Question about Dynasty DGRSC 30 Gas Kitchen Range
Oven igniter comes on but won't ignite gas unless door is opened
  • Dynasty Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Mar 21, 2011
Oven,broiler won't light
The igniter is the most commonly defective part for a gas oven that won't turn on. The igniter has two main functions. First, the igniter draws electrical current through the oven safety valve to open it. Second, the igniter gets hot enough to glow and ignite the gas in the burner assembly. If the igniter gets weak, it will fail to open the safety valve correctly. If the valve does not open, the oven will not heat. To determine if the igniter is defective, observe the igniter when the oven is on. If the igniter glows for more than 90 seconds without igniting the gas flame, this indicates that the igniter is too weak to open the valve. If the igniter is weak, replace it. If the igniter does not glow at all, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Kenmore Oven Won Turn on
Jan 20, 2016 | Kenmore Kitchen Ranges
Tip
Replacing an Oven Igniter on a Gas Range
This advice is for GAS ovens with glow bar type igniters. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance. But, first, here’s a little gas oven theory to help you better understand how to determine if an igniter is bad:
The way the ignition system in most of today’s ovens work is like this:
  1. Set the oven or broiler temperature.
  2. The igniter begins to glow.
  3. Once the igniter reaches a certain current potential, the gas safety valve opens.
  4. Gas is introduced into the manifold and you have ignition.
  5. NOTE: It can take roughly 30 – 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That’s why you typically don’t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn’t light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it’s an easy assumption to make that the igniter may be bad, if one or the other doesn’t light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we’re going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
  1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
  2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
  3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
  4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
  5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
  6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
  7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
  8. Reconnect the wires using the recommendations mentioned in Step 5.
  9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
  10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models. I hope this information is helpful.
on Dec 04, 2009 | Kitchen Ranges
Tip
on Feb 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven and broiler won't work surface burners ok
Troubleshooting Why Your Gas Oven Won Ignite or Heat PartSelect com
Gs773lxss0 will not light
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Oct 21, 2013 | Whirlpool Ovens
Stove top burners work but when the oven is turned on it looks like the pilot light will glow but will not ignite the oven
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
Gene...OldTech2332
Aug 22, 2011 | Maytag CWG3100A Gas Single Oven
KESC308LLSO Both of the left -side cooktop eyes won't turn on (the right-side work fine), and the broiler element won't turn on. Our home electrical box was struck by lightening and has been...
Hi,If the model range you have this listed under is correct, the problem more than likely is a bad igniter on the Bake manifold. Each manifold has its own igniter. Since the bake feature gets used more often it tends to wear out faster. The following link explains oven igniters and how to replace one:
This advice is for GAS ovens with glow bar type igniters. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance. But, first, here?s a little gas oven theory to help you better understand how to determine if an igniter is bad:
The way the ignition system in most of today?s ovens work is like this:
NOTE: It can take roughly 30 ? 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That?s why you typically don?t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
Carborundum (Cylindrical in shape) ? needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) ? needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn?t light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it?s an easy assumption to make that the igniter may be bad, if one or the other doesn?t light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn?t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won?t light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we?re going to assume you have a bad igniter and need to replace it. Follows these steps:
Open oven door and remove (if possible). Refer to your owner?s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn?t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 ? 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
Good sources to find a replacement igniter include:
searspartsdirect.com*
appliancepartspros.com*
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best price.
* These two sites also provided excellent exploded view diagrams to assist in part identification and assembly.
If you have any questions about this repair, please let me know. I hope you find this information helpful.
Browse below to find the part or product that you need.:
http://www.apwagner.com/index.php?main_page=index&cPath=4_170&sort=20a&filter_id=10&alpha_filter_id=0
Jun 17, 2011 | KitchenAid KESC308LSS Electric Kitchen...
Oven will not come on
Does your clock work? This sounds like either a lack of voltage to the oven igniter, or a failed spark igniter or both. Your oven igniter is the easiest to check. With broiler door open or the plate above your oven burner removed, turn your oven on and look for a red to white glow near your ovens burner. This is a ceramic glow plug, and it will not allow gas to leave your manifold until the igniter has reached the proper temperature. If there is no glow, then your igniter has failed and needs to be replaced. The spark module that clicks as you turn your burner has obviously either died, or there isn't enough voltage being supplied to allow it to start up. Unplug your 110v wire from the stove and try a hair dryer or other 110v appliance at the wall outlet to determine if you have proper voltage there.
The worst case scenario is that both your oven igniter and spark module have died, which is rare unless you have had a power surge or lightning strike near the power transformer to your house.
The cheapest way to test this is to buy the oven igniter first, since they are far cheaper than the spark module. If the new igniter lights up, then you can be pretty sure it isn't your power outlet, and can safely move on to the spark module.
Mar 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven takes way too long to heat
This advice is for GAS ovens with glow bar type igniters. This is how to determine if the igniter is bad. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance.
An igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad. An igniter should only take 30-90 seconds to ignite.
Mar 24, 2008 | Whirlpool SF315 Dual Fuel (Electric and...
When i turn on the oven the glow bar light up but seam like no gas is coming out of the burner
It sounds like you have a bad oven igniter. Over time an igniter will age and will not draw enough current to open the gas safety valve. This is why you won't hear any gas flowing. This is actually a designed safety feature that prevents free flowing gas from accumulating in your home without ignition.
There are two basic types of igniters:
If you need to replace an igniter, follow these steps:
6. Unplug the old igniter and remove the mounting ***** holding it to the gas manifold.
If you need further assistance, post back with your questions/concerns. I hope this helps you.
Mar 10, 2008 | Kitchen Ranges
Dynasty DGRSC 30 Gas Kitchen Range Logo
152 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
