Question about TitanNet Titan Fusion Mountain Bike
Just got this bike it was unassembled. The instruction manual had a different front axle than mine. Mine has the quick release and I can't get the tire tight. I think I am putting the quick release stuff in the wrong order or missing something. The manual that came with it is terrible. Wrong axle, miss spelled words, pictures that you can't even see. Please Help. I just need a picture/drawing of the front axle quick release parts and the proper order. Thanks
    Guru:
  • 347 Answers
On my tips and tricks page are links to owners manuals for Schwinn and Huffy. they are all the same, Those respective websites with the links have clear instructions on quick releases.
Your quick release has three parts
1. shaft with lever
2. nut
3. springs x 2
Take the lever apart, remove the nut and both springs. install one spring large side onto the shaft all the way up against the lever side, slide the shaft through the hub axle center, install the other spring on the shaft opposite the lever small side facing the hub, then screw on the nut. look to the video for the rest.
Posted on Mar 21, 2011
How do I remove the front tire of my Trek Fuel Ex 7 29?
Check youtube my friend, there are great instructional videos there.Remove wheel from front forks, release any air from tyre, using 2 plastic tyre removal tools to remove tyre. Further instructions will be found on youtube.
Aug 28, 2017 | Trek Cycling
I have a Muddyfox stomp has anyone got the instruction manual please
cant find a user manual for that one
is it assembly instructions you need
Oct 27, 2016 | Muddy Fox Cycling
Front wheel woobles
Is the axle loose in the frame (quick release improperly installed); the axle loose in the wheel (hub bearings shot); or the spokes all loose or the rim untrue?
We have limitations to diagose physical problems.
Web searches for any or all of those malfunctions will lead to answers. Bike Shops will find/fix the latter two for you.
Aug 07, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
How does a quick release go together on a rear wheel of a schwinn hydra bike
Quick release can be fitted to any bike - all you need is to fit hollow axle first.
May 18, 2011 | Schwinn Cycling
I am assembling a 24 inch girls Traverse bike. Not quite sure how the front wheel goes on the fork! Seems obvious but I got confused when I saw the quick release assembly packaged with the pedals. Not...
The Front Quick release is used on the front wheel, if the axle is hollow. If it has nuts on the outside of the axle then it does not belong to the front wheel.
The front quick release is actually quite easy.
1) Place the front wheel into the forks.
2) unscrew the nob end of the skewer (opposite the handle end)
3) insert the skewer through the axle (from right to left if looking at the front of the bike)
4) Screw back on the nob a few turns.
The actual working of the quick release skewer is a cam (there is an imprinting on the handle that says open and close. make sure the handle has "open" facing out for the next step.
5) Holding the handle in your right hand, turn the nob with your left hand until the unit is almost tight.
6) Test the tightness by flipping the handle from "open" to "close". this is a cam. if you have the correct tightness then it will have some resistance to close the lever but not be difficult. If it is really hard, then back off the nob a little and try again. If it is too easy then tighten the nob a little and try again. After a couple of tries you will get it.
7) final test. Take a finger and try to flip open the lever, if you can't then its good, if you can then go back to step 6.
Dec 12, 2010 | Schwinn Cycling
I have a Cannondale road bike. There is a quick
You may need to remove the wheel, undo the quick release axle from the opposite side and then use the axle that comes with your trainer.
Jun 11, 2010 | Bell Sports Bell Motivator Indoor Riding...
Does this bike have quick release for the wheels?
If one side of the axle holder has a lever about 2" long it is quick release.
If it has nuts that require a spanner it is not quick release
May 20, 2010 | Schwinn Seneca 700c Road Bicycle
No Rear Quick Release
Some less expensive bikes do not come with quick release skewers. You just unscrew the bolts like you would any other using a wrench or socket. The will probably be really tight so you may need to bear down or use a cheater pipe. Unfortunately, these bolt on wheels tend to be solid axles and cannot take a quick release skewer. You would need to replace the wheel.
May 20, 2010 | Schwinn Miramar Women's 21Speed Bicycle
Men?s Schwinn 700C Prelude Road Bike Assembly
Pedals can be purchased in pairs and some road bikes do not come with pedals. They have 2 different axle sizes 9/16" and 1/2". There are road pedals and road clipless pedals.The ones with clips and quick bindings require special biking shoes that the cleats clip into.Quick releases come in various lengths for front and rear wheels depending on what wheel you have. This all means a trip to your local bicycle dealer. They will match the pedals to the axel size you need and the type of riding you will be doing. For a little extra cost they will install them.They will also match you up with the proper length of quick release skewer you will need and show you how to install and tighten it properly.Remember to take your bike and the front wheel. Hope this helps. Good riding.
Mar 15, 2009 | Schwinn Midmoor Men's Hybrid Bike
ART055 manfrotto pro tripod
Hey there fotoflika, I have had a similiar problem in the past and found replacement parts unavailable. My solution was to drill a small hole through the leg section, and I used a similiar size allen key to stick in the hole, effectively locking the leg in place. You could drill several holes for different extension lengths. Crude I admit, but cheaper than buying a new tripod.
Feb 04, 2008 | Manfrotto 055NAT3 Tripod
TitanNet Titan Fusion Mountain Bike Logo
184 people viewed this question
Top TitanNet Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a TitanNet Cycling Expert? Answer questions, earn points and help others
