Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Our rca hdtv monitor will work for approximately 15 mins before turning itself off then on and off again two more times. also the left side of the screen is starting to show a little more blue than usual. upon removing the speaker cover and the front cover beneath I saw what looks to be oil dripping down from the blue light inside. any ideas and cost estimate
  • 1,476 Answers
Pidksmith,
If you see something leaking from the blue tube it is probably coolant. You will need to find the leak and repair it and fill it with the proper amount and type of coolant. Projection TVs with CRTs have to have coolant covering the face of the CRT or they will overheat. Sometimes they can develope a leak. You will need to unplug the unit and remove the rear lower cover. Looking at the blue CRT from the top you should see 4 screws holding the lense on to the crt. Do not remove any other screws or you will change the mechanical focus. Remove the lense and look for the leak. If it can be fixed use good epoxy to seal it. Order a bottle of CRT coolant from http://www.mcmelectronics.com . There should be a filling port on the top of the crt. Fill the chamber to the required level, close, reassemble and you should be back in buisness. If the leak cannot be fixed you would have to replace the crt. I have a tip for that at http://www.fixya.com/support/r4573850-change_crt_in_projection_tv which explains how to do this.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Mar 21, 2011
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
Hi, I have an RCA HDTV SRS WOW Model RCA L32WD12YX5, Serial G482CJ060. It powers on and has sound for about 15 minutes then shuts itself off and restarts with no sound. As an experiment, I used the Menu...
The tv main Tuner signal board have problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jun 09, 2011 | RCA L32WD22 32 in. LCD HDTV
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
RCA R52WH74 that will shut itself off
Replace 3 capacitors on Deflection board its the bottom left hand side cp150 200uf 16v use 25v capacitor and cp114 cp120 in same circuit 220uf 35v. You will see cap cp150 if it is puffed up on top they are Bad. Call Mats Electronis 1-800-628-1118 Radio shack might have capacitors.
Dec 29, 2009 | RCA R52WH73 Projection Television
MY 50" DLP RCA picture goes on and off again. I still have sound, but it seems like it keeps wanting to reset itself. The lamp is only 15 months old! This problem is interminent. Some days not at all, and...
Is the cooling fan working? If the fan is not working lamp may be overheating. Check to make sure the fan is working. I believe the fan should be on all the time.
Sep 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Sometimes the tv turns off after about 15 mins. and will not turn back on for about 20 mins.
Check capacitors on deflection board cp120 cp111 cp114 And cp150 most of the time If cp150m is puffed up on top it is Bad 2200uf 16v replaceother 2 caps that are 220uf 35v.
Aug 11, 2009 | RCA R52WM24 52" HDTV Projection Television
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
RCA D52W20 Intermittent Power Issue
your problem is intermitent resolder the power supply the horizontal along with the area of the flyback you could be having some lose solder also resolder.if that does not work check around in the power suply some bad cap,power regulator and even the flyback again.a check should be made on the microchip.if you cannot do it your self take the set to a tech.good luck
Mar 29, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
