Atom 330 CPU dual-core 1.6 GHz, 2×512KB (1MB) of L2 cache
  • FSB 533MHz system bus support up to 1×2GB (DDR2 533/400)
  • Integrated Intel Graphics Media Accelerator 950 ( GMA950 )
  • 2 X SATAII and 1 x IDE channel (for 2 IDE devices)
  • VIA VT1708B 6-channel High Definition audio CODEC
  • 10/100 Fast Ethernet LAN using ATHEROS AR8012 10/100 Mbps PHY
C.Jetway NC92-330-LF
Features are:
  • INTEL®945GC + ICH7 Chipset
  • Support INTEL®Atom Dual-Core 330 CPU
  • Built-in INTEL®GMA 950 Graphics Core
  • Supports 1x Gigabit LAN
  • Integrated ALC662 HD Audio CODEC with 6-CH
  • ITX Form Factor(170mm x 170mm)
  • Support Daughter board Expansion
D.Foxconn 45CSX / 45CTD (soon to be release)
Features are:
  • Intel® AtomTM dual-core 330 processor mounted on board
  • 533 MHz (FSB)
  • DDR2 533 MHz x 1 DIMM, Max. 2GB
  • 1* PCI
  • 2* SATA II
  • 5.1 channel HDA, Realtek® ALC662
  • 10/100M LAN, Realtek® RTL8100C
  • 6 USB 2.0 ports
These are available in India with Prices and best in India Industry
Intel Dual Core Price list in India
  • Intel E2140 Dual Core Processor - 2100/- Indian Rupee
  • Intel E2160 Dual Core Processor - 2450/- Indian rupee
  • Intel E2180 Dual Core Processor - 2800/- Indian Rupee
  • Intel E8500 Core 2 Duo Processor - 8200/- Indian Rupee
  • Intel 2200 Pentium Dual Core 2.2 GHZ -3400/- Indian Rupee
  • Intel E4600 Core 2 Duo Processor - 4990/- Indian Rupee
Address
Address:88/150.Nelson Manikam Road,Dharma Tower Ground,Floor7&8,Choolaimedu,Chennai-94
Landmarks : Near Nungambakkam RailwayStation / Loyala College /Metha Nagar Bridge/Opposite to Bank of Baroda/Mobile Store/ Indian Terrain Ready made
Contact Number:98402 72809
For future assistance kindly contact fixya
Regards,
Ayyasam
Jun 26, 2009 | Abit AS8 Motherboard
Msi p4n sli board
The Only CPU's that board supports are:
  • Supports 90nm LGA775 processor package
  • Supports Intel Pentium Processor Extreme Edition
  • Supports Intel Pentium D Smithfield processors
  • Supports Intel Pentium 4 / Pentium 4 Extreme Edition processors
  • Intel Hyper-Threading Technology ready
  • So sadly no I am sorry. However it does Support a P4 with HT which is still a very nice CPU
    Jan 15, 2009 | MSI P4N Diamond nVIDIA nForce4 SLI LGA775...
    MSI MS-6754 mother board won't boot and beeps when I swap processors
    your motherboard has the chipset of 845GL series
    so the specification of your motherboard is as follows read it carefully there may be some error in the manual or it might not be your motherboard model just have a check with that . here are the specifications as per i saw in the net ...
    CPU • Support Intel® P4 (Socket 478) processor up to 2.6 GHz. Chipset • Intel® 845GL Chipset - Support FSB 400 MHz. - Integrated 3D/2D graphic core (Core frequency= 200MHz, 350MHz integrated 24-bit RAMDAC). - Support PC266/133 Technology. • Intel® ICH4 Chipset - AC'97 Controller Integrated. - 6 ports Hi-Speed USB 2.0 controller, 480Mb/sec. - Support both ACPI and legacy APM power management. - Legacy free support.
    Sep 06, 2008 | Computers & Internet
    New Problem
    The manual you need will be on the board manufacturers web page, howevr I will bet you have the case power switch and perhaps the reset switch on the wrong pins on the mother board. To check this, remove the switch leads from the mother board, then use a small screw driver and bridge the pins on the mother board a pair at a time. All of these leads plug on to the board in a line and not across the two lines of pins. when you get the mother board to fire up by this method geet a torch and look closely alongside the pins you will see the letters PWR SW or RS SW. It does not matter what polarity these two sets of leads are plugged onto both will work. The LED lights on the case front will only work if the polarity is correct but it will not do any harm if they are backwords. On the board you should se two sets of pins marked HDD and PWR these are the led light pins you will know you have them right when the usual red and green lights are working at the front of your tower. Regards mistyman
    Aug 15, 2007 | Balance CP4401 PC Desktop
    Computers & Internet Logo
    71 people viewed this question
    Alun Cox
    David Payne
    David Payne
