If your bandsaw doesn't feature in any of the catalogues of the major blade suppliers it is probably an unusual size and unless available from the original manufacturer or importer you will probably need to have blades made to order or buy a length of blade and using a blade repair kit, produce your own.
A great many blade suppliers will produce a custom blade, either from supplied dimensions or from a supplied pattern.
the circular blades for all compound saws have two important specifications. 1. the arbor size (the center hole in the blade and the diameter of the blade (usually 10" or 12"). After determining that you can choose the number of teeth on the blade. Not all blade manufactures offer every diameter, arbor size, and number of teeth.
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30 ShaverOutlet com Search results for oster 76
There should be enough adjustment on the tensioner to allow you to use any size blade that will be close to the original size. Set the tensioner/adjuster to the mid position measure the size of the blade, and look for one close to that size.
Try calling an electric motor shop near you, otherwise you can call Grainger and see if they have one. You will need to know the blade size, shaft size. pitch and rpm rating of the fan blade.
This is a part number.46 inch (three blade) 18 HP TMO 3400005A
MTD makes these mowers.You should be able to use those part
numbers to purchase replacements.You can find online at the mtd web
site,or Lowe`s and wal mart sell those,or at least some of those parts.
the lever on the clippers locates into the cutter of the clipper blade its only a matter of lining the lever up with the slot in the top blade which you can slide from side to side by hand. Please keep in mind wear on this plastic Drive Lever may lead to cutting problems.
