Question about Kenmore Washing Machines
Washing machine stopped between rinse and spin cycle. Water still in machine and won't run. When attempt to move dial and engage switch a humming noise starts but nothing happens.
  • 2 more comments
  • Czerney Dort Mar 21, 2011
    Is the humming noise the motor
  • busa66 Mar 21, 2011
    HOW DO YOU FIX A CYCLE TIME OR WATER PUMP?
    Thank you for a possible solution. I will start with the cycle timer.
    I do appreciate your exact answer on the humming noise and its possible exact solutions. Thank you!
    Genius:
  • 1,114 Answers
This could be either one of two things, and that is that you have a bad cycle timer, or a bad water pump. Either would give you the humming noise that you are hearing.
Posted on Mar 21, 2011
  • Charles Huckeba
    Charles Huckeba Mar 21, 2011
    The cycle timer is the easier of the two to replace, all you will need to do is take the model number to an appliance repair shop and pick up a new one, then take the back cover off of the washer, remove and reinstall. If it is your pump then you will need to drain the water out of the machine, and lay it on its side, and then you will have access to the pump. Unless you are skilled at this procedure, I would advise letting a specialist perform the work.
  • stphnjcks
    stphnjcks Aug 31, 2012
    i so appreciate your answer too. Im unemployed and cant afford a tech. How can you tell if its the timer. i took the bottom off andfound a book underneath. ( iguess for the tech) I did a test. at first it did nothing but hum. but after the test. it goes thru mostly all the cycles except spin. Im tired of draining the water out. I also took out the filter and rinsed it. i might have a problem putting back the metal clip back on. So agigated
2 Suggested Answers
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
AMD 121 won't shut off, or change cycles. Continuously "hums".
Did you try just unplugging from the wall outlet, and let sit for 15 seconds and plugging back in. Sort of like a re-boot on the computer? Just a suggestion.
Jun 30, 2014 | Ariston Technologies AWD 121
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Control dial moves along fine but drain,spin, rinse never happen
replace the water pump. about 46 dollars and a 20 minute job.
Jun 24, 2009 | Maytag Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
341 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
