Question about Weber SPIRIT E-210 (NG)
The ignitor does not work - Weber SPIRIT E-210 (NG)
    Brigadier General:
  • 4,736 Answers
Since your model Weber grill has crossover electronic ignition. I have to ask, have you changed the battery in the ignitor button/module? If so, is the battery facing the right direction? If the answer is YES to both of these questions, then the electrodes at the burners may be covered with grease and won't spark or the wiring to the electrodes may be loose and it has lost the ground. A cotton ball dipped in alcohol works well to clean the grease from the electrodes. Tracing the wiring will give you an indication on whether the connections are loose.
Hope this helps you solve the problem.
Posted on Mar 21, 2011
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
Ignitor isnt working
The oven ignitor should have a resistance reading of about 3.2 to 3.6 ohms. If the readings are out of this specification or show open replace the ignitor. measure the resistance of the oven valve. The gas valve should have about 1.5 ohms of resistance. If the gas valve is OK, the control board is suspect. The ignitor needs 120vac to work.
Apr 07, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
Frigidaire FGB24L2ASA ignitor doesn't work. The ignitor will not glow at all. There is current. Not sure if connectors are oxidized or not. What else could be causing the ignitor not to work? This...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Apr 25, 2011 | Ovens
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
My Maytag gas range oven is not working. The broiler works okay.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jul 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
The oven wont turn on the gas range works the broiler works but i cant use the oven to bake i t says pre heat and does nothing
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Amperage should be 2.5-3A. If less than 2.5A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers : WB2X9154, 4342528, SGR403, 5304401265;
Those ignitors are interchangeable, if you can splice the wires. If not comfortable splicing wires - replace it with the first one in the list, should be direct replacement.
Feb 26, 2010 | Hotpoint RGB790SEHSA Gas Kitchen Range
Bake does not work
Dec 11, 2009 | GE Profile JGSP48 Gas Kitchen Range
Bosch gas oven, the gas broiler works but the bake will not work
Find the bake ignitor (you may need to remove the bottom drawer or oven cavity floor) Turn bake on. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Jul 19, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
Weber SPIRIT E-210 (NG) Logo
1,091 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
