Question about Canon PIXMA iP3600 Photo Printer
What paper feeder does the 4x6 photo paper go into to print a photo
  • 823 Answers
Pull the paper out of the feeder tray. You will see small marks and a sliding plastic lever. use the picture to determine whether the photo paper is loaded face down or up and then slide the lever over until it hugs the photo paper snugly.
Posted on Mar 21, 2011
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
My printer keeps using the paper from the main tray, not the photo paper in the 4X6 tray. Where do I change this setting. I have it set to "photo" and 4X6 in the options. Is there a way to...
The option you are after can be found on the Print screen, if you click on the button saying Printer Preferences. Normally you will have multiple tabs, so click on the one saying Paper and on the Paper Tray option select Manual Feeder.
Nov 13, 2010 | HP Photosmart C6280 Printer
How to load 4X6 photo paper
hi
  • Turn on the Epson 875DC and the attached computer. Make sure the cable between the two devices is securely in place.
  • Step 2 Remove any paper that is in the printer's feeder tray. Place the 4x6 photo paper printable side up in the tray, with the support sheet at the bottom of the stack of photo paper. Adjust the paper guides so they are pressed against the margins of the paper.
  • Step 3 Open the photos to be printed in your computer software program of choice. When you are ready to print the photos, click on the "File" link at the top of the window, then choose "Print." Click on "Properties" and select "4x6" for the paper size and "Photo Paper" under the paper type. Click "OK" to close the "Properties" window, then click "OK" again to print the photos.
  • Jul 02, 2010 | Brother MFC255CW All-in-One InkJet Printer
    How to set for 4x6 photos
    Nothing special to set for 4x6, you lust slide the paper guide over to the 4x6 paper and stand the paper up in the paper slot in the back. You have to choose 4x6 print in your printing software window in printing preferences.
    Jan 31, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
    Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
    Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Trouble feeding paper into printer
    call our technician on toll free no 18884276640
    Jun 23, 2009 | Canon Pixma iP6600D InkJet Photo Printer
    Using attachment to print 4x6 photos
    The usual cause of this problem is too much 8 1/2 by 11 inch paper in the normal feed slot. Take most or all of the regular paper out of the tray before setting the photo feeder onto the front of the paper slot. When installing the photo feeder, make sure the photo paper container is extended by turning the big dial to the 2 o'clock position, then rotate the dial to the 10 o'clock position after the feeder is in position. Don't overfill either the photo feeder or the regular paper tray. It's pretty fussy about position and fit of the paper in the photo feeder.
    Feb 21, 2009 | Canon i860 InkJet Photo Printer
    Want to print 4x6photos on 4x6 paper on my hp deskjet 5440.
    using the paper tray/feeder. Just slide your paper guide over until it's snug, not tight. photo paper should be inserted vertically not horizontally. Set your printer settings to photo quality & photo paper. Hope this helps.
    Dec 27, 2008 | HP Deskjet 5440 InkJet Photo Printer
    Printing onto photo paper from mac g4 computer
    I put the 4x6 in the bottom cassette. I place it with the shiny side down. Landscape is when the 6" length is front to back in the tray.
    I use the cassette exclusively for 4x6 and use the back tray for all else. It works great.
    Apr 20, 2008 | Canon MP610 Photo All-In-One Printer
    Printing photos
    Of course you can use 4x6 photo paper
    you have select the paper size from page setup as 4x6
    and put the paper in the tray after adjusting the tray size
    Dec 27, 2007 | Samsung CLP 300 Laser Printer
    Canon PIXMA iP3600 Photo Printer Logo
    312 people viewed this question
    old marine
    old marine
