Question about Panasonic PT-50LCX64 50" Rear Projection Television
I have a green tint on the screen. covering about 90 percent of the tv. it looks like a block on the bottom right corner. the very top and right side of the tv is fine. its prob about a two inch line that goes around. any ideas? its a pt-50lcx64 panasonic projections screen. it was given to me and i was playing around with it trying to fix it.
  • james youngblood Mar 23, 2011
    ok. i will give it a try. im not too familiar with tvs. trying to fix this myself because its too much for a service man. where exactly are the projection tubes? are you talking about the small tube in the front of the tv? i pulled off a panel in front of the tv and found a small tube with a filter on the top and bottom. i can put my finger in front of it and it cast a shadow. i assume this is what youre talking about. and if there isnt anything, where do i get more fluid? tv repairman?
  • Panasonic Master
  • 1,229 Answers
If you tried to clean the mirrors or someone else tried, there may be an object on one of the picture tubes. I've seen this happen. In one case I repaired a projection TVwith a piece of black tape across the red tube. It may have left the manufacturing plant this way. Please check and see if a cloth is laying on one of the projection tubes. If not, you have a contaminated picture tube, replace the fluid. Thanks for asking!
Posted on Mar 21, 2011
  • matt martin
    matt martin Mar 26, 2011
    If this TV is a projection set, it will have three picture tubes. Each will be of three colors, red, blue, green. You will need to clean these and the mirror above them. On the other hand, is this TV a DLP, and not the older projection set?
I have a KDF 46E2000.About a half hr ago i was playing xbox and noticed the top of my screen turn red from one side to the other, 1/2 in down. The very bottom of my screen is tinted blue but very...
The Optical Block is causing the problem. It has been a common problem and Sony may still have a recall on it. You can check it a 1800-222-sony. If it is not still covered, I would expect to spend 800.00 to 900.00 for the assembly plus 250.00 labor for a professional to replace it.
I hope this helps,
Skyassoc
Dec 08, 2010 | Sony Grand WEGA KF60DX100 60" Rear...
Tv gone green/blue and sometimes red in top right corner
If you have a Sony rear projection LCD TV then you have a failing optics block. LCD TV's are not affected by external magnets like CRT TV's were. The optics block issue will only get worse and needs to be repaired by a technician.
Sep 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Bluish tint that starts in lower left corner and goes across scre
i have blueish on right lower corner of screen.... what causes this
Mar 05, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Free big screen, is it worth it to fix?
take the front cover off.two hidden screw at each corner or on the sides .now take off cover in middle of set.two the right you'll find a small box , it will have 3 adjustments on the top and three more at bottom.the bottom ones are your screen controls.the middle is your green and on the right is the one you turn counter clock wise.warning ...turn that control a hair .that will solve the problem
mr.tv.inc
1-866-217-6788 harry
Feb 18, 2009 | Sony KP-57HW40 57" Rear Projection...
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
65 in.JVC bad picture
You may have a convergence problem that means, there may be convergence ic's bad or related components.
If you know something about tv's, try checking things out.
You can get a repair manual from websites to download.
If you do not normally fix tv's the best thing is to call a tv repair technician.
Feb 22, 2008 | JVC AV-65WP55 65" Rear Projection...
Sony wega 50"SXRD (green tint)
They are one in the same IIRC. I'm having my TV repair for the same issue. Don't worry for now because the item has had its warranty extended to Oct 08.
May 18, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Yellow spots
I have no suggestions but I am having the exact problem, yellow haze in the top right corner of the screen with a yellow line running down to the bottom of the screen. I guess we need to call tech support.
Dec 09, 2006 | Sony KDS-R50XBR1 50" HDTV
Panasonic PT-50LCX64 50" Rear Projection Television Logo
105 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
