Question about Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range
Power went out and now the stove is on off can not do any baking
  • 24 Answers
Does the oven actually say "off" or does it seem to be off (not responding to keys, doesn't light up, etc.)? You may find this page helpful.
Posted on Mar 21, 2011
My whirlpool electric stove not turning on
Make sure it is plugged in and you have power to your house.If everything is dead check your fusebox for blown fuses if you have circuit breakers reset the breaker for the stove by turning it off then back on. If the burners on the top work,but the oven won't you probably have a burned out bake element .To change this turn off power to the stove and unplug remove 2 or 3 screws holding the bake element and remove the wires to the element by loosing the screws on the terminals note sometimes bake elements plug in in this case just unplug. Reverse process to install. Reapply power and test.
Aug 06, 2014 | Whirlpool Stove / Oven / Range Electric...
No problem with hotpoint electric range til I went to start oven, breaker kept tripping & making a popping noise
From having a Hotpoint myself, I can think of 2 possibilities.
Obvious answer would be electrical problem. If it trips the breaker you probably have a loose wire or a bad plugin socket. Did you buy a new "pigtail" plugin socket or did you use an old one when you got the stove? They say to buy a new one each time. If this is your first problem with this then your circuit can probably handle the load but see if the circuit that tripped says 30 or 40 amps. Also check to see if anything else is on that circuit besides your stove. There shouldn't be anything else on circuit. You may even have a bad circuit breaker but that seems less likely.
Second possibility is a bad baking element at the bottom of stove or bad heating element on top. When mine went bad, it made loud popping noises and sparks were flying. After that, the rest of the stove worked but not the baking element. I had to replace it for about $50.
My bet is on a loose wire. Be careful and unplug everything before you check! See if it's not fully plugged into the socket and see if the 3 or 4 wires coming from the thick plug wire are all tightly connected to your stove.
Jan 12, 2014 | Hotpoint RB757 Electric Kitchen Range
Oven will not heat up
Sounds like the oven power switch went out . Unplug or turn off breaker to the stove / oven. Disconnect the wires going to the oven bake / broil switch and using a electric meter check for continuity on the pos.and neg. terminals of the switch. If there is none then you need to replace the switch.
Aug 07, 2012 | Cars & Trucks
I own FRIGIDAIRE ES100/105 (electric stove and oven). Yesterday I was using the oven and suddenly I heard a loud sound. I went to check it I found out the both the oven and stove were off. And not working....
HI. The actual issue will be with the main logic board, which is where the main element control relays are mounted. These very important relays are damaged. The main board will need to be replaced, asap.
With that said, if you could be so kind; Please post the entire model number so that i may pull up all necessary part numbers needed, as well as, service manual links and diagrams to help with your repair.
Dec 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
The oven was on and I was baking. Heard a 'pop' then the oven went off. I flipped the stove breaker on my electrical board back on and it took the whole power to my house out. Flipped the stove breaker...
element has blown, pop is it breaking, that heating element will need replacing, failing this and elements all working water may have gotten to the electrics this would cause the pop and shut down all electric as well.
Jan 02, 2018 | Heartland 3525SS Dual Fuel (Electric and...
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
Bake or broil elements won't work.
First,go to the electric circuit panel. Turn the range breaker OFF then back ON. If that does not correct the problem you will have to replace the electronic control(clock) for the oven.
Aug 18, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 | Ovens
Ge jbp77 radiant range
my stove shut off. it want stay on
Ken
Dec 11, 2007 | GE Spectra JBP78 Electric Kitchen Range
Open Questions:
See all Thermador RDDS30 Dual Fuel (Electric and Gas) Questions
Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
147 people viewed this question
Top Thermador Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
