I was forwarding 1 file, when the mouse became a cross, instead of an arrow as normal case, so I can't close or delete or do anything else.
  • 823 Answers
Press your "control" "alt" and "delete key at the same time on your keyboard. control is the key that says "ctrl" on it on the bottom left side and "alt" is near it. When you press all three keys at the same time, you will see a prompt that asks if you want to open "windows task manager". choose "yes" or click on "windows task manager".
Click on the tab that says "applications" at the top. Then click on the file that was stuck during forwarding and then click the "end" box at the bottom. This will get rid of the problem. If you can't figure out how to get into the task manager, then just press the power button the pc and hold it in until it turns off all the way. That will also get rid of the file on the screen.
Posted on Mar 21, 2011
When i try delete pictures by holding down ctrl key on laptop they suddenly copy instead of delete
for me this happens alot when I miss click im not sure on the correct key but if anything try just holding ctrl with one finger then click and delete one file to start to see if it still does it if not when moving the mouse you are hitting an extra key which makes it copy.
Aug 02, 2011 | Computers & Internet
Tip
Delete An "undeletable" File!
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 10, 2010 | Computers & Internet
Tip
Delete an undeletable File
Open a command Prompt window and leave it open.
close all open programs.
click Start, Run and enter TASKMGR. EXE
Go to the Processes tab and End Process on Explorer. exe.
Go back to the command Prompt window and change to the
directory the AVI ( or other undeletable file) is located
in.
At the command prompt type DEL <filename> where <filename>
Go back to Task Manager. click File, New Task and enter
close Task Manager.
or you can try this
Open NOtepad.exe
click File>Save as..>
choose "All files" from the file type box
in the "filename" box
pur a " at the start and end of the filename
click save,
1. Start
2. Run
3. Type: command
5. If you cannot access the folder because it has to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces.
7. Now to delete the file type in del ***.bmp, txt,jpg,avi,etc... And if the file name has spaces ypu would use the specific folder throgh command, del badfil~1.bmp and your file should be gone. Make sure the type in the correct extension.
on Jan 31, 2010 | Computers & Internet
Digital id gone after factory restore. I cannot forward emails with pictures.
all data is removed after a full factory restore
you might try one of these undelete programs there are many of them at either cnetdownload.com or major geeks
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media.
http://majorgeeks.com/Ultimate_Data_Recovery_d5336.html
Have you accidentally deleted important files from your hard drive, or your hard drive became corrupted, losing all or some of your important data, files, and folders?
As long as your system
May 24, 2011 | Computers & Internet
SEARCH GOOGLE USING E-SPEAKING
These commands are built-in. You do not have to add or program them.
Working with Applications
Say... Open Word
Open Excel
Open Email
Open Powerpoint
Open Internet
Open Notepad
Close Application
Close Window
Close Document
Scroll Down
Scroll Up
Start Word
Start Excel
Start Email
Start Powerpoint
Start Internet
Start Notepad
Minimize
Maximize
Scroll Left
Scroll Right
Browsing the Web
Browse the web using the following commands: Open Internet
Google Website
Yahoo Website
Altavista Website
MSN Website
eBay Website
e-Speaking Website
Go Back
Go Forward
Refresh
Dialog Commands
Sometimes a program will simply ask you for a yes or no answer to an alert box or dialog. Yes
No
Cancel
Affirmative
System Commands
You can control when e-Speaking is "listening" to you using these voice commands. Standby
Resume
Stop Listening
Begin Listening
