Question about IBM BLADECENTER HX5 186G 8 787261U (883436100908) Server
We bougth one HX5 with 2 processors of 1.86Ghz octacore, and 56Gb Ram. It perfomance is less than on HS22 with 2 processors of 2.93Ghz con same memory. We use Postgress BDD. The comparasion is with the same enviroment OS Centos 5.3
    Brigadier General:
  • 4,044 Answers
Aside from the obvious difference in the Processor speeds the problem is most likely a bottle neck in the HX5 which uses a 512 FSB versus the 833 FSB of the HS22. This should be minimal though. The second place I would look if the FSB isn't the problem is the RAM Type. They both may have the same amount of RAM but if the HX5 is using the slower DDR 1 RAM versus the DDR 2 that the HS22 uses you will have system degradation.
Posted on Mar 21, 2011
How to enter biosmode
Pressing the [F2] key allows you to check and correct the settings in BIOS setup. After the correction an error free system start is possible again.
http://manuals.ts.fujitsu.com/file/8423/d2785-bios-en.pdf
This link can help you as well, good luck.
Mar 01, 2015 | Fujitsu Siemens FSC Server Primergy TX120...
Correct Graphics Driver for Windows 7
try a downloadble programme like driver easy or similar.
Apr 24, 2013 | Computers & Internet
Why is it going slow, it a celeron d processor 3.33ghz, is it windows vista??
HI
thank you for using Fixya
yes there are meger problem with Vista pc becomes slow change your OS Windows XP or Windoews 7
then up-date your RAM it will give faster perfomance
May 14, 2010 | Intel Celeron D 355, 3.33 GHz...
Can this computer using xp
Of cource supports but work slower then 2000, After install change theme into Windows Classic, then right click MY Computer> properties>Advanced and change perfomance settings to "Adjast for best perfomance" and it will work normal but if you want xp with visual effects it will slow down and make pauses during work.
Jul 30, 2009 | Compaq Presario 12XL325 Notebook
Lenovo 3000 N100 0768-FTG lap top need processor upgrade
I'm afraid you're out of luck, the motherboard is not capable of taking a dual core processor. Your only option would be to consider selling the laptop and buying a new one that already has a dual core processor installed.
Jun 10, 2009 | Lenovo 3000 N100 Notebook
Why my mouse and keyboard hangup when i attach my flash
It sounds like you could be low on memory or your processor is working super hard.
To fix this, first, check and see how much ram you have by right clicking on "My Computer", then click "Properties". Your processor speed and ram will be shown in the window. If you have less than 256 MB of RAM, or a processor less than 1.2 GHz, then you might need to upgrade your processor or RAM.
Apr 16, 2009 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
Intel DG31PR Motherboard not booting
You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
"If some thing is working, don't try to fix it" :) .
Jan 28, 2009 | Intel DG31PR Motherboard
Pentium4 3GHZ
buy a new ram.it incress your pc's perfomance
Jan 11, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Processor load on biostar m/b
IT seems no problem with your specification, but only one thing less in this criteria. What inch does your monitor? This must be match with the specification of your VGA Card, The more resolution you can get the best performance of this VGA card you can achieve, try to higher the resolution of your monitor , don't only use 1024 x 768 , but try another higher resolution. The VGA itself cannot reduce the system perfomance, because your vga card has GPU (This VGA card has his own processor and memory) just like mini computer inside your main computer.Hope this things can solve your problem, don't forget to vote
Jul 01, 2008 | Computers & Internet
Hanging vista home premium
  • When performance test is ran, the processor and other hardware resources are used as much as possible. So please check whether the processor gets over heat or any problem with memory modules. If the problem is with memory module, try to test it one by one running some memory diagnostic software, which can run on boot disk.
Take care.
May 24, 2008 | Microsoft Windows Vista Ultimate Edition
IBM BLADECENTER HX5 186G 8 787261U (883436100908) Server Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
