Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
My freezer doesn't seem cold all of a sudden, but the fridgeis ok. Neither is overstuffed, no leaks, smells or weird noises. Hasn't been moved, unlikely that plug is loose. Has been happening for the last 4 hours. Also, is 1 the warmest setting? Normally have it on 6, tried putting it to 7, but then decided to put it back to y. Model YRT 12 CKYDW Serial EWG 3075147 Thanks a lot.
  • 122 Answers
One is the warmest setting. check to see if there is any frost build up in the freezer and if the fan is running.
Posted on Mar 21, 2011
I have a Whirlpool ED5KVEXVQO2 Side by Side refrigerator. It is still very cold but making odd noises and smells like rotting oranges, mainly in freezer. Is this freon?
refrigerant doesn't smell much at all. remove all drawers, clean and defrost, rinse inside with sanitizer. you may find somethimg fallen where you can't see it normally. also check and clean outside as well, particularly around the compressor and condenser where it gets very hot.
May 04, 2014 | Whirlpool Refrigerators
Chemical smell coming freezer
You may check to see if you have a Freon leak.
Dec 23, 2013 | Refrigerators
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
My bottom freezer refrig. Kenmore 596.72214200 - suddenly smelled weird burning smell from back of frig., hear occasional clicking sounds. Everything seems to be working. Smell seems to happen when...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | Whirlpool Refrigerators
My Frigidaire refrigerator is at 60 degrees Fahrenheit and will not cool down
There are a few possibilities. First, Is the freezer portion working okay? If yes, then the problem is blocked air flow from the freezer to the frig. If no, then the cooling fan could be bad or the thermostat could be bad. First check for temperature in Freezer section, should be about 4-8 degrees no more. If it is cold, then locate the cooling fan behind the back of the frig and see if it is moving or listen for movement. If it is moving then rearrange the food in your freezer compartment.and frig compartment away from the vents. If it is not moving, then the thermocouple could be bad. compressor problems and freon leaks are not that common unless the frig has been moved alot. The cooling fan or thermocouple or overstuffed freezer compartment are the usual suspects in 90 % of cooling problems. cooling fans and thermocouples can be cleaned by using canned compressed air to remove dust which will sometimes cause a failure. The parts are inexpensive but labor is about $80. Start with the freezer because all of the cooling for the whole unit starts in the freezer.
Dec 18, 2010 | Frigidaire Refrigerators
I've got a 2002 Escape, and all of a sudden when temps dropped below 0 (here in MN) I get a strong exhaust smell inside the vehicle ??? Where shoulod I start looking for the problem ? Should I temporarily...
ok exhaust smells tend to intensify in cold weather. your vehicle is using more fuel the colder it gets. once the engine warms up does the smell go away? if it does, then i wouldn't worry.
Dec 18, 2009 | 2002 Ford Escape
Making a weird noise. sounds like water running but nothing leaking
if the fridge and freezer are still getting cold it is either just the sound of the refrigerant moving through the system or i would try checking the drain incase it has iced up
Jul 29, 2009 | GE GTS22KBP Top Freezer Refrigerator
The refrigerators accumulate ice
the fridge distrubutes cold by air movement. A overstuffed fridge can have trouble. There is a fan that blows a controlled amount of freezer air over to the food side, altho when this goes you usually have frozen freezer and food too warm. Make sure the air is allowed to move.
Nov 29, 2007 | Liebherr Premium CTP 3153 Top Freezer...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
95 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
