Question about GRY Viore RPT50V24DHD 50" HDTV DLP TV
White & black spot on my 50inch viore projection screen.
Shuttle83
  • 1139 Answers
SOURCE: HOW TO GET RID OF THE WHITE SPOTS
Hello fish_aholic,
Those white spots are the mirrors on the DMD IC failing to respond to the input signals. The most likely cause is that the transistors operating the mirrors have failed. In other words the only way to fix this problem is to replace the DMD IC. Your best bet is to replace the module the DMD is on. You will need the schematic diagram to get the part number. I would also like to suggest that you get a qualified TV technician to examine and repair this problem. This is to avoid any damage that may occur.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jul 03, 2009
  • 2973 Answers
SOURCE: my viore 42 in plasma is not projecting image. I
The video IC module seems to be giving problems. Open the back cover and take a peep inside. Look for the module just short of the screen. replace it if need be.
Posted on Nov 07, 2009
  • 927 Answers
SOURCE: Have black dust looking spots on my screen.
Howdy;
Yes there is a way. The easiest for you would be to remove the back top of the TV. That will give acess to opt lense and mirror. But first check the Lamp and inspect the lense that the Lamp into. It does not take a lot to cause your concern. Use super soft cloth and wipe surfaces.
Good Luck,Big Irish.
Posted on Nov 23, 2009
  • 269 Answers
SOURCE: my optoma is projecting white spots onto the
if it is a DLP projector then the DMD on the engine is likely bad or the main board is bad. The white things are pixels.
Posted on May 18, 2010
  • 15 Answers
SOURCE: white spots on TV Screen
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.</span>
Posted on Aug 21, 2010
Viore big screen tv has white spots all over the screen
Bad Light Engine also known as Optical Assy Block.
UED 1-800-648-6657
PTS 1-800-844-7871
Jun 05, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Black spots like little bugs on screen and some white spots
optical engine failure. that technology is called DLP digital light processing and it uses a device called a DMD digital micomirror device that has millions of mirrors onthe face and they independtly move and sometimes they can get stuck or not move and cause spots black or white across the entire picture. i suggest calling customer support for possible repair accomodation
Jan 12, 2011 | Samsung HCN4226W 42" Rear Projection...
My 50" Viore DLP Television has white dots showing
Bad Light Engine/Optical unit Assy Block
Encompass Parts Distribuiton 1-800-638-3328
UED 1-800-648-6657
Dec 14, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Spot in center of screen, if the color pictureis black the spot is blue, if the picture is white the spot is yellow.
Spots in screen is commonly caused by defective LCD on the optical assembly. LCD replacement is very difficult. I suggest to contact the nearest service center at your area.
Oct 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The picture on my tv has white spots. it is a rear projection tv hd. viore is the brand.
Lets do this, with the tv on go to the menu and if it's still has the white spots, it's most probable to be your dmd board, if the white spots are gone it might be your video board
Jul 05, 2009 | ViewSonic Televison & Video
Hello fish_aholic,
I hope this helps,
Thank you,
Shuttle83
Jul 03, 2009 | Televison & Video
White spots on 50 in. Viore
the pixels are sticking . slow degeneration of the display panel
Jun 30, 2009 | LG 42LC2D 42 in. LCD HDTV
Sony wega k - 50inch flat screen
Since the lens plastic is not tough to damage, I wouldn't use anything more harsh than a window cleaner such as Windex or similar.
Depending on the circulation of the air inside from the fan, there could be spots on the inside.
By viewing them from an angle with a flashlight, you may be able to see if they are in- or outside the lens.
If inside, you will have some panel removal to do.
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
GRY Viore RPT50V24DHD 50" HDTV DLP TV Logo
Top GRY Televison & Video Experts
Paul Bade
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul
Are you a GRY Televison and Video Expert? Answer questions, earn points and help others
