Question about JVC HD-61Z575 61" Rear Projection HDTV-Ready Television
My jvc is showing black and white what do i do
    Top Expert:
  • JVC Master
  • 75,471 Answers
Hello
Just reset the picture adjustments and se whether the colour comes up or not. If not, autotune it once more.
Reset resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
noise clear, Color Management and Dynamic Gamma) at once to the default settings.
Press the MENU button
To RESET
Use [up-down-prog up-prog dn buttons] To enter
The onscreen menu disappears for a moment,
and then the settings are reset to the default
setting for all the picture adjustments.
Press the MENU button when finished
To autotune
?† To AUTO TUNER SETUP
Up or Down button To operate
To choose CABLE or AIR
Press the OK button to start
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen
Posted on Mar 21, 2011
  • The Knight
    The Knight Mar 21, 2011
    If you have its user manual, go through these steps will be easy. Refer it..
I hooked my jvc dvd player to my curtismathes tv movies only show in black and white why
Try contacting the folks at the link below:
http://www.curtis-mathes.com
They probably have a member on their site that can help you with the problem you are having with your JVC DVD player only showing in back in white on your Curtis Mathes television. They love helping folks and they do it for free :)
Dec 10, 2013 | Curtis-Mathis CM27101S TV
Repair
To have a fair chance to advise or help I need to know the model number and brand of set(JVC)?
Apr 25, 2012 | JVC Televison & Video
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Zashiban
Jun 28, 2010 | JVC AV-32260 32" TV
Where can i find a wiring diagram for my jvc
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Oct 02, 2009 | JVC Car Audio & Video
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Black & White
check the return policy and return it as soon as possible
Dec 28, 2008 | JVC LT42P789 42 in. LCD TV
JVC KD-S575
Most versions of the JVC KD-S575 uses the 16pin block connector as shown below. It is available at the JVC Accessory Store.
Below image shows the pin's alphanumeric designation.
Color coding and where connected is shown below.
A2 Brown - cellular phone/mute
A4 Yellow - Always on B+12 (such as the battery's positive terminal)
A5 Blue/White - Power Antenna
A7 Red - Accessory or switched +12VDC
A8 Black - Chassis/Ground/GND
B1 Purple - Right Rear +
B2 Purple/Black - Right Rear -
B3 Gray - Right Front +
B4 Gray/Black - Right Front -
B5 White - Left Front +
B6 White/Black - left Front -
B7 Green - Left Rear +
B8 Green/Black - Left Rear -
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | JVC KD-S570 CD Player
Don't worry you dont have to buy a new camera :) When you press the menu button there should be an options menu. look around for the "effects" options or something along those lines. There is a black and white mode on the camera, my guess is that it turned on somehow. All you gotta do is turn it off.
I hope that this helps, feel free to ask more questions. I have a jvc video camera just like this one, so if need be i can just look at mine!
Jan 15, 2008 | JVC GR-AX940 Camcorder
Black and White video output
check your tv system,(PAL,NTSC etc.)same as your cd player,go to MENU and select both to ,AUTO.
Feb 05, 2007 | JVC MX-J900 CD Shelf System
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
JVC HD-61Z575 61" Rear Projection HDTV-Ready Television Logo
125 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