Hello
Computer
Listen to Me
Add a New Command
Add Mouse Click
Moving the Mouse
The Mouse Movement option has to be checked on the Mouse menu. Mouse Left
Mouse Right
Mouse Down
Mouse Up
Faster
Slower
Stop
Mouse Clock One
Mouse Clock Two
Mouse Clock Three
Mouse Clock Four
Mouse Clock Five
Mouse Clock Six
Mouse Clock Seven
Mouse Clock Eight
Mouse Clock Nine
Mouse Clock Ten
Mouse Clock Eleven
Mouse Clock Twelve
Slide Left
Slide Right
Slide Down
Slide Up
Mouse Buttons
Select
Double Click
Right Click
Properties
Drag Item
Drag File
Drag Object
Release Item
Release File
Release Object
Mouse Jump To
Mouse One - Top of Window
Mouse Two
Mouse Three
Mouse Four - Middle of Window
Mouse Five
Mouse Six
Mouse Seven - Bottom of Window
Mouse Alpha - Left of Window
Mouse Beta
Mouse Charlie
Mouse Delta - Middle of Window
Mouse Echo
Mouse Foxtrot
Mouse Golf - Right of Window
Editing Commands
Doing some word processing? These commands may help perform common Windows functions. Select All
Edit Copy
Edit Paste
Edit Undo
Edit Delete
Edit Find
Delete Line
Find
Search and Replace
Moving the Text Cursor
These commands may help navigate documents. Left Arrow
Left One
Left Two
Down Arrow
Down One
Down Two
Right Arrow
Right One
Right Two
Up Arrow
Up One
Up Two
Page Up
Page Down
Beginning of Line
End of Line
Beginning of Document
End of Document
Simulating Keys
Enter Key
Home Key
End Key
Spacebar
Escape Key
Delete Key
Backspace Key
Tab Key
Dictation
Start Dictation
Stop Dictation
Standby
Resume
Train Word
Show Commands
Dictation - Editing
Delete that Phrase
Delete that Text
Delete Last Phrase
Delete Last Text
Strike that Phrase
Delete Last Word
Edit Copy
Edit Paste
New Line (inserts a line)
Next Line (inserts a line)
New Paragraph (inserts 2 lines)
Next Paragraph (inserts 2 lines)
Select All
Delete Key
Backspace Key
Reading Commands
Read All Text
Read Selected Text
Stop Reading
Pause Reading
Resume Reading
Skip Ahead
Skip Back
Read Faster
Read Slower
Phonetic Alphabet
You must really like using voice if you are into the Phonetic Alphabet. Alpha
Bravo
Charlie
Delta
Echo
Foxtrot
Golf
Hotel
India
Juliet
Kilo
Lima
Mike
November
Oscar
Papa
Quebec
Romeo
Sierra
Tango
Uniform
Victor
Whiskey
Xray
Yankee
Zulu
Feb 05, 2011 | e-Speaking
While trying to change settings on my computer I lost the Browser bar ie. file, edit, bookmark, icon for home forward and back feature, address bar
Most probably you pressed the F11 key in the upper key row on your keyboard, and it entered "full screen" mode.
Press F11 to exit full screen mode, this should do the trick.
If this is not the case, please come back and write a comment to that effect, we'll try to assist you further.
Good luck :)
Jul 10, 2010 | Gateway MT3705 Notebook
I have windows vista and can't delete mp4 files from my comouter
Even i had the same problem and i could solve it.
Try this
1) Open a Command Prompt window and leave it open.
2) Then, Close all open programs.
3) Click Start, Run and enter TASKMGR.EXE
4) Go to the Processes tab and End Process on Explorer.exe.
5) Leave Task Manager open.
6) Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.
7) At the command prompt type DEL where is the file you wish to delete.
8) Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.
9) Close Task Manager.
Oct 31, 2009 | Nextar MA933A MP3 Player
Htc mobile pc
Make sure that all programs you have been using are closed when you press the cross (X). The factory settings are se to minimize the application instead of closing the program. This will keep all the applications running on the background instead of actually being closed. There are options under the menu setting options that give you the option of closing the applications by taping X or by pressing and holding X. I set tapping on mine.
The more programs running on the background the more memory usage.
Jan 11, 2008 | HTC Touch P3450 Smartphone
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
