Question about Procom Heating & Cooling
Have propane Procom heater want to convert to Natural gas. Can you advise me?.
    Master:
  • 403 Answers
The gas company has to come change the regulator for you
Posted on Mar 21, 2011
3 Suggested Answers
  • 108 Answers
SOURCE: procom MN300HPA ventless heater conversion
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
Posted on Nov 07, 2008
  • 22 Answers
SOURCE: convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Posted on Sep 15, 2009
Hello, How to convert a ProCom VentFree Stove QL300TYLA from Propane to natural gas..
yo have to get a kit the orifices are way different because nat gas runs at one half a pound and propane runa at 10 pounds
Feb 20, 2010 | Procom QL300TYLA Heater
I have a ProCom FBN400TYLA vent free natural gas fireplace and want to convert to propane because the gas company wants too much money to hook up a line. Is this even possible?
Found the manual on line and copied directly from it:
WARNING
Models FBN400 are equipped for Natural
gas. Field conversion is not
permitted.
Models FBL400 are equipped for Propane
gas. Field conversion is not permitted
This should answer your question.
See if you can run the gas line or find someone to do it cheaper for you.
Nov 15, 2009 | Procom QL300TYLA Heater
I want to convert a QN300TYLA natural gas unit to
HI , I HAVE A PROPANE MODLE QL300TYLA I WOULD LIKE TO CONVERT TO NATURAL GAS , MAYBE WE CAN SWITCH PARTS.
Oct 08, 2009 | Procom QL300TYLA Heater
Convert a procom heater from propane to natural
Sep 14, 2009 | Procom ML300TBA Heater
Procom MN300HPA ventless heater conversion
Ray
Nov 06, 2008 | Heating & Cooling
Natural gas conversion
I have a similar problem. But, I want to convert it to propane. I have a 5 burner vent free modelMN300HPA. If your are handy. I would consider shipping you the parts inside mine to install in yours. These parts are very simple to remove after removing the access panels. I have taken mine out already. Called procom then to no less find out the propane parts needed are not sold by them. I think only the injectors (5) the main valve (regulator) and the pilot are the only things need to change. When taking out the pilot this is easly done, By removing the nut on the supply line. And then bending back the retaining tabs to then slide back the pilot then it comes out of the assembly bracket. Injectors are simply removed. Regulator located at the bottom is a simple remove. The only other item that might be questionable would be the valve that selects the amount of burners you would like to operate. And I would think this would be the same and not need removing. Let me know if I can help. I would like to get mine converted to propane. Thanks Tom
Oct 22, 2008 | Procom ML300TBA Heater
ProCom VentFree Natural Gas 30,000BTU Garage Heater
first you gotto see IF a changeover is possible! do your instruction manuals say it can be converted?
Jan 12, 2008 | Heating & Cooling
Heating & Cooling Logo
229 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
