Question about Whirlpool Washing Machines
I washed 3 pairs of tennis shoes in my whirpool duet . f22 came up and my door is locked
    Sergeant:
  • 170 Answers
I have post on here to get front load door open//click on my name..good luck
Posted on Mar 21, 2011
  • 294 Answers
Your questions has been asked before and here is where you can find the answers on Fixya
http://www.fixya.com/tags/whirlpool_duet_f22
Hope this helps. J
A pair of running shoes costs $5.00 more than a pair of regular tennis shoes. The total cost for both is $115 Find the price of the regular tennis shoes
You will never learn any mathematics if you do not solve math problems. I am here to do your homework. I will however help you set the problem up.
1. Define variables (unknowns).
2. Let t be the price of the tennis shoes
3. Let r be the price of running shoes.
Translate the text into mathematical expressions
A pair of running shoes costs 5$ more than a pair of tennis shoes
5 $ more ---> ... +5
Cost of a pair of running shoes (r) = cost of a pair of tennis shoes (t) +5
So the first statement can be expressed as r=t+5
The total cost of both ------> Sum of the costs r+t
The total cost of both is 115 $ ------> r+t=115
Now you have a system of two linear equations in two unknowns
( r=t+5
(r+t=115
There are a few methods to solve the system (comparison, substitution, or combination/addition/elimination). I gave the 3 possible names for the third methods.
Choose a method and solve the system to find t and r.
Note: Although all three methods, if carried out correctly, will give you the same solution (t,r), one of them should be preferred. It is worthwhile to recognize immediately which method should be favored depending on the system you are dealing with.
Oct 29, 2013 | Clothing Accessories
Whirlpool Duet Washer F22 Error Code Follow-up
1) F22 mean DOOR LOCK ERROR , this problem can be a) switch for open or defective b) loose wires or broken wires, test by continuity VOM .
2) adjust the Door vs switch very well for propely closed, and test the closed switch.
3) see if the color are missing and put in the WRON terminal.
God bless you
Jun 28, 2012 | Washing Machines
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-22 is my error code. What is that?
F22 DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Nov 25, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
F22 code ?? duet locks but will not run
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet had code of f22. door was locked, i manually got it open but now the controls still do nothing. i tried resesting..
Switch on the machine. Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Feb 23, 2010 | Whirlpool GHW9300 Duet Washer
Washer door is locked and won't open. Error code
DOOR LOCK ERROR
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal De
