Question about Brother 929D Mechanical Sewing Machine
I am trying to sew three layers of sweater material and my needles keep breaking. What adjustments can I do to not break needles?
  • 10,319 Answers
Just be sure to test your stitch on scraps if you are using a serger for your seams. Heavy sweater knit requires some tweaking of the settings. Hems are sometimes tough as well. You may want to try alternative hems like lettuce, or bound...depends on your pattern, etc. Let us know what 6the outcome is
Posted on Mar 21, 2011
The needle keep on breaking because it stich on the plate
Your needle alignment may need to be adjusted. Sometimes this happens if you pull the material rather than let the machine feed it. I took my HV in and it was alignment. For less than 30.00 they realigned it and now works like a charm, no more breaking needles!
Dec 07, 2016 | Sewing Machines
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
or
www.youtube.com/sewing/canvas/material/
www.youtube.com/fy5318/multiple/layers/of/material/setup/
www.ask.com/sewing/multiple/layers/of/material/and/setups/
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
Why does my machine keep breaking needles
try these suggestions
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Feb 19, 2013 | Necchi 6018 Mechanical Sewing Machine
When sewing hems and coming across a thick seam, the pressure foot seems to not allow the material to run through, keeping it stalled while the needle continues to pump into the material eventually...
I don't think you can adjust the feed pressure on this machine. I have the same machine and the same problem and my solution is the same as you've already mentioned - raise the foot and move the fabric by hand. I would do it by turning the wheel by hand until the seam is clear of the foot to prevent breaking a needle or sewing my fingers.
Feb 06, 2011 | Brother XL-2610
Thread keeps breaking when sewing through thicker materials
When you sew any thick material on any machine the needle cannot form the loop properly as the needle comes up because the material is keep the tread tight to the needle, the only real way round it is to sew slowly.
Jun 23, 2010 | Consew 206RB
try to reduce needle thread tension. if no improvement then remove and look closely for any sharp point in bobbin case holder mechanism that may be breaking thread.
Nov 25, 2009 | White Sewing Sewing Machines
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
Janome left needle thread breaking CONSTANTLY
Sounds like a tension problem. Your machine should have two tension adjusters. One for each needle. The book that came with your machine will tell you how. Another possibility is a bent needle.
Feb 27, 2009 | Janome MyLock 634D Mechanical Sewing...
Problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Mar 29, 2008 | Juki DDL-8700
Brother 929D Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
