Question about Wasp USB to Serial Converter (633808160029) Serial Adapter
My windows xp computer gives me a message that WASP USB to Serial converter is not compatable. It suggested I try to find a device driver that is compatable with win xp. Please Help. Thanks. Paul
  • 1,591 Answers
There's a problem with the OS in the registry, the unit itself doesn't need a driver, the OS supports it directly.
OS = Windows Operating System.
Try the unit on a different system. If it works, look to your system registry
if it doesn't , the unit may be defective (most likely is)
Posted on Mar 21, 2011
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
I have the same printer, and xp on my pc, but how do i connect them? my laptop does not have a serial conection. i tried to use a usb/serial converter and i installed the xp driver from minolta website,...
You need to make sure you have selected the correct COM port whin you try to print. Depending on the type of USB to serial converter, the COM port it assigns can change just by moving it to another USB port. Right-click on My Computer and select MANAGE. Select Device Manager from the list. Click on the (+) next to PORTS and double-click on your USB-SERIAL device COM port. Somewhere in the Properties window you should be able to see the assigned COM port (COM1, COM2, etc.). If possible, set the COM port to COM1 or COM2 for greatest compatibility with older software. Then when you print, make sure your printer driver is also set to the same COM port.
Mar 05, 2011 | Office Equipment & Supplies
I am trying to install the Singer professional Sew-Ware software on my new computer that us running Windows 7, I had to purchase a Serial to USB cord which I attached and installed the cord. When running...
Singer.com's FAQs provide the following:
Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 22, 2010 | Singer Professional Sew Ware Options 2.0...
USB to serial converter will not link to Macbook
the mac is still a mac but running windows, is sewing machine pc/mac compatible? if it is then boot under osx if u cant its not osx compatible only pc
Apr 24, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
I have a Kingston Data Traveler 2GB USB Flash Drive which I bought 2weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices...
We have all had it, yesterday it was fine now it says it doesn't recognise ya USB device.. AARrrgg. Well there are various way to try to fix. Now providing your USB aint Kaput then this works like 99 outa a hundered.Simply Remove and reinstall all USB controllersTo remove and reinstall all USB controllers, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
  2. Click the Hardware tab.
  3. Click the Device Manager button.
  4. Expand Universal Serial Bus controllers.
  5. Right-click every device under the Universal Serial Bus controllersnode, and then click Uninstall to remove them one at a time.
  6. Restart the computer, and "Windows" will then automatically reinstall the USB controllers.
  7. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Remember with USB devices. FIRST, install software/drivers, then insert USB device SECOND.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Device not ready
CNET's review states that this camera connects to USB, but no mention is made of it being compatible with USB2. Theoretically it should be compatible since USB2 ports are supposed to be backwards compatible with USB 1.1. Yet I have other USB 1.1 devices which will cause "device not ready" error messages when I try to connect them to a USB2 port. Interestingly, the CNET article doesn't list Windows XP as a compatible OS. Another person posted that he received the same error message when trying to connect his camera to his 64-bit XP computer.
In any event, Largan's web site doesn't make any mention of them producing complete cameras -- only camera components. Perhaps their foray into the digital camera market was less than successful.
So, while this isn't truly a solution post, perhaps it may point you in the right direction as to possible causes of the device not ready error message.
Apr 20, 2009 | Largan Chameleon XP Digital Camera
Bit of a problem installing Wacom Intuos2 with serial converter
you can check in the internet for the new driver and u can install like in XP and you dont find send the model number and the name and i will check for u
Nov 22, 2008 | Wacom (PTZ930AC) Graphic Tablet
Tripp-Lite USB to serial
Windows XP has gone long ago obsolete.
Suggest upgrade with a new computer to Windows 10.
Mar 02, 2018 | Tripp Lite Computers & Internet
Wasp USB to Serial Converter (633808160029) Serial Adapter Logo
138 people viewed this question
Top Wasp Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Wasp Computer and Internet Expert? Answer questions, earn points and help others
