My recently added laptop is connected to my wireless router but can not access the internet...thanks
    Sergeant:
    Novelist:
  • 164 Answers
Try to do the following steps.
Go to run and type in cmd.
On a command box type in the word which is on bold letter.
Reset TCP/IP stack to installation defaults, type: netsh int ip reset reset.log
Reset WINSOCK entries to installation defaults, type: netsh winsock reset catalog
Reboot the machine.
Posted on Mar 21, 2011
Randomly disconect wireless internet
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 27, 2012 | Gateway M-7315U Notebook
Hi I let my neighbor use my wirless internet now I think they saved the password and are using it at their free will i my computer recently broke and I lost the driver what can I do to change my wireless...
You are able to access your wireless router from a mobile device (at least, I was from my Android smartphone). Enter in the ip of your router (if you are unsure, look up the default IP for your router model on google) and enter in your username and password (again, you can also find the defaults of these if you are unsure). Once you gain access to the router, you are able to then change the password. I would recommend doing this as then your neighbors will no longer be able to connect.
Feb 28, 2011 | Computers & Internet
I have recently added a laptop to my wireless internet which my ps3 runs off also. I haven't had any problems conneting to the internet until I added the laptop, now it doesn't want to connect. I went...
the wep key as it is commonly referred to, ( ~10 digit letters and numbers not cap sensitive) is a passcode to gain access to a internet through the wireless router only things i can think of are A. you put it in for your console along time ago and don't remember putting it in B. you changed the setting of wireless router to get it to work for laptop C. your stealing someone's internet and they decided to add a passcode to get in it
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
I have a 2wire router from AT&T and I cannot access the internet using my laptop. I am able to connect wirelessly but only locally. I recently added an adapter for my Direct TV to access movies on the...
I've never had any restrictions, I have an internal router, and several computers and devices access the internet through my AT&T account both wired and wireless. I don't know anything that would prohibit you using a machine to connect to the internet through one of their routers, and the fact that it can connect locally, if by locally, you mean you can access other devices connected to the router, then as a network analyst, computer guru, the only thing that I can think that 'might' interfere is your IP address on your computer; but, that would restrict the other devices from connecting to the internet too, or the laptop but not both. But, to me it sounds odd that you have such an issue, it has to be the way the network is configured on your laptop. If you know, you can check this through the DOS or Power Shell on your laptop. I presume it's windows, at the prompt, if windows, just type
ipconfig /all <return> = C:\ipconfig<sp>/all<return>
to check your network card IP and mask settings for all devices that could connect to the internet. Perhaps your laptop is IPv4 and the AT&T is set to IPv6 only, something like that.
Jul 03, 2017 | 2wire (2701HG-B) Wireless Router
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Amit
Jan 07, 2011 | Linksys WRT160N Wireless Router
My wifi doesn't connect to any routers but it connect to my laptop ad-hoc.Still i am not able to use internet through ad-hoc.I have tried restoring my iphone, reset and erase settings, reset network...
Ad-hoc is a computer to computer connection.
You need to change the wireless configuration to Access Point (Infrastructure) mode with encryption.
Your wireless card in your computer or laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 30, 2010 | Apple Cell Phones
Added another laptop but does not access internet
your router may be limited check this video to see what I mean...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 27, 2009 | Computers & Internet
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Compaq n6120 - can't connect wireless
Most wireless networks are setup as infrastructure networks, meaning all communication is to/from a wireless access point/router that serves the same function as a switch/hub in a wired network as a central point to transfer communications from machine to machine. One works over the air the other through a wire.
There is an alternate form of wireless networking refered to as ad hoc -- in this version of wireless networking every wireless adapter can "talk" to any other wireless adapter configured with the same SSID (name) and security encryption (none, WEP, WPA). This is how somewhat less impromptu wireless networks are created similar to impromptu infrared networks some of us have used. One limitation of the ad hoc networks I have seen configured to date is access to the internet. I have posted an article where a stationary PC (required to be running for any other wireless machine to access the internet) with a wireless card in ad hoc mode could act as the router for wireless network but it required a cabled connection the internet. I suppose it could be a second wireless connection on a separate channel with a second wireless adapter in an infrastructure network but why? These types of networks are only recommended in another article for a limited (small) number of machines.
Based on this are you asking to create an ad hoc network to connect 2 PC's wirelessly without a wireless router or access to the internet from the wireless network (without a dedicated machine)?
Dec 19, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
