Question about Hayward Garden
Hello,\r\n I'm running a 3 year old 1.0 hp Hayward Superpump on 220VAC mains, supplying a 25,000 gallon above ground pool through 1 1/2 inch lines with sand filter, and Polaris cleaner with booster pump. I don't use biguanide. The system had been running fine, although the pump has always run rather hot and noisily. The motor shut itself down after making some intermittent grinding sounds. The mains breakers were still closed, the motor housing abnormally hot. I checked for intake obstruction, emptied the strainer, and re-primed. The motor started up and ran, but within seconds began emitting smoke and flames from the cooling vents. I killed the power immediately, and the fire extinguished itself. I pulled the motor, I find casing and impeller intact, shaft turns freely with no palpable slop. The capacitor, switches and contacts in the dryend are dry and show no charring or corrosion. The jumper is set correctly for 220v. I suspect bearing failure. Questions: 1) How can I determine if this unit is salvageable? 2) If I must replace, should I consider upgrade to 1.5 HP? Please advise. Thanks! W Emory Lawrence, MD
  • Emory Lawrence Mar 29, 2011
    Again, thanks for your help John.
    I did replace motor w/ OEM unit of same specs along with new impeller seal. The impeller, and pump housing were in satisfactory condition and so were not replaced. The install went without any problem and now pumps works great!
    The old motor obviously had been sucking (no pun intended) for many months... and extremely noisy. Filtering and back-flushing were getting increasingly sluggish. This had developed so gradually that I did not notice. However, when the failing motor finally burst into flames, even I was able to recognize that a serious problem may have developed.
    Maybe next time I'll deal with this in more timely manner, rather than waiting for catastrophic failure at some future time :-)
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Check the stator for a ground-fault using a megger or a ohm meter. If it smoked it is likely even an ohm meter will show a ground; if it is not grounded check for resistance across the line connections. A typical single phase motor will be about 1 ohm. If it is zero ore some number below .5 the winding is shorted.
A winding that smokes is nearly always best to be replaced. Even if you get it running again it is only going to be for a short time. I would not change the horsepower if the pump had been keeping the pool clean prior to the mechanical and/or electrical trouble. If you do you'll need a new impeller too since changing one without the other is pointless.
Was the pump leaking as you began to have these troubles? Have you confirmed the incoming line voltage is 220V and stays at least 208V or more under load? You may have had an underlying problem with voltage drop or a leaking seal that caused the failure that you will want to address to prevent this from happening again.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Posted on Mar 21, 2011
  • 1 more comment
  • Emory Lawrence Mar 23, 2011
    Thank you for your prompt reply! The motor did indeed have short in windings, so I'm replacing it along with impeller seal. Agree w/ checking for voltage drop under load after install of new unit. You did mean AC potential measured with multimeter across the 2 hot leads with motor running, right? I did research sand filter specs, and as you suggest, upgrade to 1.5 HP not indicated.
  • John Prohaska
    John Prohaska Mar 23, 2011
    Yes, measure the potential on the two hot lines with the motor running. Voltage drop should be less than 10%...the less drop the better.
    John
  • John Prohaska
    John Prohaska Mar 29, 2011
    Glad it worked out and yes...catching a motor as the bearings and/or seal start to fail can be much cheaper to fix...often under $100. If you get a moment please rate my answer :)
    John
On the haywood superpump model c48l2n134b1 i have 2 wires to wire on L1an L2 witch wire goes were
Either wire can go to either line as long as it is only one line lead to each post. Rotation is fixed and unlike a three-phase motor, reversing the two wires does NOT reverse the motor rotation.
John
Dec 07, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
I have a 3/4 hp superpump that is about 2 mos old. when it runs it "Surges" and puts out no pressure. The suction line is drawing in water.
I had a problem with mine. It also was drawing in water but it turned out it wasn't enough. The flap on the skimmer wasn't opening all the way. It get stuck closed sometimes. I probably need to sand on the hinges a little.
Aug 27, 2010 | Hayward SAND FILTER, PRO SERIES
If you are replacing a 2 hp pump with a Hayward 2 hp super pump on a 220 line is L1 white and L2 black
Shouldn't be a white line on a 220 circuit but some people use them. Red and Black is the standard. If you are sure they supply 220 VAC, which I would verify, it doesn't matter which one goes to which terminal. 120 or 3 phase matters. If you have a multi meter, put the red lead on the black wire and the black lead on the white wire. If you read 220, good. If you read 120, it will make a difference.
Jun 26, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
How do i take apart a hayward superpump 115/230V serial number c48l2n134b1?
i have a hayward 3/4 hp model c48l2n134b1 motor when i turn it on runs fine heats up and shuts off smells like somthing is burning
May 22, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
I am replacing my Hayward 1 HP superpump. The old pump had the 230/115 conversion plug on line 1. The new pump has it on line 2. Do I jusst connect the 115 v(hot) wire to line 2? That would be oppisite of...
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
Oct 19, 2009 | Hayward 1.5hp 230v 2 Speed Uprated Super...
Pump is leaking from the bottom what do I need to do to fix it? Only leaks when running, also looses prime when turned off.
The mechanical seal. We sell them for about $4 or you can get them locally. The superpump uses a 201 seal.
Jul 16, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
I'm need assistance wiring my hayward 2 speed super pump up with my pool timer. the pump is working now but it's running real hot and making alot of noise.
You may have a faulty bearing ... causing the noise. The pump is actually water cooled. Do you have 2 inch line for your 2 HP pump? Small pipe makes the pump work harder. If your lines are smaller, you may want to consider a smaller pump.
the motors will run pretty warm.
Run your pump on high for best results.
If you are using a timer ... you will need a double pole switch to turn it off if it is setup for 220 VAC (which it should be, for most econimical operation)
Jul 08, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
My hayward 1hp pool pump is running very hot to touch
Make sure the supply wire is the correct gauge for the current draw. The main reason to run on 240 volts is a smaller gauge wire and breaker than on 110 which draws close to 15 amps. For example a person using an above ground on a small extension will cause it to overheat. Make sure it is getting as much power as possible
Jun 30, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Garden Logo
136 people viewed this question
Top Hayward Garden Experts
Craig Butler
Craig Butler
Bill Boyd
Pushkar Singh
Pushkar Singh
Are you a Hayward Garden Expert? Answer questions, earn points and help others
