Question about Garden
I need an exploded view of the drill/screw mode and the torque adjuster
  • 43,501 Answers
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Posted on Mar 21, 2011
My drill slips under high torque
check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Nov 04, 2012 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Problems with torque clutch in new DeWalt tranmission
hi
like most clutches on hummer unit after the assembly has been done you will a way to tighten the spring clutch look for adjustment to make the spring looser and tighten
Mar 10, 2017 | Dewalt DC925 Cordless Drill
Dewalt D21810KS-XE is described as having a clutch. Is that clutch adjustable torque?
Yes, that would be to adjust the screw driving torque etc.
Feb 18, 2011 | Dewalt Drills
The 14 Position adjustable torque control How to use and what it is used for and how would it help me while working with my drill.
The torque settings on a drill will stop the drill from driving the screw ( or what ever you are tightening ) when it reaches a specific "tightness" . For example; the setting "1" will only tighten a screw a very little bit, while " 14 " will tightten the heck out of it.
Note: once the screw has reached it's specific torque ( or tightness ) the drill motor will continue to turn but it will disengage the driver, making a kind of grinding sound,it's perfectly normal so don't be alarmed.
Dec 29, 2010 | Dewalt 18 Volt Compact Drill Kit
Hello my drill bit holder is stuck open and the fingers that hold the drill bit won't come out of the housing no matter how hard I turn it.
If you go to this URL you will see a screw that is #1 in the exploded view.
http://www.ereplacementparts.com/ryobi-p206-18v-2speed-drilldriver-parts-c-7931_8051_8064.html
If the chuck on your drill is open you might be able to access this screw. It appears that this screw holds the chuck onto the drill and removing it might allow you to remove and then replace the chuck. I am not 100% sure of this, but it looks like a good place to start.
Sep 15, 2010 | Ryobi 18volt 12" Cordless Drill Model P206
Amount of torque per setting in dewalt dc925 xrp
The torque settings are not tightly controlled so they are not all that repeatable from drill to drill. They also vary somewhat with the speed of the drill and the condition of the battery. And they aren't linear (a setting of 10 is not twice the 5 setting) Simplest thing to do for a rough idea is to use your hand to hold the chuck still to feel how much torque you have at each setting. (start low and grip it tight!) If you want a specific torque setting, say 10 ft-lbs, then put a stout screw in a scrap of wood, hang a 10 lb weight on it 12 inches from the screw and adjust until it just starts to slip.
Apr 02, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
The front clutch housing on my Skil 2887 Xdrive 18Volt drill is loose and the chuck wobbles as a result. I can't find an exploded view to see what I'm in for if I decide to open it up. Is the fix difficult...
If your drill is less than one year old it is under warranty. If not, get a firm estimate from any skil repair center. To locate one near you go to skil.com
Sep 18, 2009 | Drills
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
