Question about Garden
Victor spitfire motor type lawnmowers pullstart. The pullstart is not working, its not the pullcord/spring return system that is the problem, it is not engaging anymore to the plywell well that it needs to do, looks like it is missing a spring or expanding grab blocks to grab onto the alloy mounting that is attached to the flywheel bit ? can anybody help please. Thanks Toddy
  • Kelly
    Kelly Mar 21, 2011
    Is this a Victor or Victa? As far as the pull start / recoil. Most of them use friction on a center piece to pivot out the drive pawls to gran the flywheel adapter. You should be able to grip the center piece and see if the the pawls come out. If it rotates and you do not see any plastic pawls they have broken and will need replaced. If you see them...then there is a friction problem that is usually caused by dirt / corrosion or a broken thrust washer / spring.
    Kelly
    Top Expert:
  • Garden Master
  • 12,962 Answers
Either the pull string has un coupled or the little fingers that are part of the start assembly are not engaging the motor. If latter, you need new start assembly. Ouch.
Posted on Aug 29, 2017
KMusselmann
  • 247 Answers
SOURCE: Pullcord
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Posted on Mar 19, 2009
Skinnerd1
  • 13 Answers
SOURCE: craftsman air compressor bearing flywheel
Your local hardware store should have one. The model number will probably not help; you will need to measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
Hope this helps.
Posted on May 22, 2009
  • 420 Answers
SOURCE: My Flymo microlite 28 lawnmower is very noisy...
You got it, replace the disc before you use it again.
Posted on Aug 28, 2009
SOURCE: Brand new Pope Spitfire 40 lawnmower won't start
Caren,
Drain the fuel completely if it is older than 1 week. Make sure you undo the bolt at the bottom of the fuel bowl to ensure all old fuel is drained. Refill with fresh fuel (premium unleaded) and try again. If it still does not work then remove the spark plug and rest it on the metal of the mower while still attached to the silicone ignition wire. Have someone hold the cut out bar to the handle (as you normally would to run the motor) and pull the cord. You should see sparks being emitted from the spark plug. (Make sure there is no fuel nearby) If you cannot see any sparks then replace the spark plug with a new one and repeat this process. If you still cannot see any sparks being emitted after attatching the new plug to the silicone wire, resting it on the metal of the mower, and pulling the cord to start it as you normally would, the mower will need to have the resistor and capacitor checked by a professional repairer as no spark is being generated.
Good luck.
Allan
Posted on Oct 25, 2009
Plug type on the pope spitfire 40 push lawnmower
typical pope
spark plug type not mentioned in the user manual
the owner is expected to keep the original plug and buy the same one every replacement
luckily spitfire 40 use a briggs and stratton 4 stroke
so not too many variables
take the one fitted in it with you
could be any equivalent to a cj8 to J19 with a short thread
Sep 06, 2016 | Garden
What is the correct plug for the pope spitfire 40 lawnmower
2000 Sportsman 500. How do I reinstall spring on rewind start cord?
An easy way to fix a pull start recoil spring . - YouTube
? 8:48
https://www.youtube.com/watch?v=d4r8wbejHXY
Feb 19, 2013 - Uploaded by chaseme81871
Thank you so much! I was able to find the pull cord at a local home depot store and when when my husband ...
How to rewind a pullstart spring - YouTube
? 5:05
https://www.youtube.com/watch?v=qTcL3_3leTk
Mar 13, 2010 - Uploaded by lenniepincher
If you ever need to rewind a un coiled pullstart spring. ... ( NEW VERSION ) How to Rewind and Replace Recoil Starter Spring - Duration: 3:53.
Nov 24, 2015 | Polaris ATV
How to set timing on honda lawnmower HRR216TDA
There should be dots on the cam gear and crank gear that have to align, however a simple way to sheck if the timinh is correct is to set the piston too top dead centre non compression stroke, the exhaust and inlet valve should both be rocking
Jun 16, 2012 | Garden
Victor 4 stiff trigger
If it is a coil spring system just remove a couple of coils--carefully.
Sep 05, 2009 | Sport & Outdoor - Others
Shrieking Lawnmower!! I hit small tree branch w/ walking non-drive 3.75 hp Briggs and Scrap-Iron "Sprint" off-brand gas mower. Started shrieking like banshee. Resulted in tangled pull-cord. So I removed...
sounds like you have dirt in the recoil clutch, (under the screen) or you bent something there. try removing the clutch and make sure shaft is very clean and lightly coated with oil. This would be for a briggs and stratton engine.
Jul 25, 2009 | Garden
Pullcord on my Craftsman 6.0 lawnmower does not pull, seems to get stuck before engine turns over. Took top cover off to see if there was an obstruction, did not see one. Is this something I can attempt to...
It's likely the rope came off the pulley and is lodged in behind it. They usually can be fixed by bending back some tabs or taking out a bolt to let the pulley come out a LITTLE. Be carefull because the rewind spring behind it will unlatch if you pull too far. It's not that strong but it will whip around and it has a sharp end
Jul 01, 2009 | Garden
Pullcord violently retracting on Craftsman lawnmower
It is possible that the 'dogs' that engage the crankhaft were stuck in the out (engaged position). Once the engine started, it wound the rope in the opposite direction until the dogs slipped and retracted. Romve the top cover that includes the pull start unit. Check for smooth and sticky free operation while pulling on the cord. Try using a very light oil to lube if nessesary.
Apr 29, 2009 | Sport & Outdoor - Others
Pullrope broke on weedeater 550 how do i get it apart to fix it
ther eshoul dbe some bolt holding the pullcord/recoil assenbly to the flywheel/motor. you need to locate and find these bolts first. let me know when you have this apart. you have to unwind the rope and pull it completley out, then buy a new pullcord rope(other rope will just fray and break agai) slip it thru the holes tie a knot wind up the spring and carefu;lly place it back on were it came. let me know if you run into any trouble.
Apr 23, 2009 | Poulan Pe550 Gas Edger
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
