Question about Phoenix Gold XS2300 Car Audio Amplifier
Power wires are 3? other then red & block wires what is next conector for?
    Scholar:
  • 156 Answers
You have 3 sets of wire connecting to the amp (besides the rca connection), Red is power from the battery, Black is the round wire (shorter the better), lastly Blue is the remote turn on wire. Without the remote turn on, your amp will not power up regardless of the power from the battery.
RCA connectors are for your audio, it carries the noise signal to your amp from the head unit...
Posted on Mar 21, 2011
40amp fuse to fuse block keeps blowing (fuse #3 in the manual)what color is the wire off this fuse so I can trace this to the fuse block this is on a 1992 jeep Cherokee laredo
Confused. #3 in the diagrams is 10 amp dome light. Are you talking about the starter relay fuse that powers the solenoid? That circuit has a red wire from the ignition switch to the fuse. After the fuse, the wire is black/red to the start relay. After the relay, the wire is brown to the starter solenoid.
Sep 15, 2017 | Cars & Trucks
Where can I find a service manual? I need to change the 3 wire power cord to a 4 wire cord.
first install the RED & BLACK conductors on the cord to the L1 & L2 terminals or the 2 outer terminals on the 3 position terminal strip on the dryer,next take the WHITE ( NEUTRAL) wire on the cord connect it to the "N" terminal on the dryer terminal strip usually located between the 2 phase wires RED & BLACK so the terminal strip will be(RED-WHITE-BLACK) red & black can go on either outer terminal as they are not polarity sensitive due to the A.C. current, then the GREEN on the power cord goes to any metallic portion on the dryer case
Aug 23, 2012 | Maytag ADE7005AYW Dryer
Mass air flow issue
Check for voltage at ecm conector pin #54 it should be a red wire. With the engine warm and idling you should have 0.9 - 1.8 dc volts then rev motor to 2500 rpms and you should have 1.9 - 2.3 dc volts. make sure you ground your multimeter to the bat or engine block. DO NOT ground to ecm or any ground wires that lead to the ecm.
Mar 22, 2012 | Cars & Trucks
Need a to change power cord from a 3 prong to a 4 prong on a maytag neptune electric dryer an I need the color codes
RED & BLACK go to L1 & L2 POWER terminals on the dryer (polarity is NOT aw factor on these 2 wires) the WHITE wire goes on the N- NEUTRAL terminal usually the center terminal between the 2 POWER terminals on the 3 terminal power block on the dryer,then the GREEN wire is the safety ground and is connected on any METALLIC spot on the dryer case,usually theres a screw somewhere just off the 3 wire terminal block mentioned above
Mar 08, 2012 | Maytag Dryers
Battery will only keep a charge for roughly a week. After sitting
SOUNDS LIKE THE BATTERY IS GETTING OLD, THEY NORMALY LAST ABOUT 3 YEARS WITH CONSTANT USE, DO YOU HAVE AN ALARM THAT MAYBE DRAINING THE CHARGE OFF IT? YOU SHOULD ALSO REMOVE THE PANELS LOCATE REGULATOR RECTIFIER, AND CHECK THE CONECTIONS AT THE BLOCK CONECTOR, SEPERATE THE BLOCK AND CHECK THE CONDITION OF THE CONTACTS FOR COROSION INSIDE, ALSO LOOK AT THE OUTER OF THE BLOCK WHERE THE WIRE GOES INTO THE BLOCK PARTICUALY AT THE RED WIRES AS THEY ARE PRONE TO COROSION, IF THIS IS THE CASE TAKE CARE NOT TO BREAK THE WIRE AND MIX THEM UP, CAREFULLY REMOVE 1 AT A TIME AND REPLACE WITH OTHER CONECTORS, JUST A STAB IN THE DARK HOPE THIS HELPS
Oct 29, 2010 | 2003 Yamaha V Star 1100 Custom
Alpine 9887 no incoming power supply. Incoming vcc checked ok at conector level, 10 amp fuse block not blown
did you check power at both the red and yellow wires? also, make sure you have a good ground.
Sep 10, 2010 | Alpine CDA-9887 CD Player
Hi we had to move & unplugged the DVD/R & I dont know where to plug the cords back into the back of the player or the TV. I can get video ok but no sound. Thanks in advance.
unplug the red and white cables from dvd , next, plug only white cable in the white conector of the dvd and listen the audio, if is not ok, try in another white conector of the same dvd until you obtain good sound, do the same with the red cable.
Apr 10, 2010 | Samsung DVD-R130 DVD Recorder
I bought new lights for my bathroom , they have 3 wire conectors , the lighting loom has 4 wires, green, black , red and white, how should i connect the new lights?
CONNECT GREEN TO GREEN/ BLACK TO BLACK/ RED TO RED , CHECK TO SEE IF THE WHITE WIRE HAS POWER , AND IT MAY BE THERE FOR ANOTHER USE.
Oct 24, 2009 | Kitchen Appliances - Others
Rf top ac on rv keeps blownig the 3 amp fuse
The 3 amp is 12 Volt protection for the control board. If that fuse is blowing instantly, then you have a short in the 12 Volt system somewhere. More than likely it is somewhere between the Thermostat and the control unit. Check to see if you have 12V at the thermostat. If so, then disconnect the red wire from the thermostat and the red wire at the control unit. At the control unit side, use an Ohmmeter to see if you have continuity with ground. If so, that wire is the culprit. If not, reconnect the red wire and continue to the next wire. Do this until you find the wire that is shorted to ground. Of course, the ground wire will not be checked.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Phoenix Gold XS2300 Car Audio Amplifier Logo
180 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
hoyzee1
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
