Question about ASUS Computers & Internet
My M4A785T- M mobo.can't find my LAN or sound cards installed in the PCI slots 1 and 2.. when trying to download the drivers. error msg, saying no hard ware is installed
    Master:
  • 525 Answers
Make sure your old drivers are uninstalled. When vista/7 starts up by default they look for any missing drivers.
Posted on Mar 21, 2011
How can I download Realtek audio driver on my Dell Dimension 3100 desktop to get the Finding Nemo computer game to work?
Only nemo fails, all other games ok
all windows sounds ok,local mp3 files play
dvd movies sound fails, tell us the extent of the failure first, if only nemo fails , then it's bad, not the PC. ok?
Learnt that most folks trying to replace a driver fail,for many reasons, guessing tops the list
as does blaming it IT IS WORKING CORRECTLY.
10000 of posts here like that, and now the PC has 2 failures.(one real, one self caused)
gee try dell, fixya is NOT DELL.
Dell designed it not us nor microsoft, DELL did.
NO OS stated, is this XP? the virus magnet?
what does funny mean? surely you can elaborate that.? (wish wish)
sound from what object,external speakers, (powered)?
FUNNY?=
1: dead.?
2: Weak?
3: distorted even with volume down)?
4: with all USB devices unplugged? (not mouse, not keyboard) do not use USB head phones or USB only speakers now. nor Blue tooth speakers now.
just real speakers. for the test.(are you?)
5: what jacks, a desktop can have 2 green jacks./
one called (onboard and PCI sound "line-out")
The green jack you pick if 2 there, must be selected in windows sound output screen.
tests?
http://pcdied.com/no-sound/no-sound.html
I can have on my desktop,
All these devices. ( i can select them)
A: BT (blue tooth)
B: USB head phones.
C: main sound chip. Realtek
D: main shut down in BIOS and PCI sound card.active.
E: other head phones, or external speakers.
F: mine now has a USB DAC box, that goes to home theater system. (fancy dancy)
I have no idea at all what you have THERE ever.
bingo dell.
http://www.dell.com/support/home/ca/en/cabsdt1/product-support/product/dimension-3100/drivers
May 13, 2018 | Dell Computers & Internet
New motherboard GA-p67x-ud3-b3 no video on boot
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
    * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  3. 3 x PCI Express x1 slots
    (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
Apr 29, 2012 | Gigabyte Computers & Internet
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
The full details of your motherboard are below:
Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
Nov 03, 2010 | Intel D915GAV Motherboard
LAN is not recognizing Internet port
Then you have reinstall *********** boards drivers from its cd.
Oct 25, 2009 | Intel DG31PR Motherboard
Pc keeps freezing,sometimes even in BIOS, in the event log i read this error message : IRQARB: ACPI BIOS does not contain an IRQ for the device in PCI slot 6,function 0. hardware and appropriate drivers...
Did you place a new video card, sound card, wireless card.. ram.. anything? cause it sounds like whatever you put in is not compatible with your Mobo's PCI slots.
Aug 21, 2009 | Computers & Internet
Lan on motherboard D915GLVG
Unplug your computer and Install a lan card into any available PCI slot.  Restart your computer and install the CD.  The CD will load up the drivers when needed.  You may have to start your computer once completed.
Sep 17, 2008 | Intel Motherboard
System do not reconize the PCI card
Does it ask for a driver to be installed? Or have you got the wireless version of the mobo that needs an ASUS WiFi-b add-on card with an omni-directional antenna?
Like on the previous version of the mainboard, the PCB contains five PCI slots and an exclusive WiFi slot, in its left part. By the way, when you install the original WLAN card from ASUS into this slot, the last PCI becomes unavailable. Now let’s examine the card, too.
The card supports the wireless networking protocol IEEE 802.11b, describing data-transfer rates up to 11Mb/s. Using the software that accompanies the card, you can use it in the Ad Hoc as well as in the Infrastructure mode, and the card can perform the functions of a programmable access point, providing connections to 31 clients. Thus, the owner of the WiFi-b kit can easily deploy wireless networks and connect to existing ones.
Jul 11, 2008 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
Computers & Internet Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
