Question about Whirlpool Microwave Ovens
Whirlpool range top microwave model #mh1150xms-4 has trouble code F2.
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave mh1150xms-4 code f2
F2 on a Whirlpool is a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
BUT If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 05, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool MH1150XMS-3 F2 error message
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
The part number to order is 8205031 (formerly 8204739) and you can get it here for $140.37 plus shipping.
You can also find helpful exploded view diagrams at that link.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
Posted on Sep 12, 2009
  • 400 Answers
SOURCE: HOW DO I GET TO THE HANDLE ON A WHIRPOOL OVER THE
Look here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135344&diagram_id=1301811#d1301811 Perhaps there are other places. Do a google search for mh1150xms parts. I hope this helps you.
Posted on Nov 20, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Model # MH1150XMS-3 F2 Error
"F2" on a Whirlpool means you have a shorted membrane keypad. It's not uncommon for it to be intermittent or partially operable, too.
On some models, you have to peel off the old keypad and stick on a new one.
On some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple DIY job.
You can find helpful exploded view diagrams and order parts by entering your full model number (with suffix) from the tag on the oven
here.
If you have to replace the frame, you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Posted on Jul 10, 2011
My whirlpool microwave oven will not power up and shows a code f2. how can i fix it
its an error need to call technical assisstance ..thAT error ranges for faulty temp sensor/probe up to control board ....
Aug 05, 2014 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
Whirpool Micro Wave oven turntable not working model MH1150XMS-2
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 21, 2011 | Whirlpool Microwave Ovens
Microwave Model # MH1150XMS-3 F2 Error (Short in membrain keypad
here.
Jul 07, 2011 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool ADG 4956 - problem F2
Hi, here is the answer for f2 "F2 - error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
Apr 24, 2011 | Whirlpool Microwave Ovens
My new Whirlpool oven Model number GBD 279 PVS02 error code EO F2
F2 E0 is a shorted keypad. Replace the keypad which is your entire touch pad. In rare cases your ERC or electronic range control can also be bad, unlikely though. Hopefully this is still under warrantee as the part alone is over 150.00. I recommend you have a technician replace this as most parts houses will not warrantee a electical part if a customer installs it. Good Luck, Appliance Specialists.
Dec 15, 2009 | Microwave Ovens
William E. Miller
prototech@usa.net
Sep 09, 2009 | Microwave Ovens
Display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
determined from whirlpool that the f2 display is from the control circuit board. the board's problem is intermittent and needs eventually replacing. not covered by warranty. determined that whirlpool has reduced the warranty for the electronic circuits in its appliances from 5 to 1 year. this is great for consumer confidence in whirlpool. have had trouble with 2 other new whirlpool appliances. probably will not buy another whirlpool appliance.
Aug 01, 2008 | Whirlpool GH5184XPQ Microwave Oven
Microwave mh1150xms-4 code f2
prototech@usa.net
Jun 10, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
161 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
