Question about Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
My water is black. is it now unsafe to use? - Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
    Brigadier General:
  • 4,736 Answers
The question is why is it black? Is it mold or mildew? Has the unit every been cleaned and flushed regularly? If you answered NO, to the last question, that may be the problem. You can flush the system by using a 50/50 solution of White Vinegar and Bottled Distilled Water. After doing that, wash the interior of the water container with soap and water. Then run another flush cycle of Bottled Distilled Water. In the future, if this was the problem, use bottled distilled water only for humidifying purposes.
If the above was not the problem, there may possibly been some type of oil leak from the motor or one of the rubber gaskets is breaking down and polluting the water. Until you solve the problem, discontinue using the unit.
Posted on Mar 21, 2011
Why does my machine keeps turning off
This question needs to supply more information than it currently does. Who manufactured your humidifier? Model of your humidifier? Details about when it 'shuts off', such as water level, temperature, etc.
Most humidifiers are designed to shut off when conditions reach an unsafe condition, such as water level too low. Generally this is sensed by some sort of float telling the device to shut off. Another method used is by monitoring the temperature in the device, after all 'humidification' is done by evaporating water into the surrounding air. If the temperature rises above 212 deg f (boiling point of water) it thinks there isn't any water left to add to the air so it shuts off for safety reasons.
The best course of action is to contact the manufacturer directly for details.
Apr 02, 2015 | Humidifiers
Black chunks and water after use of V150SG Vicks Steam Guard Vaporizer.
The black specks could be caused by interaction between the heating element and mineral content in the water.
Mar 25, 2014 | Vicks V150SG 1.5 Gallon Warm Steam...
Replace water panel
Hello, if your asking how to replace the water all you need to do is buy a replacement water panel, and make sure the side with the black mark is pointing up.
Dec 13, 2011 | Aprilaire 400 Humidifier
I am having the water turn black even with daily water changes. Also when cleaning out the filter there are black flakes. Do I need a new machine. This one is only 6 months old.
If it's still under warranty, return it for replacement or repair. You will need your Proof of Purchase to do this. Something is leaking internally and contaminating the water.
Mar 27, 2011 | Vicks Healthmist 4100 Humidifier
Why is my humidifier forming black percipitate in the tank? how can i remedy this
The black particles are pretty common. This is a byproduct from minerals in the water and is normal.
Just clean the tank regularly (with diluted bleach). The black particles will also collect in the steamer unit (the top blue part). Wash this out with hot water (no soap or anything) after each use. If you tap it a few times on the floor of your bathtub you'll probably see some of this black stuff come out. No worries, just rinse again with hot water.
There's no harm from the black particles.
Feb 28, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Water doesn't shut off completely (drips) when furnace is OFF. Water doesn't increase to a stream when furnace is ON. Also, black connection (regulator ?) between copper water pipe (inlet) and black...
Hi i would check you water line see if they are blocked and checkout the valve and the jet inside where the water goes donw the pad they could be blocked
Feb 11, 2010 | Aprilaire 550 Humidifier
Aprilair 550 water running but not trickling through filter
it hard to see make sure the filter is in the upright position i believe they mark it with a black strip. you want it so the little v's are catching the dropplets or water otherwise thats normal but make sure you change it every season.
Nov 21, 2009 | Humidifiers
Honeywell True Steam heats but continuosly drains / vibrates
I had the same problem.
I replaced the solenoid which resulted with the same problem.
I then blocked the drain using a ball valve, that resulted in the humidifier overflowing.
I do have a fault code (3 blinks) indicating failure to fill tank.
However, if this were true, blocking the drain would have solved this problem.
I have replaced the unit with a new one, and it is now working perfectly.
If you have covered all these bases then I suggest replacing your unit. Hopefully it's under warranty.
Cheers, Rich
Feb 22, 2009 | Honeywell Power Humidifier: Furnace...
Water Leak
there is a nozzel at the end a black tube at the top of the hummidifier that has come off or the tube is cracked
Dec 24, 2008 | Aprilaire 550 Humidifier
Humidifier leaves a crusty dark substance in water
SPECIAL NOTES
Discoloration/Black Particles
After use, the water residue in the bottom of the container may contain black particles, and, in
some areas the water and the bottom of container may discolor. These conditions are normal and
do not effect the purity of the steam or medicine. The container is easily cleaned with soap and
water. Rinse and dry the container after cleaning.
This was taken from the manual that comes with the humidifier...
Dec 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Logo
400 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
