Question about Sony Playstation 3 (PS3) Console
My PS3 is broken and It will not turn on any more do to blunt trauma and i want to get the info off my hard drive how do i do this can it be done.
    Filmmaker:
    Uploaded 5 video answers.
  • 84 Answers
If you mean you want to transfer the files from that ps3 to another, all you have to do is remove the harddrives in both units, and swap them. If you want to have the harddrive in the new unit instead of the old one, once you have the old harddrive in the new unit simply use the backup function and backup to an external harddrive. In either case keep the extra drive because ps3 harddrives have a tenancy to die (I'm on my third drive)
Heres a video on how to remove the drive:
Posted on Mar 21, 2011
An error occurred during the update operation (8002f310)
ok this is my solution download the update in a blank cd create a folder and name it PS3 inside this folder create another folder and name it UPDATE in upper case use the update folder for your download once you have done install the cd on your playstation and turn it on and wait and see if it works if not remove your hard drive and install another one but do not remove your cd now get a flash usb drive and do the same create a folder PS3 another folder UPDATE and downooaathe update once you turn on your ps3 with thenew hard drive it will ask you for the usb drive make sure to connect the usb drive and follow instructions on screen if you don't have another hard drive you can format the one you have in your ps3 yes i know you have all of your games there and info but there is no choice this is why you need to try with the cd first
Oct 04, 2013 | Sony Playstation 3 (PS3) Console
What are trauma plates in bullet proof vests?
The trauma plates are used as an additional barrier and protection against blunt-trauma injuries, such as light injuries like bruises and more serious injuries like broken bones and damage to internal organs. Trauma panels are made of either metal or ballistic fibers.
Feb 04, 2013 | Work Safety
What are trauma plates?
Trauma plates are devices that can be added to the vest over a localized area (most commonly the mass centre of the torso) to increase the wearer's protection against blunt-trauma injuries. Blunt-trauma injuries are caused by the impact forces of the bullet against the armour, resulting in non-penetrating internal injuries, such as bruises, broken ribs or other injuries to internal organs.
Jan 17, 2013 | Sport & Outdoor - Others
Well every time I turn on the ps3 it suddenly starts flashing yellow,makes a 3 beep noise then flashes red until the power button is pressed again please help me
I couldn't give you the specifics as to Why it's happening, but to me it seems like you're probably gonna need a new power adapter cable.. or unless it suffered recent physical trauma maybe the optical drive is loose. Either power is not being properly conducted into the console or something inside it is amiss and needs Sony to look at it. I used to have an Xbox with a very similar problem.. turns on for a second or two, beeps, and turns off. That was due to trauma.
Oct 20, 2012 | Video Game Consoles & Games
Error 80010514 on ps3
anyone with this error code, it is NOT a firmware issue, it is for sure hardware failure, the blueray disc is gone and will need replacing. instructions to replace it can be found here.
Let me know if it works for you.
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
How i can fix red screen on ps3 ?
Well first of all you can try the below steps -
1. turn off your ps3 with switch at back
2.hold power button
3.(do this while holding pwr button) switch back on the ps3
4. if done correctly the ps3 should make a loud fan noise causing the fans to enhance for awhile, that should clean out anything that could overheat the ps3
Sometimes the red light will be flashing because there is a problem with the connection of the hard drive to the rest of the PS3 or the hard drive itself is broken.
You can usually fix this problem by re-setting the drive. To do this, go to the side of your console and take out the hard drive. Then replace it in exactly the same position. If the red light is still flashing when you turn your PS3 on, you might have to get a new hard drive, or even a new PS3. Please post comments for more help or information..........
Good Luck!!
Thanks
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Playstation won't work
that usually only happens when the hard drive was taken out and a different one from a different ps3 was put in its place... the ps3 doesnt recognize the info on the hard drive that was written by a different ps3.
Jan 24, 2010 | Sony Playstation 3 (PS3) Console
As the result of blunt trauma to the monitor it is half green and the pixels that should have been there look like they are on the bottom of the screen. Is this fixable or should I replace the monitor? If...
If the LCD screen has a cracked or shattered glass then the LCD screen needs to be replaced, it is beyond repaire.
There are LCD replace available on the Internet, it needs to be one that suits your model laptop. LCD Parts can service, have parts and DIY info use this link to their WEB site :-
www.lcdparts.net
Sep 26, 2009 | ASUS Eee PC 1000HA Notebook
When i turn on my ps3 it comes up ''hard disc drive is corrupt''
My PS3 has done this before. If it is like mine then all you have to do is wipe all the memory and restart the system which should be one of the options it can give you if you click past the "Hard drive disc is corrupt screen." This can happen because you might of shut down the system by accident when it was saving a game thus the hard drive becomes corrupted. You won't lose any online info but you will lose memory to saved games and thing else that is saved on the HDD like Demo Games. I hope this helps you. If not then I am very sorry and I am sure it will be fixed if not by my advice.
Mar 09, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
